Old 03-12-2002, 03:10 PM   #1
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Default R&R Cupholder on GC8
Ok the captain has delivered and now I need to put this cupholder in.
This should be as easy as putting on a rear sway bar , but
I was just down looking at things in the car as well as the New cupholder sitting here, and well, I'm confused. SUPRISE!
Anyone now the trick?
Cheers,
_chris
WRSport is offline   Reply With Quote
Old 03-12-2002, 03:33 PM   #2
Pikeadon
Member#: 4422
00 RS
Yellow
open up the armrest undo the screws, pop off the piece around the e-brake, pop off the piece around the shifter undo the screws for the piece that goes around the radio ond ashtay if there are any can't remember, it is held on by two tabs at the bottom and top and some on the sides, then there are a couple of screws in the single cup holder that need to be removed.
so basically the easiest way is to take apart the center console to access the hidden screws for the single cupholder.
These instructions suck but i'm just going from memory.
Pikeadon is offline   Reply With Quote
Old 03-12-2002, 03:35 PM   #3
Pikeadon
Member#: 4422
00 RS
Yellow
oh wait just noticed you said R&R cup holder what is that, I thought you meant the dual cupholder oh well
Old 03-12-2002, 03:38 PM   #4
WRSport
Member#: 2060
00 2.5RS Coupe
Sorry, I meant the cup holder on the dash.
Old 03-12-2002, 04:41 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If you want to do it gently, you need to dismantle the climate control area. If you want to do it the quick and dirty way, pull out the two screws on the sides (the ones you can easily see) and then take a long screwdriver and remove the last screw. If you look at the one I sent you, there is a "bulge" with a hole in it. This faces down (obviously ) when the cupholder is installed. That thing has the third and final screw going through it . Remove that (you'll likely lose it down the dash), push down gently with the screwdriver, and pull straight back. It will come out .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
Old 03-12-2002, 09:04 PM   #6
WRSport
Member#: 2060
00 2.5RS Coupe
I knew those two screws were too good to be true.
Rear Brembos on GC8 with GC8 STI RA R180 rear? bicanek Brakes, Steering & Suspension 9 03-15-2008 12:31 AM
GDB ohlins on GC8 anyone? wanna trade me their GC8 ohlins for my gdb? swapstar Brakes, Steering & Suspension 3 03-14-2006 10:15 PM
225/45/17 on p7's on GC8 stitches Brakes, Steering & Suspension 2 03-27-2003 09:07 PM
help removing side rails on doors on gc8 yuzo Interior & Exterior Modification 4 10-19-2002 09:20 AM
225/45-17 S-03s on Rota Attacks on GC8 Jon Bogert Brakes, Steering & Suspension 5 10-14-2002 09:42 PM
