Old 09-03-2008, 12:21 AM   #1
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Default Prosport coolant temp. gauge reading low compared to Accessport. ?
I just got done reading all the live data for my car on my accessport. (of course not while I'm driving though )
Accessport was reading 194 degrees for the coolant temp when engine was at full operating temp.
Prosport gauge consistently reads 180 degrees.
Any ideas why? Maybe it has to do with the placement of the coolant temp sensor? That just seems like a pretty big gap.
lennyTR is offline   Reply With Quote
Old 09-04-2008, 12:55 AM   #2
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
bump because it is important to know exactly how hot my motor gets.
Old 09-04-2008, 02:19 AM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Where is the temp sender for the prosport unit...
Old 09-04-2008, 01:52 PM   #4
lennyTR
Member#: 142379
2007 WRX TR
Satin White Pearl
Upper radiator hose. I used prosport's radiator hose adapter.
Old 09-04-2008, 05:21 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
Thats why. The factory unit is in the cross over pipe which sees more coolant flow and is between the two block halves vs the prosport one that sits in the hose and when the thermo is closed no fluid is even passing by.
I wonder if you could tap into the single wire gauge sending unit?
Coolant Temp gauge not reading badchad Legacy Forum 6 07-15-2008 11:32 PM
Prosport Boost Gauge Reads Low RexTexWagon Electrical & Lighting 5 06-18-2008 07:48 AM
Prosport Mechanical Boost Gauge Reads Low RexTexWagon Newbies & FAQs 19 03-17-2008 02:08 PM
Transmission temp gauge idea, Switch to use coolant temp gauge so no dash space taken ciper Transmission (AT/MT) & Driveline 6 06-05-2003 03:54 PM
For those of you who wants to install a water temp gauge! Read here. tmat3 Normally Aspirated Powertrain 0 02-09-2002 09:12 PM
