Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 08-22-2008, 08:51 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Complete Clutch Install Kits-Clutch/Flywheel/Fluid/Clutch Line $645
Bad news guys. Exedy just announced a price increse
Never fear! Gruppe-S just decided to give away a few free items with your clutch kits.
Choose Your Clutch
Exedy Combos
Exedy Stage 1 (98-04 Impreza)
4 Quarts Redline 75-90NS Fluid
Gruppe-S Steel Braided Clutch Line
$645 Shipped
Pm For Price with a ACT Streetlite Flywheel
Exedy Stage 1 (02-05 WRX)
$699 Shipped
Add a Gruppe-S Flywheel For Only $1 More
Exedy Stage 1 (06-07 WRX)
$699 Shipped
Exedy Stage 1 (04-07 STi)
$699 Shipped
Exedy Stage 2 (02-05 WRX)
$789 Shipped
Exedy Stage 2 (06-07 WRX)
$789 Shipped
Exedy Stage 2 (04-07 STi)
$749 Shipped
ACT Combos
ACT Street Clutch/ ACT Flywheel (98-04 Impreza)
$705 Shipped
ACT Street Clutch/ Gruppe-S Flywheel (02-05 WRX)
$645 Shipped
ACT Street Clutch/ Gruppe-S Flywheel (06-07 WRX)
$745 Shipped
ACT Street Clutch/ Gruppe-S Flywheel (04-07 STi)
$775 Shipped
Pushing extreme power? Step up to our multi plate combos. Guaranteed the best price anywhere. We will beat anyones price.
Exedy Twin Plate
Too Low To Advertise Pm For Price
Exedy Triple Plate
Cusco Twin Plate (04-07 STi)
$1599 Shipped
Carbonetic Carbon Twin Plate
Carbonetic Carbon Triple Plate
JDM Subaru STi RA 5sp Gear Set
Special Order From Japan
Do you need to hold more power put cannot afford the STI 6-speed transmission? Don't want the inconveniences of a dog-box or the price? Looking for a more track friendly gear ratio? Then our STI RA gear-set is the perfect solution for you!
The STI RA V6 gears are a found in the rally-bred Version 6 Impreza STI RA and is designed to be a much beefier swap for your WRX 5-speed transmission. The cryo-treated and thicker gear teeth make for stronger gears and shaft. These makes for a perfect solution for customers looking for gear-sets that will hold more power. For further strengthening, the mainshaft, 1st gear, and 2nd gear are WPC treated.
We recommend these gear-sets for customers looking for gear-sets to hold 275-350 awhp. For higher power levels we would recommend either a STI 6-speed tranny or a synchro-less dog-box.
All gearset kits include STI RA Gears 1-5, main shaft, properly matched speed-o gear, and shifter fork. Please see our bearing and synchro sections for a complete rebuild kit. Rebuild time is generally 5-6 hours of bench time (not including removal & installation) and if your transmission is damaged will usually require new bearings and synchros.
Gear Ratios:
First Gear 3.083
Second Gear 2.062
Third Gear 1.545
Fourth Gear 1.151
Fifth Gear 0.825
$1499 Shipped
***Special Order From Japan***
JDM STi 5th and 6th Gear Close Ratio Conversion Kit
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios
5th Gear - 1.062 (0.971 stock)
6th Gear - 0.842 (0.756 stock)
$375 Shipped
Cusco 6 Speed Dog-Box Kit
The Cusco Dog-Box Kit converts the original synchronize-type 6MT to a Dog type 5MT. By using the genuine main body, the price is about half of the competitor's. It makes for a nice shift feeling without popping out. There are plenty of maintenance parts are available also. Reasonable Dog box by effective structure gives you a nice feeling and better results!
$6199 Shipped
Kartboy Short Shifter
The World Famous Kartboy Short Throw shifter replaces the stock shift lever in 1997-2008 model year Subaru Impreza vehicles. Overall shift throw is decreased by 40%, providing a noticable difference and a solid feel.
Constructed of CNC'd and TIG welded 4130 Cr-Mo steel. Installs with simple mechanic's tools in under 30 minutes. Made in USA.
Kartboy Short Shifter Combos
02-07 WRX w/ Standard Shifter
$125 Shipped Free Gruppe-S Shifter Bushings/Free Kartboy Rear Shifter Bushing
05-07 WRX w/ Factory Short Shifter
04-07 STI
$175 Shipped Free Gruppe-S Shifter Bushings/Free Kartboy Rear Shifter Bushing
Kartboy Bushings
$35 Shipped
Rear Differential/ X-Member Bushings
$30 Shipped
Transmission Crossmember Bushings
$30 Shipped
Perrin
PERRIN knows itís important to keep your rear end cool! So keep it cool with the PERRIN PerformanceTM Differential Cover. Made from high strength, heat-treated cast aluminum, our cover incorporates cooling fins to reduce oil temps, thus extending the life of your expensive differential. Additionally, the oil capacity is increased more than 30% over stock. All combined in a great looking design to positively accentuate your rear end!
$265 Shipped
__________________
Thanks,
Gruppe-S
[COLOR=black][B]Please Note:[/B]
[I]- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available[/I][/COLOR][I]
- [B][COLOR=Red]No Cancellation on JDM Or Special Orders. No Exceptions![/COLOR][/B][/I]
Gruppe-S is offline
Old 08-25-2008, 04:35 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 08-26-2008, 01:56 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 08-27-2008, 02:49 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 08-28-2008, 02:07 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 08-29-2008, 02:41 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-02-2008, 06:12 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-03-2008, 01:40 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-03-2008, 08:16 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Closing Thread Guys
Click Here for Updated Specials
http://forums.nasioc.com/forums/show...7#post23567087
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Closed Thread
Competition Clutch - Clutch Kits and Flywheels GST Motorsports Drivetrain 6 07-09-2012 09:39 AM
Clutch kit and flywheel install-Who do you recommend? ammo0000 Rocky Mountains Impreza Club Forum -- RMIC 7 02-18-2010 09:07 PM
FS PA: Various Brake Lines, Motul Fluid, Clutch Line InfiniteMotorsports Suspension/Brakes/Handling 31 11-26-2009 01:03 PM
Installing my clutch kit and flywheel in to my 2000RS needs a head ups workin4audi Transmission (AT/MT) & Driveline 1 09-02-2004 08:02 AM
OK guys need a heads up...Installing clutch kit and flywheel workin4audi Tri-State Area Forum 0 09-01-2004 10:55 PM
