Old 04-23-2013, 08:20 AM   #3026
deanwrx
Member#: 188997
2007 STI
Originally Posted by RedRumbleWagon View Post
Rim size? 17x ?
Work Emotion cr kai 17x9 +44 5x100 - I follow da bugeyes.
deanwrx is offline   Reply With Quote
Old 05-02-2013, 02:09 PM   #3027
Nightmaresmk
Member#: 281522
05 Outback 2.5XT
Wagon with 255/50R17
Nightmaresmk is offline   Reply With Quote
Old 05-03-2013, 12:29 AM   #3028
A. G. Pym
Member#: 287398
2008 WRX Hatch
TP Stage 1
Any profile shots of this ride?
A. G. Pym is offline   Reply With Quote
Old 05-06-2013, 09:08 AM   #3029
Nightmaresmk
Member#: 281522
05 Outback 2.5XT
I haven't done any real pictures here is one from my cell.
Here is a profile. My wheels are 17X8 et35 Rota Torque Perfect look and postition
Old 05-06-2013, 11:03 AM   #3030
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Originally Posted by FonzMEDIA View Post
Thank you.
18x9 +45
Mild front roll
Rear grind and mild pull
-1.9 deg front, -2.3 deg rear
As you may have assumed, i wanted a 9" wide wheel with minimal rim outside the fender well, hence the 45 offset
I can't figure out how you guys clear the strut/coil with that high an offset. I'm at +38 with a 255 and any more than -1* camber puts me right against the strut. How much inboard clearance do you have?
mechatricity is offline   Reply With Quote
Old 05-06-2013, 10:12 PM   #3031
FonzMEDIA
Member#: 351896
2005 WRX STI
Crystal Gray Metallic
I have about 8mm of strut clearance in the rear, and since the fronts have camber plates I have a bit more clearance there.
FonzMEDIA is offline   Reply With Quote
Old 05-07-2013, 12:39 AM   #3032
caplephoto
Member#: 286353
2015 WRX
Crystal White Pearl
Lurker by CaplePhoto, on Flickr
Finally got some meat. Matte bronze 18x9.5 ROTA DPT on 275/35/R18 Cooper RS3-S's.
caplephoto is offline   Reply With Quote
Old 05-08-2013, 09:17 AM   #3033
Nmullin11
Member#: 353683
2015 Wrx limited
Wrb
The silver one is mine and the wrb is my inspiration sti.
Same rims on my car just not as low, or clean and different spacers
Nmullin11 is offline   Reply With Quote
Old 05-11-2013, 04:48 PM   #3034
02wrxYEE
Member#: 351797
Sedona Red Pearl
Specs on the silver? What suspension are you running?
02wrxYEE is offline   Reply With Quote
Old 05-11-2013, 06:08 PM   #3035
TwinscrollGT35R
Member#: 256810
37's on 20's I think its meaty.. They almost make my Subaru tires small.
TwinscrollGT35R is offline   Reply With Quote
Old 05-27-2013, 10:08 AM   #3036
sotoWRX
Member#: 186202
06 WRX
Dom3 XT-R
My new wheels and tires
18x9.5 RPF1
265/35 Toyo R888
sotoWRX is offline   Reply With Quote
Old 05-27-2013, 03:14 PM   #3037
orestes85
Member#: 299557
2011 STI
18x10 Volk TE37SL Black Edition
275/35 z1 Star Specs
orestes85 is offline   Reply With Quote
Old 05-27-2013, 03:32 PM   #3038
easterbran
Member#: 307359
'05 STi Stage II
That is just glorious.
easterbran is offline   Reply With Quote
Old 05-27-2013, 05:44 PM   #3039
gotboost02
Member#: 83764
02 WRX / 00 RS
gotboost02 is offline   Reply With Quote
Old 05-28-2013, 04:08 AM   #3040
Horse
Member#: 183912
??? What widebody?
Star Specs 265/35/18, 18x10 +35 (old setup)
Horse is offline   Reply With Quote
Old 05-28-2013, 04:13 AM   #3041
Horse
Member#: 183912
??? What widebody?
new setup 285/30/18, 18x10 +35, 5mm spacer
285/30 brand X vs 285/30 brand Y. HUGE difference in size
test fitting, pokes with no alignment yet.
stock body, inner/outer fenders molested
Old 05-28-2013, 06:49 AM   #3042
orestes85
Member#: 299557
2011 STI
Not rubbing with only a 5mm spacer? My 275/35 star specs were about 3-4mm away from the coilover on my 18x10 +40s and we had to get creative to ensure that we had clearance on the inside (granted, mine is a completely different chassis). My rear still needs a roll, though and we're bringing the back up about 1/8-1/4 inch to match the front to keep from having to bottom out the front's collar.
Old 05-28-2013, 07:31 AM   #3043
BSHUNTER
Member#: 290877
2013 WRX STI SEDAN
[quote=orestes85;39892794]18x10 Volk TE37SL Black Edition
Love this!
BSHUNTER is offline   Reply With Quote
Old 05-28-2013, 12:36 PM   #3044
Horse
Member#: 183912
??? What widebody?
Yup. +35 with a 5mm spacer has more room than +40. With just the camber bolt and plate trick I was yielding over 8mm of clearance between the strut body and 265/30 tire (shorter swift springs clear tires). Rear has no spacers
Old 05-28-2013, 12:41 PM   #3045
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
Your T2 collars are the rub point.
Shorter springs would fix it.
-t3h_Clap
WRX8XB is offline   Reply With Quote
Old 05-28-2013, 07:22 PM   #3046
BLUESTiYLE
Member#: 207422
04 STi
A little meaty! 285/30/18
IMG_3011 by sti_yle, on Flickr
BLUESTiYLE is offline   Reply With Quote
Old 05-28-2013, 07:28 PM   #3047
TwinscrollGT35R
Member#: 256810
Finally we are getting some meat back in this thread.
Old 05-28-2013, 07:39 PM   #3048
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
those you running 265 35's what are your wheel offsets?
i'm on 245 40 17 with +20 offset, my fenders are rolled and pulled like crazy and the is still a bit of poke. I want to run 265's but i'm afraid on my offset they would look dumb as hell with out fender flares.
ravenlunatic is offline   Reply With Quote
Old 05-28-2013, 07:53 PM   #3049
gotboost02
Member#: 83764
02 WRX / 00 RS
+25 .. Yes I currently feel like it pokes too much but about to do some more rolling and a phone book pull. I feel like its right there but it need a little massaging. I am determined to get these 265s to fit under stock fenders and still be low.
Old 05-28-2013, 08:03 PM   #3050
ravenlunatic
Member#: 180601
2003 PSM WRX
phone book pull?
haha the difference 5mm makes when you are pressing for all the tire you can under your car...
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
