Old 03-12-2002, 07:12 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default Shifter plate modification after short shifter installation (pics inside)
Ok all these threads about wether or not you need to modify the plate around the shifter assembly got me and dale (dbrier) to take some pics of out mod job so i thought i'd post them here
First we took a buzzsaw and cut off the upper right portion of the plate ring, then used a dremel tool to smooth out the rough edges so it wouldn't cut into the rubber boot seal
Here's just to illustrate the cut (we actually cut it out further to make more room for the shifter linkage):
Here's a pic of the rubber boot seal without the ring plate. I noticed driving around without the metal plate, a lot of underbody wind noise generates
Now putting the modified plate back on (notice we cut a little bit more from the plate):
Here's a pic of it installed on, and note where the rubber part is not covered by metal in the upper left corner, there is still a little seal leak here:
Just a closer shot of how the shifter linkage pushes up against the rubber seal with the short shifter:
Hope this helps!
Ed
edkwon is offline   Reply With Quote
Old 03-12-2002, 07:26 PM   #2
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
I did the same thing except I only cut out a traingular peice. So there was o hole left over. But if you have the Cobb it;s a must. My linkage has a groove from the plate hitting it.
Dolphin Overton is offline   Reply With Quote
Old 03-13-2002, 08:04 AM   #3
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
On mine, I didn't need to cut the corner out, the plate is completely symetrical so I just rotated it 180 degrees and cut off one of the metal tie downs.
Hope this helps.
JoeT is offline   Reply With Quote
Tranny whine after Short Shift Install? Jrags87 Newbies & FAQs 3 02-13-2009 04:06 PM
Kartboy short shifter on factory SPT short shifter stud100spray Newbies & FAQs 7 11-28-2007 04:03 AM
Want to trade WRX short shifter for my Subydude short shifter Sti"izzle" Private 'Wanted' Classifieds 0 09-24-2006 11:21 PM
Mis-Fire after short block install!! evo8asti Built Motor Discussion 9 06-22-2006 12:28 AM
Plate around shifter, when installing short shifter DeusExMachina Normally Aspirated Powertrain 6 03-10-2002 11:18 PM
