Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 03-31-2012, 12:01 PM   #5476
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Haven't found that rattle yet josh? Another method I used to locate it was to drive without the center console and shift boot on, so I could grab parts of the shifter when it rattled to see if I could find it.
JBPSTI04 is offline   Reply With Quote
Old 03-31-2012, 03:10 PM   #5477
MouseMarine
Member#: 312313
2010 WRX Hatchback
Default Rattle?
Originally Posted by jrt20 View Post
Do you have a rattle with yours? I have to find where my rattle is coming from.
No rattle so far, but I only tested it for 5 miles or so on normal roads and highways. I just took everything apart again to make sure my torque was correct.
Did you accidentally break any clips?
MouseMarine is offline   Reply With Quote
Old 03-31-2012, 08:49 PM   #5478
jrt20
Member#: 296210
2013 STI
WR Blue Pearl
Yea that's what I was going to do tomorrow. Hopefully I don't slice my finger doing this. I have a feeling it is the shift linkage rattling against that metal frame that surrounds the hole of the shifter area. What concerns me is that the rattle is not consistent giving me false theories of what it is. It will sound louder one day than the other or briefly disappear for a ride. Odd.
jrt20 is offline   Reply With Quote
Old 03-31-2012, 08:56 PM   #5479
jrt20
Member#: 296210
2013 STI
WR Blue Pearl
That's something else I was considering. When I installed the shifter, I didn't know to not assemble everything together. So, I basically forced the bushings into place by bullying the shifter support rod out of the way. May have cause some unforeseen damage. Eeeeekkkkk. I will find out tomorrow.
Old 03-31-2012, 09:38 PM   #5480
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
My rattle was only semi-consistent as well. I got it only in certain gears, at certain rpm's during acceleration. Try and retorque as much if the assembly as you can.
I don't know if there's really anything you could have broken under there, but I guess that's worth considering as well. I just don't know how different your assembly is compared to mine.
Old 03-31-2012, 09:55 PM   #5481
MouseMarine
Member#: 312313
2010 WRX Hatchback
One thing I noticed when I was installing mine was when I shifted to 3rd gear with the sound proofing piece off, I intermittently heard squeaking from the little rubbery protruding thing right in front of the shifter in 3rd gear. Seemed like the linkage would rub on it.
I notice my shifter lightly vibrates a good amount while driving, so I would only add that as another place to look.
Old 03-31-2012, 09:57 PM   #5482
MouseMarine
Member#: 312313
2010 WRX Hatchback
Does it sound louder during colder weather, and stop after you have been driving a while?
Old 03-31-2012, 10:33 PM   #5483
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
That metal frame surrounding the shifter causes rattles as well from the reading I have done, and on GD's, people would spin that piece around 180 (so front is in the rear) to gain clearance and lose the rattle. I thought that was my problem at first, but after removing that price altogether and getting the rattle while driving, I eliminated it as a possibility.
This whole rattle thing is probably detracting from the awesomeness of the new shifter, but I promise it will be worth it when you solve it.
Old 03-31-2012, 10:43 PM   #5484
black11wrx
Member#: 296339
2011 WRX
Hey guys just got my ebay lip in today and it looks like its gonna fit up perfectly. Will have it on sometime early this week. definatly by the forced 4's meet. Also finally got the windshield stripe done on my car, so looks a little better. Will post pics up later
black11wrx is offline   Reply With Quote
Old 04-01-2012, 12:09 PM   #5485
Twitch8x
Member#: 306335
05 Impreza
Also selling a set of 18" wheels
Twitch8x is offline   Reply With Quote
Old 04-01-2012, 12:53 PM   #5486
black11wrx
Member#: 296339
2011 WRX
what kind of wheels? pics?
Old 04-01-2012, 12:58 PM   #5487
Twitch8x
Member#: 306335
05 Impreza
Pm me your number ill send pics
Old 04-01-2012, 04:56 PM   #5488
chadb
Member#: 198179
2007 STI
UGM
Is anyone good with the accessport.. Haveing some issue with new downloads on the port. And my new computer has some issue with uploads as well. Any help would be appicated..
Thanks..
chadb is offline   Reply With Quote
Old 04-01-2012, 05:02 PM   #5489
black11wrx
Member#: 296339
2011 WRX
Thanks..
Which tunes are you trying to put on it? You have to add tunes through the accessport manager software
Old 04-01-2012, 05:27 PM   #5490
chadb
Member#: 198179
2007 STI
UGM
I would feel a lot better if someone was here to help with the set. I had done like 2years ago. I need to change a bunch off stuff.
Old 04-01-2012, 08:03 PM   #5491
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Were you sucessful to your upgrades??
EROCS04SBRUSTI is offline   Reply With Quote
Old 04-01-2012, 08:06 PM   #5492
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
I am not yet,trans installed twice this Saturday because i am really having a problem with my throwout bearing,when the clutch pedal is pressed and comes off the snap ring,and i have to uninstall the damn tranny and presssure plate once again.I never had this problem after 3 sucessfull clutch jobs,i really thinkin of tack welding it in so it does not pop off once again til the clutch is worn.Any other ideas?As this stuff is brand new.
Old 04-01-2012, 08:53 PM   #5493
chadb
Member#: 198179
2007 STI
UGM
Limp mode sucks....and I need metal turbo inlet pipe.
Old 04-01-2012, 09:11 PM   #5494
jrt20
Member#: 296210
2013 STI
WR Blue Pearl
Found out that the rear bushing was not installed properly. I assumed that the bolts for the rear bushing would just thread properly back into their respective holes. Nope. The passenger side bolt cross threaded and what seemed to be fully tightened was only half way threaded. Fml. Well I did my best to fix the cross threading, but the big success is no more rattle. Whew.
Old 04-01-2012, 09:12 PM   #5495
Jovver
Member#: 107076
'06 WRX STi (WRB)
'06 Outback 2.5 (WGO/MGM)
Good job, now you can sleep peacefully again!
Jovver is offline   Reply With Quote
Old 04-01-2012, 09:15 PM   #5496
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Glad you figured it out!
Old 04-01-2012, 09:20 PM   #5497
jrt20
Member#: 296210
2013 STI
WR Blue Pearl
I did have a squeak caused by the linkage boot. Lithium grease fixed that.
Old 04-01-2012, 09:27 PM   #5498
black11wrx
Member#: 296339
2011 WRX
Glad to see its fixed
Old 04-01-2012, 09:29 PM   #5499
jrt20
Member#: 296210
2013 STI
WR Blue Pearl
My shoulders and neck feel fantastic. I can't believe how much that bolt was not threaded in. Shifting is more fun without the worry of something falling apart. The flaps have also been installed and they look awesome.
Old 04-01-2012, 09:40 PM   #5500
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
damn just sold 2 last month,good job on the linkage jrt20.
Calling All Cleveland Area Scooby owners!!! nick32 Mid West Subaru Owners Club Forum -- MWSOC 21 04-03-2008 04:55 AM
Cleveland Ohio I-Club jayfressh Mid West Subaru Owners Club Forum -- MWSOC 9 04-02-2002 06:44 PM
Vin #11 1998 SOA 2.5L RS at Cleveland Ohio AutoRama!!!! black99gt Member's Car Gallery 4 01-21-2002 10:31 PM
Need WRX-help in Cleveland, Ohio... Shaka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-12-2001 10:05 AM
('93-'01) Cleveland, Ohio - A day at the drag strip event! Shaka Impreza Forum 9 10-04-2001 11:58 AM
