Old 01-18-2012, 11:00 PM   #1401
Jcizzo
Member#: 248317
2008 F430 Hamann
2005 V-limited STI
More meat please. Someone please post a link so we can continue w/ the thread
Jcizzo is offline   Reply With Quote
Old 01-18-2012, 11:07 PM   #1402
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Originally Posted by TwinscrollGT35R View Post
As the cost of Subaru's drop. The lower crowds buy them up. The evolution of a subaru owner begins.
Stock studs on a true 400+whp car is stupid to begin with. Let alone wrong offsets.
Anyone figure out stock wheel studs, with spacers. Then add leverage of wrong wheel offsets and come up with a breaking point in psi? Excel spread sheet on WHP, So you could look at your offset, your whp and come up with oem wheel stud strength. Or something like that...
So if that sounds stupid. I'm on doc's pain meds.... lol
Properly torqued, it takes TONS of force to overcome the friction between the hub face and the wheel. I forget the actual number, the calculations are in the Wheel and Tire forum somewhere.
vision.dynamix is online now   Reply With Quote
Old 01-19-2012, 02:54 AM   #1403
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
UsVERSUSThem WFC #197
245/40 17x9 et38 CR Kais.
SubIELove is offline   Reply With Quote
Old 01-19-2012, 10:42 AM   #1404
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
^ That's virtually my setup. Falken Azenis RT-615 245/40/18 x 9 +38 Drag DR-31.
Any chance you got a measurement of the tire before installing them? I've heard they run around 10mm wider than most.
Up in the air whether i want to run those Star Specs at 245 (presumably measuring close to 255) gaining me an extra 10mm more tire, or just go with a different tire at 265/35/18 for a little more tire and slightly less sidewall.
QwaktastiK is offline   Reply With Quote
Old 01-19-2012, 03:07 PM   #1405
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Go 265-40 don't be a vagina.
Only reason I went 35 is because it's all they have for 295s.
Wrx_Fan_0717 is offline   Reply With Quote
Old 01-19-2012, 03:11 PM   #1406
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
265/40r18 is WAY too tall.
Old 01-19-2012, 03:24 PM   #1407
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
so is 295/35/18.
WRX8XB is offline   Reply With Quote
Old 01-19-2012, 03:26 PM   #1408
Wrx_Fan_0717
Member#: 152080
Thought they were 17s.
Semantics. And no way 295-35d are tits
Old 01-19-2012, 09:42 PM   #1409
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
lol. Thanks for the encouraging words. Yeah, 265/35/18
Just worried about whether they'll fit. I'm on a narrow body and stock style suspension (not coilovers). So kinda curious whether it'll fit.
Old 01-19-2012, 10:06 PM   #1410
Wrx_Fan_0717
Member#: 152080
I have 245/40/18 star specs on the daily (a mazdaspeed 3) and its meaty and not too tall. Good compromise I think I have a pic somewhere of the tire/wheel.
I'd do a 255 star spec. I'd rather have a wider tire. 255s tuck easy with a roll and pull. Anything over 235s really have the same outcome anyway. You scrub without fender work.
Old 01-19-2012, 10:11 PM   #1411
Annihilator817
Member#: 296742
'16 STI,'11 WRX,
'96 328i DSP
I'm running 265/40/17 Z1SS's, and they only rub on the inner fender well on the rear at full compression, no roll necessary.
Annihilator817 is online now   Reply With Quote
Old 01-19-2012, 10:14 PM   #1412
Wrx_Fan_0717
Member#: 152080
Maybe. ....nah. Lol
A bit, but I love meaty tires.
Originally Posted by WRX8XB
so is 295/35/18.
Nooo way. This is the meaty tire thread. Not rubber band church of the super duper my tires don't fit right and pop a bead thread.
I have 295/35s and I think the sidewalls are about perfect.
Old 01-19-2012, 10:23 PM   #1413
Wrx_Fan_0717
Member#: 152080
You have a 2011...............02-07s and newer WRXs will most definitely rub with a sane sized wheel and offset.
Wait did you put a 265 on a stock wheel?
Old 01-19-2012, 10:25 PM   #1414
SubIELove
Member#: 107571
2004 OBS JDM V8 Sti
I ran RT615's on my old wagon and they ran a tad bit wide, but not as much as the star specs do. Since the rt615's are no longer available, only the rt615-k's are available now, I can't comment on how they run size wise. I do like the grip on the star specs a little better than the old 615's. Once again, can't comment on the performance of the new K's as I havent tried them yet. Also the sidewall on the 265 at 35 will probably be the same size, if not larger, than that of a 40 series sidewall on a 245.
Old 01-19-2012, 11:14 PM   #1415
Eww Evo
Member#: 299687
2.5L Rallispec Block
06' Wrx Track Car
^^ Clean. Nice Hatch..
Eww Evo is offline   Reply With Quote
Old 01-19-2012, 11:54 PM   #1416
exhaust_note
Member#: 73375
The Dunlops are awesome, way better then Falken.
exhaust_note is offline   Reply With Quote
Old 01-20-2012, 10:17 AM   #1417
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Heres an oldie:
IMG_0308 by k.duong, on Flickr
255/35 Star Specs
Old 01-20-2012, 11:42 AM   #1418
Annihilator817
Member#: 296742
'16 STI,'11 WRX,
'96 328i DSP
Sorry, I was flipping back and forth between this thread and this one: http://forums.nasioc.com/forums/show...7#post36174207 So in my absent mind I neglected to make the connection that we were talking about another chassis.
Yes, on a stock wheel. I don't have the option of using larger wheels. And I would have gone bigger than 265/40/17 if Dunlop offered a larger size in the Z1SS.
Old 01-20-2012, 05:20 PM   #1419
TwinscrollGT35R
Member#: 256810
I am planning to go to a 35 and I would love to run a 40. I have plenty of room to run a 35. And I am sure I could go down to a 275/40/18 and get a much better contact patch on the track. The current 30 is a kidney killer and on some tracks is more a negative for traction then a gain. 30's I think are a waste of rubber in my opinion. My next set I run is going to be a 315-295/35/18 And if I can't get that in the brand I am looking at in the compound I want. Then I am going to run a 275/40/18
Its cool to look at a car and go WOW that's a tire on that car. But when its about function, 30's have done nothing but upset my car mid corner with a bump or a dip. The sidewall just can not handle it like taller tires can. I also think 30's on the street are bad as once again you do not have enough sidewall to soak up a pot hole and what not.
TwinscrollGT35R is offline   Reply With Quote
Old 01-20-2012, 06:04 PM   #1420
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
What suspension are you on? I do just fine on my 285/30/18s. In fact they are much better than the 295/35/17s I used to run. Less basketball effect and more direct feel.
pignoseSTI is offline   Reply With Quote
Old 01-20-2012, 07:28 PM   #1421
TKimmell
Member#: 274270
2006 2.5i
Regal Blue Pearl
I have a set of 16x10 0 offset diamond racing wheels for my car, I'm not sure what size tire I should get, I know the wheels will be sticking out a good 2 inches past the stock fender, which is why I'm getting flares. 285/35 or 285/40?
Thanks-
TK
TKimmell is offline   Reply With Quote
Old 01-20-2012, 09:21 PM   #1422
grippy monkey
Member#: 131067
your "stance"
sucks
^ hahaha... forealz? you gonna add some NOS to your 2.5i to push those?
grippy monkey is offline   Reply With Quote
Old 01-20-2012, 10:55 PM   #1423
ej20forester
Member#: 117185
2006 FXT MT
Thanks-
TK
Interesting choice... i would recommend the taller tire considering it's on a 16" wheel.
ej20forester is offline   Reply With Quote
Old 01-20-2012, 11:20 PM   #1424
Annihilator817
Member#: 296742
'16 STI,'11 WRX,
'96 328i DSP
Tire sizes are horribly limited for 16 inch wheels. Good luck finding a decent tire in a large size.
Old 01-21-2012, 01:04 AM   #1425
ej20forester
Member#: 117185
2006 FXT MT
True there is nothing close to the size you are looking for. and if there is they are track tires. best match i found were 275-45-16 hoosier for $1130 a set. widest streetable tire i found was a 225.
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 12:53 PM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 02:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 08:52 PM
