Old 08-25-2008, 03:38 AM   #1
3barboost
Member#: 73609
2002 wrx
Default Lets talk AVCS clearance on a stroker
I need some help understanding this in my head
take an 81mm stroke - at BDC the piston is 2mm further down the bore and at TDC 2mm further up the bore
What happens to AVCS clearance ?
Am i right in thinking that what would apply to std stroke (79mm) is no longer valid with 81mm stroke ? (thinking out loud here really)
This is on cosworth 81mm stroker / with cosworth cams in278/ex274 so 10.7mm lift, our cams are slightly different to usa spec (qty of lobes at rear of cam, and in avcs cam pulley)
my feel is no vvt at all ? does anyone have direct experience on this ?
3barboost is offline   Reply With Quote
Old 08-25-2008, 04:27 AM   #2
bugeyes
Member#: 64494
2001 V7 sti
81mm stroke = 1mm further up and 1mm further down.......not 2.
With such a small change to stroke I dont think it would make any significant difference to the clearances. They may be fractionally less but its probably a question to put to Cosworth as they would know exactly what profile they are running on their cams.
bugeyes is offline   Reply With Quote
Old 08-25-2008, 10:24 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
with a stroker, you actually will have a little more time to hang the valve open then compared to a long rod setup...a stroker spends less time at TDC.
though for that stroke change, it really is minimal.
Regardless, it a an application specific call...it will depend on several variables specific to YOUR motor and components...cosworth should be able to tell you.
Let's talk AVCS tuning.....anyone...? bboy Engine Management & Tuning 678 11-24-2012 09:37 PM
Lets talk wet kits... N2o nmyeti Factory 2.0L Turbo Powertrain 2 09-02-2001 10:00 PM
Lets talk wheel size 17s or 18s ACT Brakes, Steering & Suspension 6 04-02-2001 03:22 PM
"tri state" Forum is up! Anyone close to NY/NJ, Lets talk!:) Keith General Forum Archive 0 01-10-2001 10:37 AM
Message Board Statistics All times are GMT -4. The time now is 10:40 PM.
