Old 08-27-2008, 09:24 PM   #1
XmikeX
Member#: 184768
05 WRX
toasted white
Default trouble getting into reverse
its hard to get my car into reverse. is this transmission trouble clutch problems or just semi normal??(dont think so) i can get it in but sometimesi jsut got to let the clutch out again and try to put it in
XmikeX is offline   Reply With Quote
Old 08-27-2008, 09:51 PM   #2
mattwho
Member#: 156202
02 WRX sedan
Completely normal.
mattwho is offline   Reply With Quote
Old 08-27-2008, 10:09 PM   #3
go0sebumpz
Member#: 147521
03 WRX swaggonn
if you're having trouble getting into reverse, go forward a little and put it back into reverse easily. this is completely normal for many of us owners' specifically on wrx's i believe.
go0sebumpz is offline   Reply With Quote
Old 08-27-2008, 10:56 PM   #4
XmikeX
Member#: 184768
05 WRX
toasted white
OMG im stoked i thought that my tranny was screwed up or something and i jsut bought the car. yah it goes in easy if i roll back a little or go forward.
thanks alot guys eased my mind
Old 08-29-2008, 07:09 AM   #5
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
also, try throwing it in 4th and then into reverse. always works for me
evan_impreza is offline   Reply With Quote
Old 08-29-2008, 12:31 PM   #6
my scoop eats babies
Member#: 174894
A much easier solution:
As you're trying to push it into reverse, put a little pressure on the shifter and slowly let off the clutch. Just before you hit your friction point, it will slide into reverse like butter every single time.
my scoop eats babies is offline   Reply With Quote
Old 08-29-2008, 05:33 PM   #7
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default reverse
i double clutch every shift . do some more reading on your tranny you will see it has issues
watchunglava is offline   Reply With Quote
Old 08-31-2008, 09:11 AM   #8
brandonswrx
Member#: 186194
04 PSM STI
:Agile Tuned 391hp/387tq:
^^+1 yes it has many issues.
brandonswrx is offline   Reply With Quote
trouble getting into reverse SkatmanWRX Transmission (AT/MT) & Driveline 1 05-31-2010 03:44 PM
HELP; trouble getting into Reverse and 5th gear amye66 Transmission (AT/MT) & Driveline 4 01-20-2006 01:13 PM
To all of you out there that are having trouble getting into reverse. Sublime5260 Transmission (AT/MT) & Driveline 5 12-15-2002 01:38 AM
Trouble getting into reverse tomrichardson Normally Aspirated Powertrain 15 11-02-2000 09:49 AM
