Old 04-25-2001, 02:35 PM   #1
^jynx^
Member#: 1787
Question power of the WRX before turbo spools
not sure what forum to post this in because its a WRX question(but technical) it is a NA power <Q>(but for a turbo motor)
and i am sure this has been discused before but toi be honest with you i am just to damn lazy to search.
But what is the power of the ej20 BEFORE the turbo spools up?
^jynx^ is offline   Reply With Quote
Old 04-25-2001, 04:30 PM   #2
Chirik
Member#: 5320
2002 WRX Wagon
WR Blue Pearl
Post
Before the turbo spools?
Pathetic. ;-)
No power at all under 2000rpms, low from 2000-2500, decent from 2500-3000, and then *woosh* ;-)
But don't let it drop below 2000 rpms, or you'll bog.
Chirik is offline   Reply With Quote
Old 04-25-2001, 04:43 PM   #3
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
Post
power below when the turbo spools is just good for getting the clutch engaged, and for the parking lot manuvering.
If you keep the rev's around 2500-3000 you will keep the turbo spooled for the most part.
ChrisW is offline   Reply With Quote
Old 04-25-2001, 04:56 PM   #4
bignick
Member#: 5247
Post
i think he means how much horse does an ej20 have without turbo it most likely has less than a 2.5rs its a 2.0 liter say your turbo was worn out no boost what is its horsepower?me i think 130to 150hp
bignick is offline   Reply With Quote
Old 04-25-2001, 05:05 PM   #5
^jynx^
Member#: 1787
Post
yeah i want to know what you got if you took the turbo away
Old 04-25-2001, 05:15 PM   #6
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
Post
165 i think would be the same a RS, but im not sure
ninetalesnwf is offline   Reply With Quote
Old 04-25-2001, 05:20 PM   #7
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
that's a scary thought...low compression, small displacement motor
Strepto is offline   Reply With Quote
Old 04-25-2001, 06:00 PM   #8
dougwendel
Member#: 4213
Post
It can't be 165 - that's the rating on the EJ25. Probably more like 130-140. I actually like having a more sedate motor at low RPM. It makes stop-and-go traffic much easier to navigate.
dougwendel is offline   Reply With Quote
Old 04-25-2001, 06:16 PM   #9
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
Post
no no, I am sure it's much lower than that.
the RS uses a EJ25 with decently high compression..
the WRX is on the EJ20 with low compression..
so pre-spool up it's making LAME horsepower..
I'd venture to say in the realm of 100 or so..
Fish is offline   Reply With Quote
Old 04-25-2001, 07:28 PM   #10
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
If it could rev to 6000 without boost a low compression 2.0L might make 100-110 HP. But you're talking about 1500-3000 RPM. At that low RPM--off boost--it probably only makes 40-50 HP.
Edit: looking at Cobb's stock RS dyno chart, the high compression 2.5 is making just under 50 wheel HP at 3000 RPM. That's maybe 60-65 HP at the crank, so 40 or so sounds about right for the 2.0.
[This message has been edited by Jon Bogert (edited April 25, 2001).]
Jon Bogert is offline   Reply With Quote
Old 04-25-2001, 08:51 PM   #11
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
The WRX is at least as much slower than the RS below 3k as is faster above 3k. So yes, .5l less displacement and less compression make for slow going if you dont spool quickly.
Midwayman is offline   Reply With Quote
Old 04-25-2001, 11:39 PM   #12
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
Post
EJ20 without tubro would be around 100-115 MAX, no way it can reach 140-150 range.
sti2_5rs is offline   Reply With Quote
Old 04-26-2001, 04:29 PM   #13
pottsie350
Member#: 6110
98 Impreza L
Red
I agree 100 hp or so max. You could always put higher compression pistons in it. But the cam is probably milder than a high compression engines cam...
pottsie350 is offline   Reply With Quote
Old 04-26-2001, 06:02 PM   #14
SubEd
Member#: 717
Wink
Who cares? What a worthless point..."if you take away the turbo, what's left?"...
Hypothetically, you don't have much...but
Who cares??? Have you experienced the boost yet?
Ed
[This message has been edited by SubEd (edited April 26, 2001).]
SubEd is offline   Reply With Quote
Old 04-26-2001, 08:39 PM   #15
Gambit
Member#: 102
Post
I agree with SubEd. Who cares. It has a turbo. So use that darn glorified hairdryer!!
On a serious note, off boost with a 2.0l small compression motor, it's really slow. And it's on a car weighing 3085lb dry weight too!
Sure makes one wonder how does the ppl in other countries putt putt around with their 1.8l new age Impreza which weighs so heavy.
Gambit is offline   Reply With Quote
Old 04-26-2001, 08:49 PM   #16
Andy_T
Member#: 502
Post
Here's an idea - go and research Subaru's other engines. They make the EJ20 in non-turbo format with a slightly higher compression ratio. It makes 125 bhp at 5600 rpm, which you would expect given that the 2.5 makes 160 or so (166 in NA, 156 elsewhere).
Of course, the turbomotor would have lower compression, so if you took it away it would make less. But this a purely academic point, akin to asking "how fast does a V8 go if you tried unplugging 4 HT leads to save on gas?"
Andy_T is offline   Reply With Quote
looking for the 12 mph turbo spool thread aaaacccc Off-Topic 29 12-21-2011 10:22 AM
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
I come in the name of jesus, by the power of the holy spirit!!! MrSaabaru Off-Topic 5 07-10-2006 09:23 PM
Last pics of the SVX before winter (most likely) *56k die* Bwana Member's Car Gallery 33 01-08-2005 04:15 PM
