Old 08-22-2008, 11:20 AM   #1
Qcanfixit
Member#: 135762
2059 Venturi Skimobi
transparent aluminium
Default 2001 RS 2.5, with a Turbo from a 94 SAAB 900 CE
Title say's it... I'm reading through other threads.
I have a 2001 RS 2.5 A/T all stock.
I have been offered the turbo taken out of a 1994 SAAB 900 Commemorative Edition
I know nothing about the SAAB turbos, the TMIC is about the same size as the OEM one Subaru uses... what kind of trouble can I expect?
Will I need custom Fabrication of any parts?
I heard the stock compression may not be turbo friendly.
Can the motor handle it?
Qcanfixit is offline   Reply With Quote
Old 08-22-2008, 11:51 AM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
You'll need to do some custom work on the intake side, and you'll want to think about what you're going to do on the exhaust side too. Motor might be able to handle it if you have proper engine management.
jey is offline   Reply With Quote
Old 08-22-2008, 01:45 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
dont you live in OT? LOL
you'll need custom exhaust w/ the right flanges..
stock motor can prob handle 7 lbs with good E/M..
mxpunk is offline   Reply With Quote
Old 08-24-2008, 03:09 AM   #4
Qcanfixit
Member#: 135762
give me an idea of what proper engine management looks like.
I assume I would need a few extra gauges too
oil pressure, fuel pressure, psi, air ratio
am I missing anything?
The car does have an AEM Intake, it came with the car
I don't really consider that much of an upgrade so I say it's stock.
I'm not looking to race it, or max out the power, I just want a little more ooomph, and I want to make that scoop worth something.
Old 08-25-2008, 02:29 AM   #5
front runner
Member#: 121603
2001 legacy BH
blue
You may need more than a turbo, gauges and e/m...but you gotta start somewhere. And seeing as you aren't going the "jdm sti v5 type Ra-R full car swap", you're going the budget route. And of course, correct me if I'm wrong because you may just like the whole custom route. It can be fairly cheap if you DIY as long as you have the tools and skill.
Metal fabrication: can you weld, cut, grind, and mock up...and build custom flanges
electrical wiring: Can you read automotive electrical diagrams, now just what wire to cut and solder?
Okay, stuff you may need: BIGGER injectors, oil/coolant lines, wideband sensor, BOV, spark plugs, and probably more i forgot.
....Anyways, I'm not flaming but the last guy trying his own custom build left one last comment here, "Project over. Everything is for sale." I run 10 lbs on the stock motor BTW.
front runner is offline   Reply With Quote
Old 08-25-2008, 02:18 PM   #6
Dom'sGurl
Member#: 150837
2006 Legacy GT
using that turbo would be pointless.
The car made 185hp with that turbo.
You aren't going to gain anything, in fact you may lose power by putting that restriction in your exhaust and intake. Combine that with the fact that it's made for a 2.0L which means that it has a small turbine housing. The small housing will increase back pressure dramtically. This will reduce cylinder scavenging during valve overlap and cause the engine to knock.
DO NOT USE THAT TURBO.
Dom'sGurl is offline   Reply With Quote
Old 08-25-2008, 04:04 PM   #7
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Qcanbreakit.
atech_rallyrs is offline   Reply With Quote
Old 08-25-2008, 11:18 PM   #8
2milehi
Member#: 81633
'98 RS-T
I found it A LOT easier to add a WRX tubro, exhaust manifolds, intercooler, up and down pipe. Some bolt-on, some custom modification. But stay away if you can't weld.
http://forums.nasioc.com/forums/showthread.php?t=824400
2milehi is online now   Reply With Quote
Old 08-26-2008, 12:38 AM   #9
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
emanage ultimate if you want to stay obdII complient or the PnP Hydra + a 5MT swap..not sure about EMS solutions for cars with autos
2001 RS 2.5 Coupe Aspen White 36k miles $14,000 obo (Dallas) shyong Private Vehicle 'For Sale' Classifieds 3 07-10-2007 12:40 PM
Free K+N out of 2001 RS 2.5 BKsWRX New England Impreza Club Forum -- NESIC 5 09-04-2004 09:44 PM
2001 RS 2.5 Wagon what oil weight oldvetter Newbies & FAQs 4 10-16-2002 12:55 PM
selling a 2001 RS 2.5 beekstar Southern California Impreza Club Forum -- SCIC 0 03-29-2001 10:55 AM
1/4 mile times for a stock 2001 RS 2.5??? CyberLogic General Forum Archive 3 01-12-2001 12:29 PM
