Welcome to the North American Subaru Impreza Owners Club Wednesday July 8, 2015
Old 04-08-2013, 10:31 PM   #2926
TheStig_22B
Member#: 208510
05 STI
Hope this is good enough for here. 17x9.5 +38 255/40 direzza ZII
IMG_4646 by Deebsr6, on Flickr
IMG_4656-Edit by Deebsr6, on Flickr
IMG_4653-Edit by Deebsr6, on Flickr
IMG_4641 by Deebsr6, on Flickr
TheStig_22B is offline   Reply With Quote
Old 04-08-2013, 10:43 PM   #2927
army21b
Member#: 228116
2008 FXT Sports
AW
spacers?
army21b is offline   Reply With Quote
Old 04-08-2013, 10:48 PM   #2928
TheStig_22B
Member#: 208510
05 STI
5mm in the front to clear brembos.
Old 04-08-2013, 11:11 PM   #2929
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Looks kind of like my setup!
Enkei RPF1 17x9" +35 Wheels
Federal 595 RSR 255/40R17 Tires
xluben is offline   Reply With Quote
Old 04-09-2013, 10:34 AM   #2930
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
had a little shoot after she was detailed, photo's taken by my buddy. 265/35 RE11's
still a work in progress, gonna tweak the suspension and do the brakes next week.
Jive Turkey is offline   Reply With Quote
Old 04-09-2013, 11:22 AM   #2931
gaguilarsti
Member#: 213354
2013 BRZ
hhmm... is this a square set up on the tires?
Might not be selling my new set of 275/40/17's after all...
gaguilarsti is offline   Reply With Quote
Old 04-09-2013, 11:28 AM   #2932
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Yes, he's running 265/35/18s on all four.
SWP n Gold is offline   Reply With Quote
Old 04-09-2013, 11:30 AM   #2933
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Yes! I have been waiting for these for a while... Drool!
JSchell1309 is offline   Reply With Quote
Old 04-09-2013, 11:33 AM   #2934
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
depending on offset and suspension, that might be too much tire. what brand? honestly even what i'm running is a bit overkill for the car, but it handles so nice
"overkill is under-rated"
Old 04-09-2013, 11:41 AM   #2935
gaguilarsti
Member#: 213354
2013 BRZ
^^ agreed!
Well, I literally just sold a set of NT01's in the last 5 minutes but still have a set of 275/40/17 NT05's that I only used for a handful of track days last year and could be pretty money on a BRZ of which I'm about a week out from getting.
All about function for performance so what kind of camber are you running and is there rubbing?
Old 04-09-2013, 11:47 AM   #2936
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
^^ agreed!
i didn't get aligned/corner balanced yet as the KW's are taking a while to settle but now that its settled the rear camber is out of whack. but i was set to -2 all around but i'm gonna try to keep it at 2 all around. really not much needed because my offset is reasonable.
275/40 is a huge sidewall though.
i rubbed on the rear bumper, the plastic part, that rubbed it self out, or just trim it before you put it on. the front i had issues, towards the front of the fender by the side marker the fender flares out. otherwise its rolled pretty flat from factory. i had to roll that little lip in basically to gain some clearance.
Old 04-09-2013, 11:49 AM   #2937
gaguilarsti
Member#: 213354
2013 BRZ
ah, thanks for that super helpful!
In that case, someone buy my NT05's! haha
Old 04-09-2013, 11:54 AM   #2938
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
no problem, if you need any info or etc just pm me. happy to help.
Old 04-10-2013, 06:19 AM   #2939
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
Hybrid,07 6spd, BW Roated
Got a question for y'all meaty tire guys.
I just got a 18x9.5 35et wheels, and trying to figure out what's the best size to run the car without doing major pulling on fenders? Currently they are rolled, and very slightly pulled.
Car is dropped, not dumped, but will be getting dropped another .25" all around. Tires I have in mind 235/40 or 255/35
Here's a quick pic of it on 18x8 35et on 235/40 tires.
UpSideDownDesi is offline   Reply With Quote
Old 04-10-2013, 07:27 AM   #2940
Aarron_M
Member#: 68210
2013 STI
There wasn't a question mark in your entire post.
Aarron_M is offline   Reply With Quote
Old 04-10-2013, 09:00 AM   #2941
army21b
Member#: 228116
2008 FXT Sports
AW
my 255 Potenza RE760's are stretched onto my 9.5's.
Old 04-10-2013, 09:27 AM   #2942
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Originally Posted by UpSideDownDesi View Post
I just got a 18x9.5 35et wheels, and trying to figure out what's the best size to run the car without doing major pulling on fenders. Currently they are rolled, and very slightly pulled.
255/35s will be slightly easier to fit since they're smaller.
Old 04-10-2013, 11:49 AM   #2943
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
fixed
What modification did it require to fit?
I have had 245/40/18 before on a 18x7.5 42et wheels on my car. Fenders were rolled and pulled enough where tires sat flush without any scrubbing with almost 0 camber all they way around. Now wondering if I was able to pull that, the current roll/pull will be enough for 255/35 with slight camber.
Is any one running either one of the tire combos, and please post a picture or and advice. Thanks
Old 04-10-2013, 01:57 PM   #2944
low-n-slow
Member#: 313818
2002 wrx hybrid
TV stars don't need question marks
low-n-slow is offline   Reply With Quote
Old 04-10-2013, 03:34 PM   #2945
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
If you don't want to move the fenders, move the tire. Sounds like 2 more degrees of negative camber should do it. Assuming you don't hit the struts first.
JourdanWithaU is offline   Reply With Quote
Old 04-10-2013, 06:25 PM   #2946
UpSideDownDesi
Member#: 148372
02 WRX,FD,S2K,M5
I see what you did there .
I am running Tein Flex Coilovers. Ran 19x8.5 35et with -3 degrees in the back and -2.5 in front previously, not strut issues. I don't have front fender liners either. I don't mind running some camber, car isn't my DD.
Just don't want to get the tires, and then lol.
Old 04-10-2013, 08:37 PM   #2947
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
jbp
I need to pull the rears and shave the fronts 17x9 +35 245/40 star spec
[IMG][/IMG]
Str8Gone is offline   Reply With Quote
Old 04-10-2013, 09:03 PM   #2948
army21b
Member#: 228116
2008 FXT Sports
AW
None, yet. When I do get it lowered I will make sure I have enough room for 265's
Old 04-10-2013, 10:20 PM   #2949
RossLH
Member#: 147839
2003 WRX
SRP
Spring is here!
RossLH is offline   Reply With Quote
Old 04-10-2013, 10:36 PM   #2950
low-n-slow
Member#: 313818
2002 wrx hybrid
[IMG][/IMG]
Excuse my question that does not involve meat but is that fender and eye lid kevlar?
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
