Old 09-02-2008, 11:10 AM   #1
RallyDude87
Member#: 183022
2011 DGM WRX
Ninja Status
Default phase I ej25 block w/phase II heads
Has anyone installed phase II 2.5 heads(sohc) on a phase I block?have searched around,can't find any info,I have the parts laying around,trying to do it cheap for my brothers 2000 outback,I'm concerned with valve clearance problems.any info would be appreciated,thanks in advance
RallyDude87 is offline   Reply With Quote
Old 09-04-2008, 11:27 AM   #2
RallyDude87
Member#: 183022
2011 DGM WRX
Ninja Status
Well I finally got the motor together, turned it over by hand and everything seems fine. So installed the engine filled up all the fluids and it finally started it up to see what would happen. It's running like a champ now....wahoo
Old 09-19-2008, 01:51 PM   #3
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
did the phase 1 intake fit ?
sense of nature is offline   Reply With Quote
Old 09-25-2008, 01:43 AM   #4
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
No the phase I intake did not fit. What HG did you use?
~Josh~
Old 10-22-2009, 10:57 AM   #5
carzap
Member#: 227689
Default I am considering using a phase I block.
I have a 99 forester with a blown motor (Phase II). I also have a wrecked 98 legacy GT (Phase I) with a good motor. Is it possible to take to the Phase I block and use the forester (phase II) top end and other parts to get my forester going again? I was wondering what head gasket I should use. It seems that this is possible by reading the above posts. Is there anything else I should look out for?
carzap is offline   Reply With Quote
Old 10-22-2009, 11:40 PM   #6
jedz123
Member#: 67083
1993 Impreza L HB
EJ25D swap, 5-speed FWD
Phase 1 heads flow better then the SOHC Phase 2's. Match the head gaskets to the block your using.
jedz123 is offline   Reply With Quote
Old 10-23-2009, 08:25 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Absolutely. The thing to watch out for is the pistons come out of the deck slightly at TDC on the phase I block. Use headgaskets for the DOHC motor (correct thickness) and all will be well.
Jay
Phase I EJ25 swapped with Phase II 25 kerberos824 Subaru Conversions 4 02-25-2009 09:06 AM
anyone running phase 1 ej25 heads on phase 2 ej25 block ??? IllNastyImpreza Built Motor Discussion 7 05-04-2008 11:48 PM
1998 phase 1 EJ25 into 2000 phase 2 EJ22 OBS. s'ko Subaru Conversions 0 04-14-2008 12:20 PM
Crawford S2 EJ25 Block w/ Spec C Heads snowcrzy Engine/Power/Exhaust 10 02-24-2007 03:58 PM
Pauter Rods / JE 8.5 Pistons / EJ25 block / EJ25 Phase II block halves DoodieHead Private 'For Sale' Classifieds 3 08-05-2004 07:09 PM
