Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 08-22-2008, 12:15 PM   #1
stoooo
Member Sales Rating: (1)
Member#: 62289
Default FS: 2001 Subaru Impreza 2.5RS Sedan
*** SOLD ***
I bought this 2001 Subaru Impreza 2.5RS Sedan in March of 2005, after a year long search for the perfect car. Prior to its move to Minnesota, it lived with its previous owner in Ohio. It is a fantastic car that has been a real pleasure to own. Only selling due to relocation. $9850 obo.
Factory Leather Interior
5spd Manual
92,6xx miles
Factory Stereo w/Subwoofer
2005 WRX Wheels with Nokian WR Tires (205/55-16)
OEM Carbon Fiber Dashboard Trim
OEM Armrest Extension
A box of service history papers (including the original window sticker)
Timing belt has been replaced
Water pump and thermostat have been replaced
Both rear wheel bearings have been replaced
Fed on an exclusive diet of Shell V-Power since purchase
Title in hand
Available immediately
VIN – JF1GC67551G501166
More pictures available upon request
Due to relocation, the easiest way to contact me is via email – stuart dot powell at gmail dot com
Car has the following modifications:
Power
Ganzflow Cold Air Intake
K&N Air Filter
Borla Header (version IV)
Tanabe Racing Medallion Catback Exhaust
Unorthodox Racing Crank Pulley
Magnecor Spark Plug Leads
NGK Copper Spark Plugs (The JIS sized ones so the Magnecors don't pop off)
Suspension
Koni Sport Inserts
Eibach Pro Kit Springs
STi Carbon Fiber Front Strut Bar
Super Pro Poly Front Lower Control Arm Front Bushings
Whiteline Front Lower Control Arm Rear Offset Bushings (Increases Caster)
Whiteline 22mm Front Sway Bar
STi Grp N Front & Rear Strut Tops
FHI 20mm Rear Sway Bar
TC Sportline Aluminum Rear Strut Bar
Whiteline Adjustable Rear Lateral Links (all four)
Whiteline Rear Toe Lock Kit
Super Pro Poly Rear Trailing Arm Bushings Front/Rear
Driveline
STi Grp N Engine Mounts
STi Grp N Pitch Stopper
STi Grp N Transmission Mount
Kartboy Short Shifter
Kartboy F/R Shifter Bushings
Turn in Concepts Shift Lever Pivot Bushing
Whiteline Transmission Crossmember Bushings
Whiteline Rear Differential Carrier Front Bushings
Brakes
Goodridge Stainless Braided Brake Lines
Racing Brake Slotted Brake Rotors Front/Rear
Hawk HPS Brake Pads Front
Hawk HP+ Brake Pads Rear
ATE Super Blue Brake Fluid
Dress Up
Clear Corners
Clear Side Indicators
Sylvania Silver Star Headlight Bulbs
Narva Gold Foglight Bulbs
Blacked out Front Indicators
Black Lower Vents
Black Mesh Foglight Covers
Blacked Out Tail Lights
Other
Trunk Light Kit
Legacy Full Intermittent Wiper Stalk
Kartboy Red Exhaust Hangers
Red Line fluids in engine, rear differential and power steering
Uncle Scotty's cocktail in the transmission
Included spare parts (OEM and aftermarket)
New Spark Plugs
New PCV Valve
New Fuel Filter
K&N Air Filter Recharger Kit
Original Tail Lights
Original Headers
Original Catback Exhaust
Original Air Intake Components
Original Front & Rear Sway Bars
Hawk HPS Rear Brake Pads (used less than three months)
Original Rear Lateral Links
Whiteline Poly Bushings for 20mm Rear Sway Bar
OEM Subwoofer
OEM Crank Pulley
OEM Engine Crossmember Weight
Extra ECU (perfect for sending off for an I-Speed reflash)
Numerous other small parts acquired in the last three years
Stuart Powell.
stoooo is offline   Reply With Quote
Old 08-22-2008, 01:09 PM   #2
pgtkid
Member#: 32810
2006 Impreza 2.5i
Sandstone Metallic
pm sent
pgtkid is offline   Reply With Quote
Old 08-22-2008, 01:23 PM   #3
coldspot
Member#: 186442
2007 Impreza 2.5i
where abouts in minny are you located?
coldspot is offline   Reply With Quote
Old 08-22-2008, 07:12 PM   #4
stoooo
Member#: 62289
SW Metro.
Old 09-19-2008, 08:54 AM   #5
stoooo
Member#: 62289
*** Sold ***
FS MA: 2001 subaru impreza 2.5rs sedan, Blue xdmethod24 NESIC Private Classifieds 43 04-06-2010 04:51 PM
FS: 2001 Subaru Impreza 2.5RS Sedan. VerySlowRS NESIC Private Classifieds 4 05-30-2008 10:41 AM
FS DFW: 2001 Subaru Impreza 2.5RS sedan Texas25RS TXIC Private Classifieds 11 08-03-2006 01:13 PM
FS: 2001 Subaru Impreza 2.5RS RadarLove Private Vehicle 'For Sale' Classifieds 2 09-19-2003 06:03 AM
FS: 2001 Subaru Impreza 2.5RS RadarLove Private Vehicle 'For Sale' Classifieds 2 09-14-2003 10:30 AM
