Old 08-28-2008, 06:00 PM   #1
silentt
Member#: 119995
2004 Outback XT
Peachy
Default STI swap, weird noises when throttle is applied?
Hey guys, I just finished my STI swap and had my key programmed today. I go to start it up and makes a weird sound, almost like it's gulping or something. After that, it idles perfectly, warms up perfectly, etc. Once I go to tip in the throttle, it makes a sound like it's gargling or something. It comes from both sides of the engine and only happens when I tap the throttle. Other than that and the same sound happening when the engine starts, it runs perfectly. No smoke, no smells, nothing. The sound comes from both sides of the engine bay. Not the middle, but both sides.. almost like the heads?
Any ideas?
silentt is offline   Reply With Quote
Old 08-28-2008, 06:17 PM   #2
silentt
Member#: 119995
2004 Outback XT
Peachy
Video:
Ignore the white smoke, it was just burning off whatever fluids seeped into the seals. It doesn't smoke anymore when it idles.
Old 08-28-2008, 06:39 PM   #3
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
get it tuned lol. u need to anyways. prob some wierd leaning out when u do a tip in because tip in is a tunable subject.
cquirki is offline   Reply With Quote
Old 08-28-2008, 06:41 PM   #4
RobK0000
Member#: 62230
that is probably the wierdest sound i have ever heard.
RobK0000 is offline   Reply With Quote
Old 08-28-2008, 06:42 PM   #5
RobK0000
Member#: 62230
Its like a valve is trying to open and its closing right away. wierd is all i got to say.
Old 08-28-2008, 06:46 PM   #6
silentt
Member#: 119995
2004 Outback XT
Peachy
Why do I need to get it tuned? It's a 100% stock STI drivetrain with matching ECU, immobilizer, key.
Yeah... It doesn't smoke at all or have any strange smells, no cross contamination of fluids, nothing. Idles fine then BOOM, strange noise with throttle.
Old 08-28-2008, 07:15 PM   #7
silentt
Member#: 119995
2004 Outback XT
Peachy
Idea: Possibly unseated spark plugs? It idles perfectly but under any kind of load it almost sounds like a misfire. I had a compression test done on the donor car and it's possible that the mechanic didn't re-tighten all the plugs and just lightly placed the coil pack on the plugs. I had to bolt in the coil plugs and they weren't easy to get in there.
Old 08-28-2008, 11:06 PM   #8
parkes
Member#: 166898
1994 T leg SS
ABM
So Chad you Get it Figured?
My car is waiting on Engine managment and Exhasut and i hope it Starts...
parkes is offline   Reply With Quote
Old 08-29-2008, 12:52 AM   #9
silentt
Member#: 119995
2004 Outback XT
Peachy
It was plugs.
Old 08-29-2008, 01:26 AM   #10
parkes
Member#: 166898
1994 T leg SS
ABM
Good to hear man, Simple easy fix
got done before me eh? hehe..
check out mine?
http://bbs.legacycentral.org/viewtopic.php?t=36494
Weird noise when throttle is applied? silentt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-28-2008 06:22 PM
weird noise when 2005 WRX is off scrawshaw Electrical & Lighting 3 03-20-2005 07:09 AM
Turbo Makes weird noise when boost is changed slayerh4x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-04-2004 02:44 PM
Weird noise when 1st is engaged? STIRS Newbies & FAQs 4 06-12-2003 06:31 PM
weird noise when heater is on mofoporn General Community 3 03-08-2002 10:56 PM
