Old 08-22-2008, 12:14 AM   #1
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Default 05' Legacy 2.5i and Outback 2.5i - Non Turbo Tranny?
Quick question: I know the 05' LGT and Outback XT got the better transmissions and the XT has the 4.44 instead of the 4:11. So what about the regular 05' Legacy and Outback? It looks like the Legacy 2.5i has a 3.90 FD and the Outback 2.5i has a 4.11 FD with these ratios.
1st 3.454
2nd 2.062
3rd 1.448
4th 1.088
5th .871
I wonder what parts bin subaru dug in to make these? Any ideas as to what gears they used, and what other tanny this could be diguised as? It seems it would have the newer syncro design and what not. I think the 2.5 RS has this tranny as well. I wonder what kind of gears they have as far as strength or gear width. I would think Subaru would just use what they have and I think the dual mass flywheel is used on the turbo model to soak up some shock going to the gears to help them survive the higher power. I've seen it listed on cars101 as the turbo model having a "Heavy Duty dual mass flywheel" and also listing the 2.5i as having a standard transmission and the turbo model having a "reinforced 5 speed". The outback 2.5i is listed as having a 4.11 final drive and a limited slip rear end also.
I'm just curious because i can pick up one of the Outback 2.5i trannys with 20K miles and the matching 4.11 Limited slip rear diff for dirt, I'm talking dirt cheap. Is it even worth messin with?
morrocco88 is offline   Reply With Quote
Old 08-23-2008, 01:45 PM   #2
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Anyone!
Old 08-29-2008, 01:36 AM   #3
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Nobody has any input on this?
Who is using non turbo tranny with turbo engine swap? scurabus Subaru Conversions 9 01-02-2010 05:37 PM
CT:ACT or Exedy Clutch Kit for 04 Non-Turbo Tranny prokaw875 Private 'Wanted' Classifieds 0 09-21-2009 07:39 PM
What is the difference between a 2.5RS and a 2.5i Subaru Impreza? rhinh25 Normally Aspirated Powertrain 50 07-28-2007 11:00 PM
06 Legacy and Outback 2.5I updates... Diabolical1 CC Legacy Forum 7 08-16-2005 04:27 PM
Voluntary Recall of MY01 Legacy L, GT and Outback miksmi Legacy Forum 0 12-08-2000 10:57 PM
