Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 08-21-2008, 12:50 PM   #1
stusha
Member#: 94862
05 WRX WRB Stg2
2009 STI Stg 2
Default Replacing head gaskets OEM or COMETIC 1mm or 1.3mm
Hey Guy's...
Im replacing my head gaskets on my 05 wrx. im running stage 2 XPT. Should i get oem's or dish out a few more buck's for cometic's, the cometic's are avalible in 1mm or 1.3mm witch ones would be the best for my application.
& should i replace the head stud'd or re use my oem's...
Thanks for all your help.
PS I am repacing my head gaskets because i am putting in a new EJ20 Shortblock (i Spun a rod bearing)...**** happens write....
stusha is offline   Reply With Quote
Old 08-21-2008, 05:01 PM   #2
bryancregger
Member#: 174103
2002 Impreza WRX
Midnight
well thicker head gaskets will lower your compression ratio i believe and if your only stage 2 there is no reason why OEM won't work.. its not like your throwing 30 lbs of boost at your engine. I went with OEM and mine are fine
bryancregger is offline   Reply With Quote
Old 08-21-2008, 06:27 PM   #3
Cocoa Beach Bum
Member#: 17355
Cocoa Beach Bum is offline   Reply With Quote
Old 08-21-2008, 07:08 PM   #4
GeneralTJI
Member#: 152680
I Parted out WRX
for my Pilots License :)
You can re-use the head studs... It's never a bad idea to get new ones though... or go ahead and get some ARP studs.. they are the best. But many have re-used the head bolts and been ok....
GeneralTJI is offline   Reply With Quote
Old 08-21-2008, 07:47 PM   #5
Cocoa Beach Bum
Member#: 17355
You seem to be answering a question which wasn't asked. His question was about gaskets, not studs.
Old 08-21-2008, 07:49 PM   #6
stusha
Member#: 94862
05 WRX WRB Stg2
2009 STI Stg 2
Default head stud
I asked about the head studs too. is it safe to re use my old ones or should i get new oem's or ARP's
Old 08-21-2008, 07:54 PM   #7
Clark Turner
Member#: 178047
02 WRX STI Spec C
Since you staying with the 2.0 block, use the OEM headgasket for the motor. Never reuse trq to yeild head bolts. Throw them out. I suggest you buy a set of ARP head studs. Use the ARP lubricant and read the instructions. Use the same pattern but trq all to a low 20 or 30 ft lbs. Come back and increase them to 50. Then 70. A couple hours later trq them full out to 80 to 82 lbs. I would then wait 12 hours at least and then come back and do a final trq on them.
Everyone has a system and even the final number is debated. I have used 82ft lbs for 5 years with not one single failure. Its important that you wait over night and come back. I normaly find one or two that will take another bit before the trq wrench clicks.
Clark
Clark Turner is offline   Reply With Quote
Old 08-21-2008, 09:02 PM   #8
xWrx
Member#: 116387
02 Straight pimpin
good info clark
xWrx is offline   Reply With Quote
Old 08-21-2008, 09:42 PM   #9
stusha
Member#: 94862
05 WRX WRB Stg2
2009 STI Stg 2
Should i have my heads planed or re surfaced ?????? what about Hondata intake gaskets are they any good???
Once again thanks for all your help!!!!
Old 08-22-2008, 01:12 PM   #10
Clark Turner
Member#: 178047
02 WRX STI Spec C
Dont surface the heads unless they are warped. Check for flatness. I have never used the hondata gaskets. Grimspeed makes some that people seem to like.
CLark
closed subydude02 Engine/Power/Exhaust 41 08-11-2010 08:29 AM
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 03:41 AM
04 WRX Interior for 02/03 Interior or WRX TR Interior cartwheels4amile SCIC Private Classifieds 5 06-04-2010 11:53 AM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 08:53 AM
FS : Innovate LC-1 Wideband with XD-Gauge alcoolaid VIC Private Classifieds 0 06-04-2010 04:12 AM
