Old 08-29-2008, 02:13 PM   #1
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Default EJ205 to EJ257
I'M PLANNING A SWAP FROM MY 02 WRX TO AN 05 STi I WAS WONDERING THE ADVANTAGES/DISADVANTAGES TO USING THE WRX HARNESS TO THE STi HARNESS AS IN POWER, LABOR, DIFFICULTY... JUST WHATEVER YOU HAVE I'D LIKE TO KNOW.
O YA I M PLANNING TO DO THE SWAP MYSELF TOO.
THANKS
bugeye-brawler is offline   Reply With Quote
Old 08-29-2008, 04:47 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
power is well worth the hassle of swaping out the harness, But it is not for the faint hearted lots of connectors n stuff should only take a weekend to do
sense of nature is offline   Reply With Quote
Old 08-29-2008, 05:47 PM   #3
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
It is pretty straight forward on the new cars. Unplug the old one and remove. Place new harness in, plug everything in. Maybe have to splice a few things and fire it up.
Older cars are much more difficult to swap.
Zephyr is offline   Reply With Quote
Old 09-02-2008, 11:28 AM   #4
bugeye-brawler
Member#: 182337
Sport -- White
awesome thanks... So run the STi ECU with the Harness
my shop told me there might be some people who make adapters for the WRX harness to fit the 5 pins on the STi ECU is there anything to that... i mean is it worth it or is it reliable do they even exists?
Old 09-02-2008, 01:44 PM   #5
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
I wouldn't bother with an adapter if you have access to the STi harness and ECU. Much more reliable just to swap out the parts that are supposed to be in there. Worth it in the long run to use the oem STi parts.
hail2theTheif is offline   Reply With Quote
Old 09-02-2008, 02:12 PM   #6
drftwell
Member#: 182244
02 Wrx to 04 Sti ... Do I need the gauge cluster?
drftwell is offline   Reply With Quote
Old 09-02-2008, 04:43 PM   #7
bugeye-brawler
Member#: 182337
Sport -- White
from what i've heard it depends on if you're doing the harness as well... if you're not converting the harness and ECU then no. but i'm pretty sure the dashes on the 04 are plug and play with the 02's anyways.
Old 09-03-2008, 07:16 PM   #8
drftwell
Member#: 182244
Yeah I was talking about a harness merge...but I don't think I'm going that route anymore...so if anyone needs an 04 Sti harness, engine and dash, dbw pedal and wiring, just give me a shout! Ill cut ya a deal...so my next question, how well is the stock Wrx ecu gonna like the ej257??? Tune it quick? Don't drive it till tune? ?
Old 09-04-2008, 12:25 AM   #9
bugeye-brawler
Member#: 182337
Sport -- White
for a harness merge you need an adapter so the four pins on the wrx ecu match up to your new sti ecu which has five
from my research don't or you can't run the wrx on the swap unless you change alot of info on the ecu instead get an adapter for your stock harness to fit into the STi ECU
Old 09-04-2008, 02:47 PM   #10
drftwell
Member#: 182244
Its 1475 from ecs
Old 10-09-2008, 01:22 AM   #11
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
Im seriously considering this same swap... so what exactly do i need to purchase if I'm buying an ej257 long block to swap into my 02?
ajohnson360 is offline   Reply With Quote
Old 10-11-2008, 06:41 PM   #12
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I have an 06 STi going into my 02. I was going to swap the harness, pedal and all that, but decided it would be much easier to just swap the manifold and get the car going. Maybe down the road when I have something else to drive back and forth to work I'll take the time and swap the harness in and get my AVCS back.
breathinez is offline   Reply With Quote
Old 10-16-2008, 02:47 PM   #13
bugeye-brawler
Member#: 182337
Sport -- White
read dummies guide to sti swap it has all the information you need depending on what route you go weither with harness swap or just the engine search and read it you'll find everything you need
Old 10-23-2008, 08:34 PM   #14
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
I need something to aid in the conversion from my 02 to this 04 motor and the mechanic says I need something else since my 02 was not electronic and the 04 is!!
driftwell, do you still have the pedal/throttle body wiring for the 04? LET ME KNOW!
Old 10-23-2008, 08:37 PM   #15
ajohnson360
Member#: 169086
2002 Impreza WRX
Maroon
Where do i find this "dummies guide to sti swap!!!???"
Old 10-23-2008, 08:57 PM   #16
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
i would just swap the long block and get it tuned.
mxpunk is offline   Reply With Quote
ej205 to ej257 Anup Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-31-2010 11:23 AM
FS: EJ205 block, EJ257 block, WRX Tranny gotawd MAIC Private Classifieds 0 07-22-2008 07:45 PM
EJ205 to EJ257 swap Tullin Built Motor Discussion 3 10-29-2007 08:07 PM
WTB: EJ205, EJ207, EJ257 Complete motor!! ASAP! dtmcnamara Private 'Wanted' Classifieds 5 07-15-2006 03:57 PM
ej205 to usdm ej257 awdhondakiller Subaru Conversions 9 07-20-2005 09:17 PM
