Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 08-23-2012, 09:44 AM   #6601
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
I have a long night at work tonight, but there's a chance I might go. I'll keep you in the loop Erik. Lemme know if anybody plans to meet up or anything.
JBPSTI04 is offline   Reply With Quote
Old 08-23-2012, 09:46 AM   #6602
Jovver
Member#: 107076
'06 WRX STi (WRB)
'06 Outback 2.5 (WGO/MGM)
I was thinking resume last weeks plan?
Jovver is offline   Reply With Quote
Old 08-23-2012, 09:53 AM   #6603
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
If I go, that works for me. I'm assuming you mean Richfield commons, 6pm?
Old 08-23-2012, 09:54 AM   #6604
Jovver
Member#: 107076
'06 WRX STi (WRB)
That's the one.
Old 08-23-2012, 11:29 AM   #6605
Flat_4_Scoobaru
Member#: 290513
'05 WRX STi
Obsidian Black Pearl
After a the long drive to Chicago the STi is back under the knife. I might be out untill next season.
Flat_4_Scoobaru is offline   Reply With Quote
Old 08-23-2012, 12:24 PM   #6606
GromsKillA
Member#: 292760
2005 CGM STi
'02 Impreza OBS
What's the plan?
GromsKillA is offline   Reply With Quote
Old 08-23-2012, 01:31 PM   #6607
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Okay, I'll be going tonight. I'll be in Richfield at 6
Old 08-23-2012, 01:31 PM   #6608
Jovver
Member#: 107076
'06 WRX STi (WRB)
Perfect, I'll be there too.
Old 08-23-2012, 10:52 PM   #6609
ROCK WHITE
Visiting NASIOC Timeout
Member#: 274453
04 STi
psm
after 1 week on jackstands the bugeye lives again (rides soo much better). hasnt been bad been though, ive driven the chrysler crossfire all this week ( a benz 6 spd roadster)
ROCK WHITE is offline   Reply With Quote
Old 08-23-2012, 11:25 PM   #6610
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
What did you do? Lateral links finally?
Old 08-23-2012, 11:37 PM   #6611
ROCK WHITE
Member#: 274453
04 STi
psm
nope. i replaced all these items with low milage jdm sti aluminum parts that i re-built(cleaned and greased)
ball joints
tie rod ends (inners too need to be installed)
jdm sti caster addings control arms (greased everything) free caster mod is gonna be done this weekend!
and
jdm pass hub/spindle with good bearings
jdm front sway links
tryed to zero out toe, and max neg camber, riding pretty good!
lateral links next and alignment and tire install!
Old 08-24-2012, 04:18 PM   #6612
endlesss
Member#: 196720
2015 WRX STI
Dark Gray Metallic
Glad to hear it went well Rob. That's definitely a time consuming job but also high on the satisfaction scale in my book.
endlesss is offline   Reply With Quote
Old 08-27-2012, 12:34 PM   #6613
SubieNAEJ25
Member#: 330414
Hi Guys. New to the forum. Glad to have found this resource.
Can any fellow Subaru owners in the Cleveland area recommend any Subie friendly mechanic shops? Not necessarily speed or tune shops. Just regular run of the mill mechanic for repairs/maintenance.
SubieNAEJ25 is offline   Reply With Quote
Old 08-27-2012, 12:44 PM   #6614
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Welcome. I'm from a ways down south, so I can't recommend shops, but if I may ask, what do you need done to your car?
Old 08-27-2012, 06:09 PM   #6615
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Yes what do you need done?I'm not to far from you in elyria,welcome to the forum.....
EROCS04SBRUSTI is offline   Reply With Quote
Old 08-28-2012, 10:40 AM   #6616
SubieNAEJ25
Member#: 330414
I might need a CV replaced soon. But I'm not quite sure the dealers up here are the most cost effective option.
This was more of a general curiousity of Subie friendly mechanics in the area. Hoping owners here had some good experiences with some.
Old 08-28-2012, 01:49 PM   #6617
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Eroc blows Through axles like its his job from what I remember, and can probably do any work you need more thorough and cheaper than any garage.
Old 08-28-2012, 09:53 PM   #6618
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
this is true but not lately from the strip/I do have the axles also if its a sti.if not still can help.
Old 09-01-2012, 02:15 AM   #6619
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
I'll be at the shop ALL effing weekend...
if someone gets bored, and wants to swing by, or needs to work on something.. show up, text me, pm me.. whatevs.. pretty much going to rock - out until the car is done.
STFU STi is offline   Reply With Quote
Old 09-02-2012, 04:17 PM   #6620
ROCK WHITE
Member#: 274453
04 STi
psm
lateral links are off of my car! if anyone ever has stuck lateral link bolts, save yourself the time and effort and source a new bolt and use a powerful air hammer!
so much easier than all the othe ways
Old 09-02-2012, 09:57 PM   #6621
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
Werd.
I concur 10000%. However... If you coat those guys in moly, then torque to spec... Then paint moly into the long bolt window with your flux brush, you never need to worry about it again.,
Old 09-03-2012, 08:38 AM   #6622
ROCK WHITE
Member#: 274453
04 STi
psm
yes anti-sieze will be applied when i reassemble. the driver side that i had i had apart when i re built the car came apart no problem(anti sieze used), but the passenger side had never been apart(70k) . i also used the anti sieze on the front subframe bolts and ball joint pinch bolts
Old 09-03-2012, 09:06 AM   #6623
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Maddad midpipe has been installed and coated, and I've bought and installed RCE black springs.
Old 09-03-2012, 05:15 PM   #6624
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
The black moly anti seize is used everywhere..
I've found that it's the best thing between bushing sleeves and the through bolts.
If possible... Lower the car, so it's supporting it's own weight, then re-torque all those bolts.
Torque specs, for quick reference..
Trailing mounts. 74
Trailing front. 85
Trailing rear. 66
Lat links:
Long bolt: 103
Inside (both cam, and straight). 74
Inspect the cam washers, if the straight edges are pinched, or rounded, replace them.
They're cheap... Under $2 each... And I always stock all those rear brs as spare anyway, if any of you find yourself in a bind..
Old 09-04-2012, 07:34 PM   #6625
STFU STi
Member#: 39528
2005 STi
Black and TiC Cows
Hey fellers..
car is ready for it's corner balance... and alignment... EFFING FINALLY
so yeah.. do any of you have an STi spare tire I can buy or Borrow..????
I really prefer to do all the adjustments and torques using the narrowest wheels possible.. yet I don't want to drive back to Indiana.. to raid my storage unit..
Calling All Cleveland Area Scooby owners!!! nick32 Mid West Subaru Owners Club Forum -- MWSOC 21 04-03-2008 04:55 AM
Cleveland Ohio I-Club jayfressh Mid West Subaru Owners Club Forum -- MWSOC 9 04-02-2002 06:44 PM
Vin #11 1998 SOA 2.5L RS at Cleveland Ohio AutoRama!!!! black99gt Member's Car Gallery 4 01-21-2002 10:31 PM
Need WRX-help in Cleveland, Ohio... Shaka Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-12-2001 10:05 AM
('93-'01) Cleveland, Ohio - A day at the drag strip event! Shaka Impreza Forum 9 10-04-2001 11:58 AM
