Old 08-28-2008, 02:07 PM   #1
drftwell
Member#: 182244
Default 04 6 speed swap into 02 Wrx with Sti swap
Yeah I'm doing the full swap and I was just wondering if there were any other brake setups I could use instead of the brembos? My conversion didn't come with them and I'm kinda looking for a cheaper temporary route..... Any ideas?
drftwell is offline   Reply With Quote
Old 08-29-2008, 07:24 PM   #2
drftwell
Member#: 182244
Anyone have any clue?
Old 08-29-2008, 11:53 PM   #3
Web Foot STi
Member#: 39086
2004 STi
Up front you can use your stock WRX brakes. The '04 STi uses the same front hubs as all of the other non '05-'07 STi's.
What did you use for a rear diff? R160, or R180?
If you used the R160 then your stock rear brakes will work.
Web Foot STi is offline   Reply With Quote
Old 08-30-2008, 10:30 AM   #4
drftwell
Member#: 182244
Na don't wanna screw the center differential so I'm going r180.... I didn't think you could use the r160 due to the gear ratio differences? Know anyone who has done this before?
Old 08-30-2008, 10:33 AM   #5
drftwell
Member#: 182244
This is in an 02 Wrx so is the front the same?
Old 08-30-2008, 11:21 AM   #6
Web Foot STi
Member#: 39086
2004 STi
Just what I've been reading over the last 5 years. The R160 requires some semi custom driveshaft work, and as you said you have to pay attention to the driveline ratios. A R180/WRX brakes requires semi custom axles. Using all stock parts, I think, you have to use the STi rear brembo package.
There maybe another option that I missed.
Old 08-30-2008, 12:56 PM   #7
Chi_San
Member#: 53558
2002 WRX Wagon
Do Brembo rears and other, non brembo 4 pot fronts?
Chi_San is offline   Reply With Quote
Old 08-30-2008, 04:15 PM   #8
Web Foot STi
Member#: 39086
2004 STi
The OP was asking if there were any cheaper, temporary options for brakes. For the front's there are many options. I don't know about the rear's.
Here is an interesting thread though:
http://www.clubwrx.net/forums/suspen...talk-bbks.html
Old 08-30-2008, 04:36 PM   #9
MasterKwan
Member#: 98961
2003 WRX
I have the DSS conversion axles and don't like them. I'm working toward a 5x114 swap. I'm hoping to use my current LGT front brakes by using Tribeca rotors (5x114). I'm not sure what to do in the back. It depends on whether I can swap backing plates or not.
Old 08-30-2008, 04:46 PM   #10
dunk
Member#: 15359
Are you looking for better wheel options? I thought you already had the upgraded bearing with your six gun hub conversion.
Duncan
dunk is offline   Reply With Quote
Old 09-03-2008, 10:22 PM   #11
drftwell
Member#: 182244
I'm looking for an alternative to the rear brembos... 04 tranny Sti 6mt
Old 09-03-2008, 10:54 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Custom driveshaft work? I swapped a car and use the six speed with stock front brakes, rear brakes and an r160...
Old 09-04-2008, 07:22 AM   #13
Web Foot STi
Member#: 39086
2004 STi
Um, what drive shaft did you use to mate the 6 speed to the R160?
Old 09-04-2008, 05:12 PM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
Stock auto driveshaft. The 6 speed is essentially the same weight/height/width/length as a 4eat.
Old 09-04-2008, 09:02 PM   #15
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
^^ right, but you have to mod the gearing in the r160 to 3.90,
ot: i cant think of anything that is cheaper than a set of used rear brembos in your case, unless you do what everyone else is suggesting which is, find an atomatic driveshaft and making our old r160 diff 3.90 ratio instead of 3.54.
Alaskan EJ20 is offline   Reply With Quote
Old 09-04-2008, 09:04 PM   #16
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
yes the front hubs are the same.
Old 09-04-2008, 10:02 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
1. There are 6 speeds available in 3.54:1 and 3.9:1 flavors
2. No change to the rear differential is required if it already has a 3.9 ,,, I never said it was a 6 speed swap into a WRX
Old 09-05-2008, 11:21 AM   #18
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
06-07 wrx 2pots rear? i know kartboy makes an adapter to fit the 02-05 wrxs. you can get a bracket custom fabbed if you have access or know someone with a machine shop.
swift2fly is offline   Reply With Quote
Old 09-09-2008, 02:17 PM   #19
drftwell
Member#: 182244
Hmm...screw it lol rear brembos... My kit did come with rotors... Just no calipers! Where's a good place to buy em? Can't find anyone willing to part the set on here...
Old 09-09-2008, 04:01 PM   #20
DS1
Vendor
Member#: 111780
You can bolt 06-07 2 pots directly to the R180 hubs and use the gravel spec (290x18/190mm parking brake) rotors.
I can supply you with calipers and rotors if you need them.
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 09-09-2008, 05:40 PM   #21
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Where do you here that using a r160 will mess up the center diff? I think their are many people that did 6 speed swap that kept the R160.
talvai is offline   Reply With Quote
Old 09-09-2008, 05:58 PM   #22
Chi_San
Member#: 53558
2002 WRX Wagon
6 speeds use a 3.9 LSD front diff. No LSD R160 was offered, that I can think of off the top of my head. So, you have to do a ring/pinion swap, or use a non LSD rear diff.
I personally would just do a freaking ring and pinion swap.
Old 09-09-2008, 06:41 PM   #23
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Yea I know you need to change the rear diff to 3.9 But changing the ring and pinion everything should be ok because their all the same ratio correct? If you didn't have a 3.9 (ex. 3.7 or 4.44) then you would ruin the center and maybe front diff correct?
Old 09-09-2008, 07:08 PM   #24
DS1
Vendor
Member#: 111780
If you didn't use the correct ratio in the rear diff as your 6mt required you would damage the center diff.
-Dylan @ DS1
Old 09-10-2008, 04:08 PM   #25
ciper
Member#: 15543
90BJ Legacy LS ABS
There are an incredible number of r160 LSD available in ratios from 3.54:1, 3.8:1, 3.9:1, 4.11:1, 4.44:1 and a few odd ratios meant for Datsuns and such. I've personally touched/used the above mentioned ratio LSDs. Some of them were viscous, some clutch based and a couple even gear based.
Edit: Take a look at this random link I found using google and scroll down to the "Subaru R-160 Differential Part #s" section http://www.prosubaru.com/tech/axleid.htm
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx STiGuy23 Transmission (AT/MT) & Driveline 4 04-09-2010 01:03 AM
04 sti swap into 02 Wrx neversummer489 Subaru Conversions 19 01-20-2010 10:27 PM
04 sti full swap into 02 wrx sedan jobxiii Subaru Conversions 0 09-10-2007 09:51 AM
04 STi swap into 02 WRX overlord Subaru Conversions 6 06-09-2007 12:47 AM
what to do with DBW with 05 sti swap into 02 wrx? bustaman Subaru Conversions 7 11-16-2005 02:11 AM
