Old 08-28-2008, 12:23 AM   #1
chav2531
Member#: 187998
1997 Impreza
GREEN
Unhappy Code P0440 Evap.emission System
I bought the car a couple of weeks ago car came from Vermont 1997 Impreza awd 5-speed 130K new trans. 6 months ago there is a stack of reciepts of parts replaced Only two owners which were both ladies. I paid $1600 for it what do you think?
Just like the title says ive been dealing with this code from hell. I have tried to get it registered and all but fails deq emissions. Everything is ready except evap. it says "NOT READY" the car does have some rust here and there. I replaced gas cap cycled it and CEL comes back smoke tested it and no leaks i replaced purge control solenoid and CEL still comes back. Everytime i clear CEL i drive it for about 2-3 days and it will pop up on the HWY. It only comes when it gets below half tank. my tags are now 3 weeks expired and school is around the corner what else should i do??? change filler neck? any other solenoids to check? please help thanks
chav2531 is offline   Reply With Quote
Old 08-28-2008, 01:07 PM   #2
gathermewool
Member#: 143624
'08 STI
SSM
Originally Posted by chav2531 View Post
I bought a 1997 Impreza with 130k for $1600. The transmission is new as of 6 months ago, and it came with a stack of maintenance receipts from the two previous owners. Seems like a good deal, eh comrades?
The problem:
I have been dealing with a P0440 code, and it won't pass emissions. I've replaced the gas cap, smoke tested it with no visible leaks and have also replaced the purge control solenoid, but he CEL comes back after 2-3 days after I clear it. It only seems to come on when th tank is less than half full. My tags are three weeks past expired, and I'm not sure what to do next. Could it be the filler neck? Please help. Thanks
Fixed. What you typed took me forever to read.
gathermewool is offline   Reply With Quote
Old 08-28-2008, 01:18 PM   #3
chav2531
Member#: 187998
1997 Impreza
GREEN
Thanks bud! I was just so disapointed yesterday with my car, that my head wasn't thinking right.
Old 08-28-2008, 08:12 PM   #4
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Yeah, it could be the filler neck. Look at it with a flashlight through the opening. If you see any rust at all, you have a winner (loser). Why this didn't surface in a smoke test I don't know. I never smoke tested the Forester when the code popped up, because I saw the rust and just knew. I replaced the gas cap first just to be sure though.
The plastic cover in the wheel well traps moisture and various cruds, rusting the crap out of your filler neck.
surowrxa is offline   Reply With Quote
Old 08-28-2008, 09:05 PM   #5
chav2531
Member#: 187998
1997 Impreza
GREEN
Whoooa i just finished replacing the filler neck and other corroded tubes around the vapor canister. The filler neck was rusted out! Im going to delete the code and see if it comes back! When you changed the filler neck and gas cap did the code go away?
Old 08-28-2008, 09:27 PM   #6
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The code has to be reset. One way you can do this on your own is to disconnect the battery for a few minutes. If the light comes back, you have another problem.
RexyGirl is offline   Reply With Quote
Old 08-29-2008, 01:40 AM   #7
chav2531
Member#: 187998
1997 Impreza
GREEN
is reseting the code that way, the same way as getting a diagnostic scanner and erasing the code?
Old 08-29-2008, 05:04 AM   #8
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Yep. You'll have to drive around a couple days (couple hundred miles or so) before the emissions system will read "ready" for your inspection.
Old 08-29-2008, 07:58 PM   #9
RexyGirl
Member#: 63616
with mods :)
Oh yeah, forgot about that part...we don't have emissions in FL
If the light does come back on, let us know what the code is and we'll help if we can.
Old 08-30-2008, 01:17 PM   #10
chav2531
Member#: 187998
1997 Impreza
GREEN
After driving it for 3 days the light came back on.. I dont know what else can be the problem. Do the speed sensors have anything to do with it no being"ready"?
Old 08-30-2008, 01:55 PM   #11
RexyGirl
Member#: 63616
with mods :)
You need to get the code pulled again and post back what it is.
Old 08-30-2008, 02:10 PM   #12
chav2531
Member#: 187998
1997 Impreza
GREEN
P0440 Evaporative Emission system Malfunction
when the CEL turned on for the very first time, which was about a month ago there were two more codes which were
P0500 - Vehicle speed sensor malfunction
P1540 Manufacturer Specific Code
WHen i took it to a suabru mechanic the first time he just erased them all and the only one that comes back is P0440. The only solenoid i have changed is the purge control solenoid.. which other ones should i also look at?
Old 08-30-2008, 02:23 PM   #13
chav2531
Member#: 187998
1997 Impreza
GREEN
OH and one more thing the very first time i took it to DEQ the Evaporative was "ready", but it failed because it had 3 codes. The last couple of times i took it to the DEQ it read evaportative "Unready" but there were no codes
Old 08-30-2008, 04:06 PM   #14
chav2531
Member#: 187998
1997 Impreza
GREEN
I just checked two other solenoids. I connected the blue plugs under the steering column to see if the solenoids were operating and the canister valve ventilator next to the vapor canister box was NOT operating, it wasnt making any noise, is that normal? I also checked the solenoid for canister purge. I was able to blow air right through the two vacume lines is this solenoid suppose to be closed when out of the car, just like the purge control solenoid?
Old 08-31-2008, 02:41 PM   #15
chav2531
Member#: 187998
1997 Impreza
GREEN
anyone help please???
Old 08-31-2008, 04:14 PM   #16
RexyGirl
Member#: 63616
with mods :)
Do you have a raw fuel smell at all?
PM me your email address and I will send you some troubleshooting tips.
Old 09-24-2008, 06:28 PM   #17
Not-EWRX
Member#: 158043
old Something new
Update??? I have this same problem
Not-EWRX is offline   Reply With Quote
Old 09-25-2008, 02:17 PM   #18
subaruNV
Member#: 154549
2006 DOM 3 Powered
WHITE/ EQ Tuned 350Whp
I to have the same problem but I don't get a check engine light on my 06 Wrx so I didn't no it wasn't going to pass untill the day it got tested
subaruNV is offline   Reply With Quote
Old 11-20-2008, 01:11 PM   #19
Boudreau
Member#: 163846
2002 wrx
I am having the same problem, 2002 wrx..
Boudreau is offline   Reply With Quote
Old 12-11-2008, 12:04 PM   #20
tdeuce82
Member#: 197219
i'm having the same issue with an 00 RS. my car idles rough tho, too.
tdeuce82 is offline   Reply With Quote
Old 06-15-2009, 02:22 PM   #21
Brisky
Member#: 148078
1993 Legacy L AWD
Did we find out how to fix the problem?
Bad solenoid?
Brisky is offline   Reply With Quote
Old 02-09-2010, 08:58 PM   #22
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
I am bumping this for answers.
I just bought a beater 99 Legacy wagon and it has the P0420/P0440 codes.
I am not worried about the 420, I can fix that one, but I have no idea what the 440 is. I think in 15 years dealing with cars I have never ran into that one before.
I'll be pulling the motor for a reseal/tune up this weekend. I'll check the gas filler tube, but I haven't noticed any fuel smells. When the tube rotted out on my 98 wagon I smelled fuel.
iluvdrt is offline   Reply With Quote
Old 02-21-2010, 11:54 AM   #23
93egsi
Member#: 142653
bump b/c i have a 2001 impreza L wagon with a p0440 code,i changed gas cap but came back few weeks later, how do i check/replace filler tube? do you have to take rear bumper off?
heeeelp!
93egsi is offline   Reply With Quote
CEL code P0457: Evaporative Emission Control System Leak Detected (fuel cap) aznfoos Factory 2.0L Turbo Powertrain 16 09-12-2012 01:09 AM
Got CEL code 440, Emission System Control Evan J. Kelly Normally Aspirated Powertrain 14 11-27-2008 11:58 AM
Code P0440 Evap. Emissions System Malfuntion chav2531 Newbies & FAQs 1 08-28-2008 02:23 AM
Code P0442, Evap system? ascott Factory 2.0L Turbo Powertrain 3 05-26-2003 12:41 PM
Check engine code P1443: Evaporative emission control system vent control function? garface Normally Aspirated Powertrain 7 11-20-2002 06:53 PM
Message Board Statistics All times are GMT -4. The time now is 10:38 PM.
