Old 08-22-2008, 12:57 AM   #1
Sparky280
Member#: 69896
98 WRX Swapped "L"
VF39 294HP/277TQ @19psi
Default RPM raise while shifting..
So my swap has been running good usdm ej20, and recently the IACV went bad so I replaced it and it began to idle better, but now i'm having a different issue. My idle at a stop is at like 1000-1200 and when i'm driving around the revs jump when I shift it does not do it constantly but sometimes, i'll shift at 3000 and I release throttle depress clutch it jumps to 4000 like i'm rev matching. I don't know what could be the culprit any ideas? I have a stock sti BOV so it's not that. IACV is new so hopefully it's not that. bad tps maybe? Only code being thrown is P0507...
Sparky280 is offline   Reply With Quote
Old 08-22-2008, 01:28 AM   #2
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
dam i sound stupid when i ask this... but what is IACV
azn0boi04 is offline   Reply With Quote
Old 08-22-2008, 07:39 AM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Idle Air Control Valve.
Sounds like you have a vacuum leak somewhere.
Jay
Old 08-22-2008, 11:05 AM   #4
Sparky280
Member#: 69896
98 WRX Swapped "L"
guess i'm going to have to look for a leak, anyone know some common locations of leaks? I know i tightend down the TMIC on both the TB and the Turbo to make sure there was no leak there. Could loose uppipe or exhaust leak be the cause? I know I havnt had a chance to check the torque of the bolts again since i've been driving for a bit?
Old 08-26-2008, 11:38 PM   #5
2ndGearFling
Member#: 64466
05, STI on green
make sure throttle cable is loose enough, if its tight when the car heats up it will cause rpm's to raise rapidly.
2ndGearFling is offline   Reply With Quote
Old 08-27-2008, 01:25 PM   #6
Sparky280
Member#: 69896
98 WRX Swapped "L"
i just adjusted that last night and it still does it, I am starting to get the darn IACV code again (1507) but the IACV is new I wonder if i need a new throttle body? I can't seem to find a vaccum leak anywhere, the only issues i'm having is the two code P0507 P1507 and my car idles at 1k i get random jumps in RPMS when shifting, could my exedy LW flywheel cause the jump in rpm?
Old 09-03-2008, 03:07 PM   #7
Sparky280
Member#: 69896
98 WRX Swapped "L"
bump,
still having this issue, just replaced the Neutral safety switch and still having P1507, what the heck is going on, this is drving me crazy.
Old 09-03-2008, 04:10 PM   #8
Handsome_Rob
Member#: 160257
'09 Madone
Are you letting off of the gas while youre shifting? JK.
Handsome_Rob is offline   Reply With Quote
Old 09-03-2008, 04:45 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
What if you remove the electrical portion from the IAC (mark its position) and try again. The ECU will still be sending a signal to the coil but the IAC itself obviously wont be moving. After starting the car turn it by hand to rough adjust the idle then take it for a test drive.
Old 09-03-2008, 06:14 PM   #10
Sparky280
Member#: 69896
98 WRX Swapped "L"
didnt know i could do that, the electrical portion of the IAC looks like it uses a special tool similar to a torx, and i don't know what type of tool it is, and i thought the ECU set the idle and you shouldnt mess with it....
Old 09-03-2008, 07:53 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
I have not personally messed with the 02 WRX IAC but if its anything like the other IAC its just a valve actuated magnetically.
The ECU does set the idle but if you removed the top of the IAC then you can turn the valve by hand. Perhaps someone with more experience specific to the WRX can double check my suggestion.
Old 09-03-2008, 08:05 PM   #12
kh15
Member#: 132400
i thought our cars rev VERY slightly when you press the clutch in to help with knock or something like that....
kh15 is offline   Reply With Quote
Old 09-03-2008, 08:12 PM   #13
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
i swore it raised a little due to the recirc of the by pass valve air going through the intake....
cuz mine does it as well...
SedonaScooby is offline   Reply With Quote
RPM raises during long idle ocelot21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-01-2009 10:57 AM
little RPM jump while letting off gas and engaging clutch at same time?? gerbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-02-2003 03:21 AM
Got an RPM gauge with shift light for birthday, not sure how and where to install gerardchau Normally Aspirated Powertrain 12 03-09-2002 11:08 PM
RPM Guages w/ shift lights Rowdy2.5 Normally Aspirated Powertrain 8 07-25-2001 09:32 PM
