Old 08-29-2008, 04:19 AM   #1
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
Default have boost problem with cobb stage 2 map or PDX maps
so i have checked everthing on my car and can't find what is stopping me from getting boost. the peak boost is about 11.5psi. there is no boost leak at all on my car. but after i took off the blitz electronic boost controller off my car and put on the stock boost solenoid back on reflash the car with cobb ap......it's not hitting target boost at all with stage 2 map or the PDX map i bought online. the PDX just give me like a 0.5-1 psi more then cobb's map. the PDX people said i would be hitting at about 18-22psi with their map. has anyone has the same problem can help me?
here is my list of mod
UR crank pulley
K&N typhoon short ram
HKS bov
HKS header
HKS up
stock turbo ported wastegate
Helix catless dp
Espelir full 3" catback
stock intercooler
Thanks,
Alvin
Please PM me if u know how to fix this problem.
alvinli217 is offline   Reply With Quote
Old 08-30-2008, 03:32 AM   #2
Defmxtones
Member#: 111527
2007 STi LTd
Urban Grey Metallic
did you ever change your pill?
Defmxtones is offline   Reply With Quote
Old 08-30-2008, 03:35 AM   #3
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
nope not at all, stock one
Old 09-01-2008, 01:02 AM   #4
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
anyone having the same boost problem and got it firgure out?
Old 09-01-2008, 10:51 PM   #5
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
anyone can give me ideas?
Old 09-02-2008, 01:50 AM   #6
Airboy
Member#: 72829
2006 WRX
2015 WRX
How much boost were you getting with the Blitz boost controller?
Airboy is online now   Reply With Quote
Old 09-03-2008, 04:10 AM   #7
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
i have tried making it to 1.1 bar of boost which is about 15.9 psi with no problem. but after i hooked up the stock solenoid back and flash the cobb PDX or cobb stage 2 ots maps, the max i get is 11.5psi now. and one more thing, i get a lot of turbo lag from the PDX map i am running now when my car starts in the morning when the engine is cold. after it warms up it's fine without turbo lag maybe a little.
Old 09-03-2008, 05:04 AM   #8
Nuke209
Member#: 108089
2003 WRX
NF Performance
It's probably that ported wastegate
Looks like they'll need to add some more WGDC for you to achieve the targeted boost.
Nuke209 is offline   Reply With Quote
Old 09-03-2008, 03:13 PM   #9
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
ok, thanks for letting me know.
Old 09-04-2008, 03:40 PM   #10
dap7298
Member#: 63594
2002 Wagon EJ207 v8
I ported my vf34 and had trouble hitting target boost on the vf34 base map. I first checked for boost leaks and when I didn't find any I tried the helper spring mod (9.5 lbs spring attached to the wastegate arm and the other end to the wastegate actuator). Worked like a champ. I'm hitting 16.9 lbs now.
dap7298 is offline   Reply With Quote
Old 09-05-2008, 02:27 AM   #11
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
i will give that a try, thanks you all guys!
Old 11-06-2008, 07:28 PM   #12
driftmotion
Member#: 163187
2007 STI Ltd *Sold*
BMW 135i
i've been having the same issue after putting my stock turbo back in ....... not able to go higher than 14 or so PSI ..... it's starting to annoy me!
driftmotion is offline   Reply With Quote
Old 11-07-2008, 06:09 PM   #13
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
bump anyone can help me and this guy here
i was thinking of running it with manual boost controller but don't know if that is good or bad with ap.
Old 11-10-2008, 04:06 AM   #14
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
anyone?
should i try running the stock intake box with k&n filter with cobb stage 2 map?
Old 11-17-2008, 08:49 AM   #15
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
any idea?
Old 11-28-2008, 02:57 AM   #16
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
anyone here have the same problem that could help me?
Old 11-28-2008, 11:16 PM   #17
borlarex88
Member#: 192628
2004 Subaru WRX
Java Black Pearl
anyone?
since cobb calls for either their intake or the stock intake, that might not hurt.
i was running too lean w/ a cel and switched back to the stock intake and its been fine since. different problem, but could have the same solution.
i will put my cai back on when i get a protune. until then, the stock intake is fine and should cause less problems.
borlarex88 is offline   Reply With Quote
Old 11-29-2008, 03:04 AM   #18
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
^thanks for the information, i will put the stock intake box in a few days once i am free. i will keep this updated. i am going the same root as u are......getting a protune for aps cai once i have the money LOL
Old 11-29-2008, 11:15 AM   #19
06stisilver
Member#: 141862
2006 Stage 2 STi
steel grey metallic
Not sure if you tried this or not but my car had a problem hitting target boost on the cobb stg 2 map, I called cobb and they said to try the high wastegate duty map and my car has been boosting fine since then.
06stisilver is offline   Reply With Quote
Old 12-01-2008, 12:22 PM   #20
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
^I have tried that with the K&N tyhoon short ram intake and it was the same.
i just changed the stock intake box with K&N drop in filter and it seems to run smoother than the PDX map with the short ram. if i don't hit targete boost, i will try the high wastegate duty map.
thanks for another reminder
Old 12-01-2008, 12:47 PM   #21
nme187
Member#: 117763
I would put the stock intake back on and reset the ECU. If your car is boosting 11psi which is mechanical wastegate pressure then something isn't right. Either with the mapping, mechanical problem or maybe your car is knocking like hell.
IF you checked for boost leaks and even a leak down test to make sure your motor is good then next step would check your wastegate actuator and make it's working properly.
nme187 is offline   Reply With Quote
Old 12-01-2008, 04:44 PM   #22
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
i have tried the stage 2 map and the stage 2 high wastegate map with the stock intake box. still not hitting target boost at all@_@ and the car is running a little bit lean.
this is driving me nuts!!!!!!!!!!!!!!!!!!!!!
Old 12-01-2008, 06:06 PM   #23
nme187
Member#: 117763
Have you tried uninstalling the AP from the car? That will tell you if it's the mapping with the AP or if it's mechanical. You hitting 11PSI is not good man, it sounds mechanical to me.
Old 12-04-2008, 02:59 PM   #24
alvinli217
Member#: 133236
2010 TR GTI
04 WRB STi-GONE
news update
about 1/2 throttle on third gear i am hitting about 1 bar(14.5psi) of boost, but once i WOT it drops to 0.6 bar(8.7psi)
boost question with cobb stage 2 soulsurfer91709 AccessPort 0 10-15-2009 07:33 PM
Manual Boost Controller with Cobb Stage 2? aakrusen Newbies & FAQs 5 05-06-2006 01:51 PM
Cobb Stage 2 91 or 93 Map in OR/WA jjimpreza North West Impreza Club Forum -- NWIC 28 04-25-2006 02:06 AM
Problems with Cobb Stage 2 Brakes mattesq Brakes, Steering & Suspension 8 02-03-2005 12:02 AM
will boost line mod be a problem with cobb stage 2 ecu? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-02-2003 12:49 AM
