Old 01-21-2012, 12:06 AM   #1426
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Originally Posted by ej20forester
True there is nothing close to the size you are looking for.
These are not the meats you're looking for..
kyletakahero is offline   Reply With Quote
Old 01-21-2012, 09:25 AM   #1427
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Originally Posted by Wrx_Fan_0717 View Post
I have 245/40/18 star specs on the daily (a mazdaspeed 3) and its meaty and not too tall. Good compromise I think I have a pic somewhere of the tire/wheel.
I'd do a 255 star spec. I'd rather have a wider tire. 255s tuck easy with a roll and pull. Anything over 235s really have the same outcome anyway. You scrub without fender work.
255/40/18 is too tall and 255/35/18 is too short for my liking. I only like 245/40/18 or 265/35/18. I know, I'm crazy.
Originally Posted by SubIELove View Post
I ran RT615's on my old wagon and they ran a tad bit wide, but not as much as the star specs do. Since the rt615's are no longer available, only the rt615-k's are available now, I can't comment on how they run size wise. I do like the grip on the star specs a little better than the old 615's. Once again, can't comment on the performance of the new K's as I havent tried them yet. Also the sidewall on the 265 at 35 will probably be the same size, if not larger, than that of a 40 series sidewall on a 245.
245/40/18 has a 10mm taller tire diameter than 265/35/18. So the sidewall of the 245/40/18 is in fact larger than that of the 265/35/18.
http://www.rimsntires.com/specs.jsp
My main complaint about the RT-615's is the tramlining/nibbling. I guess it's the combination of the tread pattern and the reinforced sidewall. Definitely not going with these again.
QwaktastiK is offline   Reply With Quote
Old 01-21-2012, 05:41 PM   #1428
Heliflyer
Member#: 302709
Totally changes look of vehicle..
Heliflyer is offline   Reply With Quote
Old 01-21-2012, 07:24 PM   #1429
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Na I agree with you truth be told. 245-40s or 265s. I only ran 255-40s on my 17s.
Wrx_Fan_0717 is offline   Reply With Quote
Old 01-25-2012, 06:46 PM   #1430
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
Originally Posted by 07wrx84
M12x1.25
12= major diameter = .4724"
1.25= pitch in mm
Pitch is one crest of thread to another crest of thread.
1.25 X .03937"= .0492125"
.0492125/1"= 20.3204 threads an inch.
So 3mm spacer is .11811" so that means your only using 2.4 threads of the stud. Its not that big o deal
This ^^^^^
07wrx84 is offline   Reply With Quote
Old 01-28-2012, 01:14 AM   #1431
Frogg
Member#: 267429
2005 Suburban 4x4
dont these 265+ slow you down? Or are you guys REALLY pushing it through the corners?
Frogg is offline   Reply With Quote
Old 01-28-2012, 01:07 PM   #1432
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Can someone explain why you have to go down in sidewall height when you go wider?
MakuseruSukotto is offline   Reply With Quote
Old 01-28-2012, 01:16 PM   #1433
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
because its goes off a percentage. Like a 255 45 is too tall (i know from experience)
For a 255/45 itd be 45% of 255 which is alot taller than a 225 by 45
(someone correct me if im wrong)
future_subaru_owner is offline   Reply With Quote
Old 01-28-2012, 01:21 PM   #1434
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Correct. The second number is called the aspect ratio. It is a percentage of the section width. It refers to the sidewall. When calculating the total tire height, it's important to remember you have TWO sidewalls, one above and one below the wheel.
Old 01-28-2012, 02:38 PM   #1435
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
No, they make my car MUCH faster. In fact, they are an absolute necessity in my case.
Yes, but not on the street.
Annihilator817 is online now   Reply With Quote
Old 01-28-2012, 02:47 PM   #1436
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
I hadn't even thought of it like that.
I thought it was a fixed ratio. Thank you guys!
Old 01-30-2012, 10:10 AM   #1437
vicious_fishes
Member#: 158864
2003 SOHC destroker
anyone stuffed a 285 or 295/30 in? spotted carlton with his flares but that's it.
i think the TIC guys too, although they don't have any flares.
vicious_fishes is online now   Reply With Quote
Old 01-30-2012, 11:11 AM   #1438
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I put a 305/30/18 on my stock body with a 18x10 +35 wheel before I made the flares. I did a big pull on the rear but the front was untouched
pignoseSTI is offline   Reply With Quote
Old 01-30-2012, 11:40 AM   #1439
vicious_fishes
Member#: 158864
2003 SOHC destroker
Old 01-30-2012, 12:07 PM   #1440
TwinscrollGT35R
Member#: 256810
TwinscrollGT35R is offline   Reply With Quote
Old 01-30-2012, 12:08 PM   #1441
03 RS
Member#: 81227
2012 Wrangler 4DR
Gecko Green
Have a quick question,
I have an 07 STI, I'm going to be running stock struts with prodrive red springs, wheel size is more than likely going to be 18x9, offset in the neighborhood of 35 or so, I'm unsure on what wheels I will be running. At any rate, I want to know what the meatiest set of tires I can run on the car with this suspension setup. I will also be rolling the fenders, so that can be taken into account. Is it possible to run a 255/40? Or will that be pushing it? I understand that with a coil over setup will allow me more options, but will not be getting coil overs until later in the year.
I should alsO add, I am not looking for "hella" fitment at all, the car will be at a normal ride height, as the streets in NYC are more like a minefield than actual paved roads lol.
Any and all helP is greatly appreciated
-Adam
03 RS is offline   Reply With Quote
Old 01-30-2012, 01:22 PM   #1442
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
^255/35's are easier to fit. 40 is too tall
blakkboxer is offline   Reply With Quote
Old 02-06-2012, 01:28 PM   #1443
Sikk Boy
Member#: 65006
2008 STI - Stage 2
Dark Gray Something
Default Kumho Ecsta 4x (265/35) + Rota T2R (18x.9.5+38) = DGM 2008 STI (rolled rears)
Wow... quite impressed with the rides and fitment here. I'm a bit more conservative.
Kumho Ecsta 4x (265/35) + Rota T2R (Hyperblack, 18x.9.5+38) = My Ride (DGM 2008 STI, rolled rear fenders)
Note: The angle looks like the start of the tape measure is off to side, but it's not. ~11" wide... which is a little bit bigger than expected for a 265mm.
Once I get it lowered on RCE Yellows I hope to get out and snaps some better pix of the setup.
Sikk Boy is offline   Reply With Quote
Old 02-06-2012, 04:35 PM   #1444
mirow82
Member#: 238895
2009 STi
Sikk Boy, I REALLY wanna see those on the yellows!
mirow82 is offline   Reply With Quote
Old 02-06-2012, 11:16 PM   #1445
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Hey fellas, whats a good meaty tire size for 17x7.5's? I know that might sound a little silly
FastAdams is offline   Reply With Quote
Old 02-06-2012, 11:25 PM   #1446
amart21
Member#: 173813
'15 FXT
amart21 is offline   Reply With Quote
Old 02-07-2012, 04:06 AM   #1447
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
Originally Posted by amart21 View Post
235/45
Too tall.
235/40/17 is a much better size, its actually the same diameter as pre-2011 OE WRX tires.
Old 02-07-2012, 04:59 PM   #1448
Annihilator817
Member#: 296742
'16 STI, '11 WRX,
'96 328i DSP
Old 02-07-2012, 05:26 PM   #1449
ztotheh
Member#: 239130
2005 WRX
WRB (retired)
^Reverse stretch. Too wide for those wheels.
ztotheh is offline   Reply With Quote
Old 02-07-2012, 05:30 PM   #1450
aesthetect
Member#: 89051
2001 GC6
what sizes z1s dat iz?
aesthetect is offline   Reply With Quote
Does Anyone Else Have A (small) Problem With the Winter Tire Thread? REX8 Tire & Wheel 8 11-08-2009 11:53 AM
Post you stock height/meaty tire pictures patricksmith04 Member's Car Gallery 18 01-21-2008 01:42 AM
The Rally Tire Thread Rallycarperson Motorsports 45 04-11-2005 07:52 PM
