Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 08-28-2008, 12:31 PM   #1
masterpickle
Member#: 147536
1996 Impreza
Green
Default Engine "stutters" at high rpm and after corners? Help please
So I have a 02 WRX with 74k. When Im at high rpm like 5k or 6k (mostly in third gear I think) my car will "stutter." It basically would be like if gas just stopped getting sent to my engine. That's what it feels like anyways. It also happens when I take a corner to sharply. Not during the corner but 45 seconds or a minute after the car just doesn't do anything. No gas pedal it just coast it's way down to idle. The car doesn't stall tho.
As far as I know it isn't my fuel pump because they either work or they dont work. I just changed my oil and my fuel filter (it was happening before I changed my oil and fuel filter as well) so it's not that but I don't know why it would be. I'm changeing my spark plugs the NKG iridium this weekend to see if that help and I thought I would check to see if my injectors might be clogged when I change my plugs. Other than that I have no idea what it could be.
Can you guys think of anything?
masterpickle is offline   Reply With Quote
Old 08-29-2008, 12:43 AM   #2
masterpickle
Member#: 147536
1996 Impreza
Green
bump for some help
Old 08-29-2008, 02:02 AM   #3
WRXislander
Member#: 50064
'02 WRX
MBP
Auto-cross guys have this same complaint when thier fuel tanks are too low. Could this be this case for you?
WRXislander is offline   Reply With Quote
Old 08-29-2008, 02:37 AM   #4
jymy04sti
Member#: 174216
2004 Impreza WRX STi
Check all your sensors, like the oxygen sensors. stuff like that might be a problem too. mine did something like that, then my dealership replaced one of my O2 sensors and my MAF sensor and it's been running like a champ ever since.
jymy04sti is offline   Reply With Quote
Old 08-29-2008, 02:58 AM   #5
fastlanerex
Member#: 133391
2004 boosted saleen
white
i would fill up your gas tank. if you have any cel pull the codes and post em up, and change spark plugs see if that fixes your problem.
fastlanerex is offline   Reply With Quote
Old 08-29-2008, 03:32 AM   #6
fastwrx25
Member#: 126441
03 bugeye
my bet on the plugs if they've never been changed
fastwrx25 is offline   Reply With Quote
Old 08-29-2008, 03:14 PM   #7
masterpickle
Member#: 147536
1996 Impreza
Green
As far as i can remember it happens when my tank if full as well. I don't have any cel's right not but i can check my maf and O2 sensor any ways. I know where they are but how do I check to see if they are working properly?
Thanks
Old 08-29-2008, 03:40 PM   #8
ILEJ20
Member#: 84085
2005 92xAero
I don't think plugs are an issue. It sounds fuel related, but did you say it happens 45 seconds after you make a hard turn?
I don't know what would take that long to cause an issue. Unless the pump didn't get enough gas as you were turning and it cause a little air pocket in the lines and the fuel in the lines runs out a few seconds after the turn is made causing a stutter for a second or 2.
ILEJ20 is offline   Reply With Quote
Old 08-29-2008, 04:17 PM   #9
masterpickle
Member#: 147536
1996 Impreza
Green
it's around 45 seconds. I haven't times it or anything it just isn't happening during the corner it's after I'm out of the corner and driving straight again.
As for the air bubble int eh line that's a possibility but if that was the case then wouldn't my engine just stall? Because it continues to run. It's basically the equivalent of putting the clutch but i can't increase the amount of gas going to the engine.
Old 08-29-2008, 04:23 PM   #10
smurfwrx
Member#: 151928
09 Triumph S3
shot in the dark, but grounding mod?
http://forums.nasioc.com/forums/showthread.php?t=156303
smurfwrx is offline   Reply With Quote
Old 08-29-2008, 05:05 PM   #11
WRXislander
Member#: 50064
'02 WRX
MBP
I didn't catch the 45 second part. If it was a low gas tank level then the power loss would happen immediately. It just happened to me today in fact. The gas light was on and I floored it from a stop while taking a right turn. The tires spun in first, I brought it up to 6500, shifted into second, it got up to about 4k, and bam power loss for about 1/2 a second like no fuel was getting to the injectors.
What's happening to you is clearly different. I'll have to think about it some more.
Old 08-30-2008, 03:04 AM   #12
masterpickle
Member#: 147536
1996 Impreza
Green
ok let me know if u think of anything
Old 08-31-2008, 12:50 AM   #13
masterpickle
Member#: 147536
1996 Impreza
Green
So i put some more gas in my car just to make sure it was the low fuel thing and I only tried it once but it didn't seem to stutter around corners this time. If that is the problem is there any way to fix it. I still had a 1/4 tank left and i don't want to have to worry about taking corners to sharp if i have less than half a tank.
Old 08-31-2008, 11:39 AM   #14
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
I was running into the same problem going around the clover leafs on and off the highway in my '02 WRX swapped GF. It was a delayed stutter/hesitation. It was well after I had finished the turn and was merging in traffic. I also felt it while on the track last weekend. I was ripping down the straight but not flooring it (it was the yellow lap so I wasn't going all out). 4th gear 1/2 throttle I think. I just felt a little hesitation. Like a misfire or soft fuel cut. Then normal from there on out. Again, well past the corner and plenty of gas.
The last time getting on the highway I had a full tank of gas. And I did replace my plugs b4 the track day. I am going to get this:
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=011
Since I have the older '96 gas tank there are less baffles and this OEM sock "surround" should help with the slop.
byroll01 is offline   Reply With Quote
Old 08-31-2008, 12:00 PM   #15
jeremywrx15554
Member#: 168567
2003 big 16g coming
fixing my 03 wrx
here is another option i could be a stopped up catylic converter.i had the promblem not on my wrx but on my nissan maxima se and i would be driving at about 60mph and around 4000 rpm and my tach would go back in fourth from 4000 to 7000 and it turned and it turned out to be a stopped up catylic convereter.i am not saying that is what it is but i kind of sounds like it.
jeremywrx15554 is offline   Reply With Quote
Old 08-31-2008, 02:23 PM   #16
masterpickle
Member#: 147536
1996 Impreza
Green
well i want to get ride of my cat anyways with a down pipe.
Let me know if the sti fuel pump solves the problem. If so I will definitely
be getting one too.
Old 08-31-2008, 02:30 PM   #17
ckb1985
Member#: 131057
2002 Wrx Sedan
Midnight Black Pearl
sounds like the same problem I was having recently on my car an 02 with 120k on the clock... I put a fuel pump in which was cheam 90 bucks for a walbro and bingo bango no more fuel issues on corners or high rps... Give it a try pumps only 90 bucks dont listen to these guys.
ckb1985 is offline   Reply With Quote
Old 08-31-2008, 11:39 PM   #18
WRXislander
Member#: 50064
'02 WRX
MBP
Naw. I'm running a Walbro and I just had this happen yesterday.
Old 09-01-2008, 07:16 AM   #19
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
pull off your fuel socks and clean them well with carb cleaner and compresseed air.
the sock is the first fuel filter and is mounted to the bottom of the fuel pump.
Old 09-01-2008, 09:06 AM   #20
WRXislander
Member#: 50064
'02 WRX
MBP
(inside the fuel tank)
Old 09-01-2008, 11:45 AM   #21
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
be getting one too.
I'm fully catless and I already replaced my pump with my old STi pump I had laying around the cellar. FWIW it had the exact same part number as the WRX pump I took out.
I'm installing the STi fuel pump assembly so I can add the little surge tank subaru started using. I'm pretty positive my problem isn't the fuel pump. I am going to add a grounding kit just for the heck of it.
Old 09-02-2008, 02:17 AM   #22
masterpickle
Member#: 147536
1996 Impreza
Green
so the sti pump is the same as the wrx pump? Good to know, thats save me some money.
And about cleaning the fuel socks how do i get to them and the gas tank. Im not sure.
Old 09-02-2008, 11:10 AM   #23
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
pulling the FP and the sock is done from the trunk but it's way easier to pull your back seat and do it from there. It's an oval cover about the size of a 6x9 speaker. It's also a little easier if your tank is only 1/4 full.
Old 09-02-2008, 01:30 PM   #24
masterpickle
Member#: 147536
1996 Impreza
Green
ok so under my back seats. Ill do it. Thanks
Old 09-02-2008, 02:13 PM   #25
byroll01
Member#: 611
'05 E55 AMG
GetADomTune.com
actually behind the pass. side back seat. front edge of trunk.
engine hesitates at high rpm tsukuba speed Factory 2.0L Turbo Powertrain 9 12-24-2007 05:36 AM
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 04:37 PM
chek engine light at high rpm bigislandracing Off-Topic 18 07-19-2007 07:22 PM
Check engine light and cruise blinking at high rpm.. ORACLESTI Factory 2.5L Turbo Powertrain 22 09-25-2006 10:19 PM
Engine sputter at high RPM? kenithzs Normally Aspirated Powertrain 4 06-29-2006 06:40 PM
