#2826 |
Member#: 315264
Vehicle:2012 WRX SWP |
i was looking at the ga3r and you can only get down to a +20 offset. are you going to be running spacers to make up for the extra 12mm? and i know people have molded them on 04-07s but i have never seen someone even put someon an 08+
#2827 |
Member#: 336644
NWIC
Vehicle:2004 WRX Aspen White |
When its there's too much ice or too much snow. I've always got my Blizzaks
#2828 |
Member#: 322824
Vehicle:2005 WRX Silver |
#2829 | |
Member#: 45323
South East
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
Being 5x100 you don't have a quick and easy 17x8 +53mm wheel, but a 17x8/8.5/9 +45mm with a 255/40/17 can work on lowering springs when the appropriate fender work is complete. |
#2830 |
Member#: 251804
SWIC
Vehicle:05 WRB STi |
#2831 |
Member#: 290592
TXIC
Vehicle:2006 WRX Wagon 2004 WRX Wagon |
I don't have any firsthand experience, but won't you have (or be close to) strut interference issues at 17x9+45 with a 255?
#2832 |
Member#: 157158
Vehicle:05 WRX stage 2 PSM |
#2833 |
Member#: 322824
I'm actually looking at the 17x9 Rota Grids with 255/40/17, if that makes any difference. I'm gonna roll the fenders, my main concern is the rubbing and I want to be able to drive the car like it's intended, not cruise slowly for fear of the tires/wheels hitting
#2834 | ||
Member#: 45323
South East
More info: Fender Mod how to: with 18x9 +45mm and 255/35 on stock struts and cobb springs Going to coilovers can pose a problem depending on spring length, spring diameter, strut diameter, # of locking collars etc. I know RCE T2s and KW V3s are capable of running a 18x9 +45mm with a 255/35/18 without issue inboard. Quote:
Are you looking at the +42mm offset? |
#2835 |
Member#: 322824
yeah the +42 offset. Mine is a 2005 WRX btw. Would that be alright with just lowering springs or even stock still? I don't know whether that will hit or if I need coilovers for the fit. If I got coilovers they'd be cheap, so that makes the decision tough. Also just to get an accurate height with lowering springs makes me nervous, I don't want 'hellaflush' but I want the car to sit right with no rubbing, hitting, etc.
#2836 | |
Member#: 290592
TXIC
Thanks for that link- directly relevant to what i'll be doing with the wagon this weekend. |
#2837 |
Member#: 45323
South East
#2838 |
Member#: 174582
NESIC
Vehicle:2005 STI PSM |
295/30
![]() ![]() Last edited by mhwrx02; 02-27-2013 at 09:51 PM. Reason: picts |
#2839 |
Member#: 184485
Vehicle:0six Stage 2ish STi Aspen W |
Looks good ^^ What's the wheel specs??
#2840 |
Member#: 174582
NESIC
18x10 front +22, 15mm spacer for brembos, 285/30 tire. 18x11 +7 rear, no spacer, 295/30 tire
#2841 |
Member#: 45323
South East
#2842 |
Member#: 174582
NESIC
the rolling diameter difference is less than 1%. The center diff tolerances, recommended by subaru, are a variance of no more than 4%. Thanks for the input though!
#2843 | |
Member#: 45323
South East
I've seen multiple sources saying .25" difference to circumference is the highest allowable difference. the 285/30/18 at 77.9" and 295/30/18 at 78.5" has a .6" difference in circumference. This is well past the .25" circumference difference. Am I missing something? |
#2844 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
Compared to those, mine aren't meaty, but I just got some Federal 595 RS-R's mounted onto 17x9" RPF1's. They're quite a wide 255 compared to what I've seen in the past. Looking forward to actually trying them in a few months.
#2845 |
Member#: 174582
NESIC
http://www.1010tires.com/tiresizecal...?action=submit
this is what i went by. After consulting with a subaru tech, I was given the answer that as long as the circumference is within 4% (1973.3/1991.6=.9908%) |
#2846 |
Member#: 290592
TXIC
Meat wagon is finally coming together. Not sure you can tell in this pic but 255 SS595s are actually wider than my RA mudflaps.
#2847 |
Member#: 207561
South East
Vehicle:2005 WRB WRX WAGON PPG Trans |
just saw this on Garrett Turbo FB page...
![]() I'd say thats serious meat! |
#2848 |
Member#: 290592
TXIC
#2849 |
Member#: 315264
That intercoolers is as big as a a smart car!
#2850 |
Member#: 184485
I got a question for you meaty folks: I recently got some karlton flares with 10 inch wide wheels and I want to run a 295/35/18 tire, has anyone done this with success or is it going to be too tall like I've been hearing from everyone?
| Thread Tools | |
| Display Modes | |
| Does Anyone Else Have A (small) Problem With the Winter Tire Thread? | REX8 | Tire & Wheel | 8 | 11-08-2009 11:53 AM |
| Post you stock height/meaty tire pictures | patricksmith04 | Member's Car Gallery | 18 | 01-21-2008 01:42 AM |
| The Rally Tire Thread | Rallycarperson | Motorsports | 45 | 04-11-2005 07:52 PM |
