Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 09-01-2008, 12:58 PM   #1
Built Industries
Vendor Sales Rating: (24)
Member#: 33839
Default Cosworth, APS, Manley, Cobb, Wiseco, BC, TurboXS and MORE! In stock at Slowboy.
Built Industries is offline
Old 09-01-2008, 12:59 PM   #2
Built Industries
Member#: 33839
COBB 512100 X 1
COBB 912240 X 2
TXS WS-TBE-TI-RP
BC-0601
BC-0602
BC-0621
BC-0622
Old 09-01-2008, 01:00 PM   #3
Built Industries
Member#: 33839
Bearings SB0006 x 2
Head Gaskets 20000922 x 2
Head Gasket 20000919 x 4
Head Gasket 20000916 x 2
Valves 20000166 x 5
Pistons PA2667 x 1 set of 4
Pistons 20003674 x 1 set of 4
Rings 20001516 x 1
Rings 20001515 x 2
Rods 14416-4 x 2
Valves 11137-8 x 1
Valves 11138-8 x 1
WRX 309937I22 x 1
SUB 287661I12 x 2
K588M925 x 1
K598M995 x 2
Old 09-01-2008, 01:02 PM   #4
Built Industries
Member#: 33839
Things that may not be on the shelf but I can get in a timely manner
SUB209917I22 -Subaru 2.5L TURBO US STI 8.5:1 Pistons 99.5mm Bore
SUB209937I22 -Subaru 2.5L TURBO US STI 8.5:1 Pistons 100mm Bore
SUB193642I16 -WRX 92.5 Bore 23mmPin 30.3/1.193Comp Height -16 Dish Volume 333g 8.0 to 1 CR
SUB287642I12 -WRX 92.5 Bore 23mmPin 32.7/1.287Comp Height -12 Dish Volume 348g 8.0 to 1 CR
SUB287661I12 -WRX 93 Bore 23mmPin 32.7/1.287Comp Height -12 Dish Volume 353g 8.0 to 1 CR
WRX209917I22 -STI 99.5 Bore 23mmPin 30.7Comp Height -22cc Dish 399g 8.5 to 1 CR
WRX209937I22 -Mahle WRX209937I22 STI 100.00mm Bore 8.5:1 CR
CRS5137S3D -Subaru WRX EJ18/20/22 H-Beam Rods w/ 3/8" ARP 2000 Rod Bolts 5.137" Length
K579M925 -Subaru Stroker 92.5mm Bore For sleeved Block Only
K602M975 -Wiseco Subaru Hybrid EJ22 Block w/ EJ25 DOHC Crank/Rods
Old 09-01-2008, 01:28 PM   #5
Member Sales Rating: (38)
Member#: 82064
2011 sti & evo ix
white
send me a price for the bearings and manley rods for sti
Ray@revitup is offline
Old 09-02-2008, 10:59 AM   #6
Built Industries
Member#: 33839
PM Sent!
Old 09-02-2008, 05:06 PM   #7
Mycues1982
Member Sales Rating: (56)
Member#: 86995
2005 Tacoma
price for Manley's Turbo Tuff I-Beam rods for an STi?
Mycues1982 is offline
Old 09-02-2008, 07:39 PM   #8
Built Industries
Member#: 33839
PM Sent!
Old 09-02-2008, 07:46 PM   #9
Built Industries
Member#: 33839
Looking for an inexpensive upgrade for your TMIC?
I have 2 of these Bulls-Eye Power TMIC's available for sale
$495 shipped while supplies last!
Just like any of their products, BullsEye has already put this product thru the ringer and always provides the results! Inputing air into the top mount at 350 degrees farenheit, outlet temperatures came out at under 100 degrees! Keep in mind that ambient air temps are usually 85 degrees. If your wonder about pressure drop, this top mount does as well and better than some of the big name models out there. BullsEye's testing showed that only a 1/2 pound of pressure drop was detected at 18 psi and monitored at outlet at 17.5 psi!
Installing this top mount is pretty easy, the only thing that doesn't just bolt right on is that you may have to trim down the top mount rubber skirting because this unit is 4.5 inches thick! Everything else is a simple bolt on, if you have hand tools, you can be on the road in under an hour enjoying ice cold intake temps! This top mount makes an unbelieveable difference on stock turbo's and IHI bolts on's and also SBR's 16G and 20G turbocharger lines!
Oliver
[email protected]
Old 09-03-2008, 10:21 PM   #11
Robbie_R
Member Sales Rating: (1)
Member#: 148110
2005 Legacy GT
Hey I'm looking for headgaskets for my Hybrid 2.5 build and ARP head bolts. Can I get a price shipped to Canada?
Robbie_R is offline
Old 09-04-2008, 07:49 PM   #12
Built Industries
Member#: 33839
PM Sent!
Old 09-04-2008, 07:55 PM   #13
Built Industries
Member#: 33839
Old 09-08-2008, 08:01 PM   #15
Built Industries
Member#: 33839
Need to keep your Air/Fuels in check?
I have your solution here.
Innovate DB Wideband Controller! available in RED or BLUE
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
I also have the AEM UEGO available as well!
PM me for the BEST pricing available!
Oliver
[email protected]
Old 09-10-2008, 02:25 PM   #17
Built Industries
Member#: 33839
FREE shipping on all APS inlet pipes in stock!
At last a true high performance turbocharger inlet pipe that actually is a pipe! Due to the tight and complex space available under the stock inlet manifold, these pipes have traditionally been available only as an aftermarket silicon hose.
The APS Turbocharger Inlet Pipe however is precision manufactured in stainless steel and the thin wall tubing (when compared to silicon hoses) delivers the maximum possible internal sectional area for the highest turbocharger air flow. In addition, the strong pipe walls completely solves the problems of hose collapse when under suction at high air flow rates.
Thanks
Oliver
[email protected]
Old 09-11-2008, 06:52 PM   #18
Built Industries
Member#: 33839
Today, I'm not going to ask you to buy anything. I'm not going to drop my pants on pricing to compete. I AM going to show you what sets us at Slowboy Racing apart from the rest and why we pride ourselves on our engines. We take block cores from all over the country in all different conditions and machine them all IN HOUSE for your order. There is no outside work done here, from the time your engine arrives until the time it leaves anything that needs to be done is done here.
Sorry about this one being sideways.....
Thank you for looking and I hope that we can continue to serve you with quality engines and performance parts for years to come.
Oliver
[email protected]
Old 09-12-2008, 03:36 PM   #19
Built Industries
Member#: 33839
So after my post yesterday braggin up my machine shop, I will put my money where my mouth is.
I have an EJ20 built and ready for you WRX! Internals are as follows:
Wiseco Pistons
Manley Rods
Cosworth Bearings
Now to the good stuff, Block pics!!! These I took this morning of the actual block being sold, as stated its a Manley/Wiseco EJ20 ready to go. This means it can ship the day you purchase. I only have ONE so dont delay!
(Link is for OEM EJ20, I don't have the Stage II on my site yet)
$2650 SHIPPED!!!! *NO CORE DUE*
Don't delay, at this price it won't last long!
Oliver
[email protected]
Old 09-15-2008, 05:20 PM   #20
Built Industries
Member#: 33839
Old 09-16-2008, 03:17 PM   #21
Built Industries
Member#: 33839
Suffering from bad head? Give your head the performance it deserves with my "Good Head" package! Everything you need for that freshen up or complete build. Packages like this normally retail for $622 plus shipping I am offering it for a limited time for $600 SHIPPED!!! With this you get the following:
BC Stainless Valves (STD size or 1mm over)
Ferrea Valve Locks
Ferrea Valve Seals
Brian Crower Springs and Titanium Retainers
All shipped to your door for a limited price of $600 SHIPPED!!!
"Wow!" you may be telling yourself "Thats a good deal" BUT THATS NOT ALL!!
If you act now I will add in a pair of BC Cams for a special LOW LOW price.
$570 for EJ20
$635 for EJ25
Hurry, supplies are limited!
Oliver
[email protected]
Old 09-17-2008, 02:01 PM   #22
Built Industries
Member#: 33839
We're dropping our pants for a hump-day special
04-07 STI AEM EMS I have one IN STOCK!! AEM is unsure of the date on the next production run so don't miss out on this one that can SHIP TODAY!
$1855 with FREE SHIPPING!
What you get:
AEM EMS:
AEM 3.5 Bar MAP Sensor:
AEM AIT Sensor:
  • Installs in minutes using plug & play technology- No wiring necessary
  • Since the EMS is designed to work with your specific car, it can be installed in minutes without the need to modify your vehicle in any way. You literally just unplug your factory ECU and replace it with the EMS.
  • Uses all factory sensors
  • Fuel table auto mapping
  • With AEM's new Fuel Auto mapping software, you can tune your engine in literally minutes! All you need is an accurate air fuel ratio input and then let the ECU do the rest. You have the ability to define the target A/F ratio at 357 different Load/RPM points as well as all the accuracy criteria. Auto mapping is included with every AEM EMS sold at no additional cost!
  • Base maps included
  • Base map wizard automatically creates a custom base map for your car
  • Live help window eases tuning process
  • Programmable traction control
  • On-board 512KB datalogger
  • (NO MORE LEAVING YOUR LAPTOP IN TO DATA LOG YOUR EMS!)
  • 10 cylinder sequential fuel injection
  • 16 general purpose outputs
  • 7 definable switch inputs
  • Electronic boost control
  • You don't need to buy a piggyback boost controller ever again! The one that is included with the EMS at no cost is state of the art. It can drive the factory or aftermarket boost solenoids and can work with all boost levels. It can run in open loop (MBC mode) or full feedback with a 357 point boost target table. Not enough? How about a cockpit boost target override switch or having the boost target defined by vehicle speed? The EMS can do it all.
  • Soft cut rev limiters
  • Utilizing user programmable stages, the EMS offers 5 distinct modes of rev limiter. With ignition retard, programmable partial cylinder cut of fuel and/or spark and full cut of fuel and/or spark, the combinations are limitless. No more harsh stock rev limiters that can hurt your engine! Two step launch control
  • Wet or dry nitrous control
  • Definable knock control
  • Full idle control (No more worries about big injectors)
  • Anti Lag (There is nothing cooler than a little bit of bang-bang!)
  • 4 EGT inputs with fuel control
  • 16/32 Hybrid high speed processor
Oliver
[email protected]
Old 09-17-2008, 03:25 PM   #23
9vapors
Member Sales Rating: (40)
Member#: 92582
pretty great deal on the valvetrain stuff.
9vapors is offline
Old 09-19-2008, 09:16 AM   #25
Rickyh
Member Sales Rating: (10)
Member#: 40453
700 miles on my stage 2 ej20 shortblock and all is well. Should be gettin tuned in a month or so. It doesn't burn oil and does not make a ton of noise. I couldn't be happier with it. It was packed so well that you probably could have dropped the crate off of a house and it would have been fine.
My only complaint was that I didn't get a hat or a sticker!
Rickyh is offline
Closed Thread
Whiteline, DBA, TurboXS, and More - Heavily Stocked! WeSellCarParts Vendor 'General Sale' Forum 50 04-02-2011 07:38 PM
Subaru Turbos In Stock At Slowboy!!! Built Industries Engine/Power/Exhaust 4 02-26-2007 09:24 AM
Perrin, Zerosports, K&N GT-Spec and more in stock! Z1 Performance Engine/Power/Exhaust 1 11-09-2006 04:24 PM
GREAT GIFTS! Prodrive Tshirts, Hats and more in stock now! AllSubaru.com Accessories & Misc 12 12-17-2004 11:54 AM
