Old 08-24-2008, 03:26 PM   #1
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
Default Can I get a V8 USDM STI Motor Swap for $5000?
I blew the motor on my 04 WRX and I'm trying to figure out to do with the $5000 or so I have saved up. I don't need crazy power levels so I'm thinking of just swapping in a stock USDM STI engine and calling it a day. No transmission, no significant mods. I need a reliable daily driver so I can't have an engine that will blow again right away. Are used USDM engines reliable? Also, I need USDM because I need OBD-II compliance.
Can this be done (with labor) for $5000?
whtlegacy is offline   Reply With Quote
Old 08-24-2008, 05:04 PM   #2
ronin555
Member#: 135862
04 STI
JBP
Lots of people go through east coast swappers.
http://eastcoastswappers.com/
ronin555 is offline   Reply With Quote
Old 08-24-2008, 09:33 PM   #3
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
let me ask my buddy i think his company has 4 08 motors from the fast in the furious cars that were crashed :]
bue car is offline   Reply With Quote
Old 08-24-2008, 09:33 PM   #4
25rsti
Member#: 166324
figure out whats wrong with ur car and fix it with beefier parts, if its something in the block build it w/ better pistons and bearings, if its just the heads fix that and dopistons in the short block. my advice is find out whats wrong first and then start brain storming
Old 08-25-2008, 09:46 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you don't want an 08 motor unless your willing to go hybrid
(take apart and use the bottom end)
and technically there never was a usdm v8
the GDF started with the C revision
a jdm ver 8 would be ALLOT easier and and fit your budget
Old 08-25-2008, 06:57 PM   #6
legacy2003
Member#: 38338
2003 Outback Sdn H6
No you can't swap in a USDM STI motor for $5k or less with labor. The motor kit itself will probably cost you more than $5k alone, if you want a complete one or one that doesn't have anything wrong with it.
JDM Ver. 7/8 STI would be an easier swap into your car, given that the wiring is the same (less labor), but even then, good luck finding one for less than $4-5k alone. With some tinkering they will pass OBDII compliance testing.
legacy2003 is offline   Reply With Quote
Old 08-27-2008, 12:01 AM   #7
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
thanks for your help. it sounds like the STI motor is out of my price range and while I would love to mess around with a JDM 2.0 I have to drive this car every day and pass emissions.
I will probably just replace the block with a new, OEM 2.0, machine or buy new heads and replace the turbo.
I will be staying at stage 2 2.0l and will upgrade the oil pump hopefully for better reliability.
Old 08-29-2008, 02:34 PM   #8
MyRedScooby
Member#: 73166
2006 Acura TL 6-SP
Anthricite
Buy 2.5 block and go hybrid
MyRedScooby is offline   Reply With Quote
Old 08-29-2008, 06:51 PM   #9
MrPhiscal
Member#: 47843
www.outfrontmotorsports.com I spoke to them the said 2400$ to rebulit a block and close the deck. 2.0 us spec built close deck block it may not bet a jap spec. I would rev the CraP out of it.
What if the head is warped or very hard to seal again, better safe that sorry
MrPhiscal is offline   Reply With Quote
Old 08-30-2008, 06:19 PM   #10
84cj
Member#: 85261
1993 Impreza L 1.8
white
Not to sound like an a$$, why do so many people look at spending 5k to replace an engine when a rebuild could be done cheaper and know it works? Seems rebuilding is a better option, IMO...... :shrug:
84cj is offline   Reply With Quote
Old 08-30-2008, 09:59 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Why would you spend that kind of money when a factory crate shortblock costs you less than $2000?
To the original poster, as long as you have no head damage, get an Ej257 STi shortblock, install it and be done with it.
If you own a bigger than stock turbo and injectors, then bonus. If not, your $5k budget won't quite cover that and the shortblock with labor. It will be close. If you shop used and smart you might pull it off.
Old 09-02-2008, 05:06 PM   #12
lllvietnaml
Member#: 142620
2001 2.5 RS
yeah, $5K is not gonna get you SH^T....i call East Coast Swappers, and they told me. 6K for the motor, 13K for the full motor (trans, Harness,ECT.), and also labor...the total come to be like 19K.... i'd say your better off doing it yourself.
lllvietnaml is offline   Reply With Quote
Old 09-04-2008, 03:06 PM   #13
Rokkit
Member#: 84181
NASA #530 GTS2
I found an entire v.8 drivetrain with 30,000 KM on it for 6400 shipped...
i'm sure you could do something with 5k if you did most of the labor yourself.
Rokkit is offline   Reply With Quote
FS: OR 2000 2.5RS Coupe w/ USDM STi Motor Swap done by PDXTuning I3izzy Private Vehicle 'For Sale' Classifieds 58 12-28-2008 02:19 AM
FS: MY00 2.5RS Coupe w/ USDM STI motor swap done by PDXTuning I3izzy NWIC Private Classifieds 18 10-03-2008 08:42 PM
FS: 2000 2.5RS Coupe w/ USDM STi Motor swap done by PDXTuning I3izzy NWIC Private Classifieds 23 10-03-2008 08:42 PM
USDM Sti motor Swap, Random parts. Kingpin Engine/Power/Exhaust 26 09-27-2005 06:12 PM
Where can I get a EJ20 USDM Turbo Motor and Tranny for my 1.8? NewbyScooby Subaru Conversions 7 06-30-2003 07:03 PM
