Old 08-30-2008, 05:59 PM   #1
timman_24
Member#: 58722
Default Standard USDM WRX 2.0L or 2.5L swapped into RS coupe
I used to own a 2003 WRX with a JDM STi V7 RA Spec C motor swap. I loved the car, but had to part with it due to work. It's been about 3 years and I am finally going to get back into the subaru scene. This time I have my eyes set on a RS coupe. I am going to get it and drive it as is over the winter and then start my swap. I don't want an extreme swap, just a lower budget one to give it some more balls.
With that in mind I am thinking about swapping in either a 2.0L USDM WRX motor or the newer 2.5L. I just don't know what the pricing would be on the motor. I know it should be significantly cheaper than a JDM motor, but I don't have a solid price. Also is the USDM WRX motor an easy swap to make? I can definitely do the mechanical stuff, I'm just wondering if the wiring is pretty much plug and play with a little work.
How much am I looking at for a standard WRX engine + supporting parts to get the swap done... if I do it my self. Thanks guys, I look forward to getting back into the game
timman_24 is offline   Reply With Quote
Old 08-30-2008, 10:36 PM   #2
sense of nature
Member#: 112759
02 Srp STi...
R ur Boltz to long????
Wiring is definitely not a little work , or plug n play, you could send the rs harness out to get it merged w/an existing wrx harness ,or do a complete swap, best bet is to source out a front clip of a wrx & swap the complete dash n stuff. prolly looking @ least 6k for a decent swap w/ parts , it's the little things that come up that nickel & dime you to death !
G/L
sense of nature is offline   Reply With Quote
Old 08-31-2008, 09:19 AM   #3
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
agreed
2.0 send the harness out
2.5 swap the dash (requires welding and cutting though)
also spend the winter fixing the other things like brakes/tires/suspension
should be able to do a 2.0 swap for 4k or less (2500+ incendentals)
Old 08-31-2008, 02:08 PM   #4
Siper2
Member#: 1134
2007 BMW 328xi wagon
If you decide to bring the car somewhere for the work, here's my list of installers:
http://www.rs25.com/forums/showthread.php?t=63515
Not all, but most of the ones who list themselves as Subaru "swap shops" are on there. You're in IL, so P&L Motorsports may be a top choice. They post here on NASIOC as well, search the membership. Same goes for DS1 Motorsports.
ECS is one of the best with wiring. They can do that portion for you, if you want to stick with the engine/mechanicals only:
http://www.eastcoastswappers.com/rates.php
Siper2 is offline   Reply With Quote
Old 08-31-2008, 02:46 PM   #5
timman_24
Member#: 58722
Thanks for the advice guys. I'm glad to hear it won't cost as much as I thought it would. I will most likely do the mechanical myself and send the wiring off to be done depending on what I feel like doing during the winter. I could actually do the wiring myself over winter and then do the actual swap in the summer.
Anyone have any good sources of front clips? That sounds like the best way to go.
Old 08-31-2008, 03:38 PM   #6
Siper2
Member#: 1134
www.garagetuning.com gets clips every so often. Email them and they may be able to find you something, I'm not sure really.
ECS' wiring-only merges are $975. Pricey to be sure, but for those lesser humans without the crazy ability to put together something so nice and neat, I'm sure it's wellllllllllll worth the price!!! They guarantee the work, too.
Old 09-01-2008, 09:59 AM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
no
you have to remove your rs harness and ship both harness off to be merged
2.0L or 2.5L what are the ups and downs thewannab2002 Newbies & FAQs 28 05-27-2010 12:18 AM
2.0L WRX swap into impreza coupe? whereismyscooby Subaru Conversions 5 08-28-2008 04:45 PM
Fully built 2.0L or 2.5 Sti short block? jifnjelly05 Built Motor Discussion 11 01-18-2007 11:06 AM
2.0L or 2.5L block, and also need '02 wagon rear spoiler cegpcola Private 'Wanted' Classifieds 4 12-26-2005 10:14 AM
jdm sti v8 2.0l or usdm 2.5l shortblock? WSSBOARD18 Factory 2.0L Turbo Powertrain 28 03-06-2005 03:48 PM
Message Board Statistics All times are GMT -4. The time now is 01:10 PM.
