Old 09-03-2008, 08:04 AM   #1
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars 2.5i heads with EJ257 bottom end
Will an STi bottom end bolt up to my heads and can I use all my accessories... ac, alternator, water-pump, etc.. and if i were to do this, and slapped on a turbo, would i need new EM, or is my stock ECU tune-able?
For the record, I've heard and read my heads will bolt up to an EJ257, I don't know about all the accessories though, and I have read that the 06+ ECU on a 2.5i is tune-able.. just trying to get a more clarified answer.
Thanks.
Boosted WRX STi is offline   Reply With Quote
Old 09-03-2008, 08:38 AM   #2
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
you will need to reflash it + use some sort of piggybacking for your best results IMO.
but yeah, your ecu is flashable so you should have good results, if its done right
mxpunk is offline   Reply With Quote
Old 09-03-2008, 02:08 PM   #3
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Im assuming your car is turboed or it will be soon.. otherwise its gonna be snail slow.
I dont know how the coolant pipe is on 06, but if its the same as the 99-01 2.5RSs, then you are gonna have to modify it for it to clear the extra breather the STI block has.
read the FAQ... and it'll explain it there.
maxiav is offline   Reply With Quote
Old 09-03-2008, 04:02 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
any chance of you selling it and getting a wrx or sti?
just seems like a headache to get it that way
but if you must, why not do a full drivetrain swap?
Nuke209 is offline   Reply With Quote
Old 09-03-2008, 05:50 PM   #5
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars
I did a quick look through and wasn't really clear on whether or not I would need to modify the coolant line, I'll definitely look into this.
I leased the car two years ago, and have two left, it was a good deal, but my car is 'snail slow' as maxiav put it. I am more just toying with the idea of swapping the bottom end to drop my comp ratio and run moderate boost. In the end, I'll probably wait until my lease is up and get a 2010 STi. I love my car, just wish I could make it quicker.
Old 09-03-2008, 05:58 PM   #6
shutupnshift04
Member#: 101710
BOSS
its leased right? throw some nitrous in that pig and beat it till it blows.....thats what my girl does atleast ahahha
shutupnshift04 is offline   Reply With Quote
Old 09-04-2008, 07:32 AM   #7
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Always with the selling it
Chocoholic005 is offline   Reply With Quote
Old 09-04-2008, 10:54 AM   #8
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
You're going to swap the shortblock on a leased car? Are they going to ding you for that when you turn the car back in? Maybe it's time to put the car up leasetrader?
jey is offline   Reply With Quote
Old 09-04-2008, 11:10 AM   #9
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars
I would buy the car out come the lease end. This question was more just out of curiosity, and to see what my options would be if I decided to do it.
Old 09-04-2008, 01:26 PM   #10
rdodger
Member#: 156447
99 18g'd 2.5RS-T
It isn't just a matter of slapping a turbo on and throwing a shortblock in, its a huge amount of work to turbo a NA motor, you need a turbo waterpump, turbo headers, tmic, boost controller, custom oil feed and drain lines, and many other things. Don't forget the dozens of trips to the hardware store and dozens more clearance issues to fix. Having just completed the exact same thing you speak of but on a 99rs, let me tell you that unless you buy a premade kit or have extensive wrenching experience DO NOT DO IT. It worked out for me because I have years and years of wrenching experience and a full shop at my hands. In your lease position on such a new car, your best bet is selling it for a wrx,swapping it, or premade kit.
rdodger is offline   Reply With Quote
Old 09-04-2008, 03:18 PM   #11
VIsubi
Member#: 187834
06 2.5i impreza
Red
I have a 06 2.5i with 9,000 miles on it..I was thinking of turbo charging it also but I wanted to find out if anyone had a site or new a company in the US that sold the WRX engine and ECU and harness as a package...for the right price I'd just do the swap and put the 2.5i on a pallet covered down in my garage for when ever I need to to throw her back in or not. Any sites would be appreciated thanks...the question remains if you throw on the SOHC HEAD will it flow with pressure. Also you'd still need to get a 3mm gasket to lower the compression cause it would still be up there maybe 9.2?
VIsubi is offline   Reply With Quote
Old 09-04-2008, 03:34 PM   #12
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars
Thank you, but I know this already, and do have quite a bit of wrenching experience. Unfortunately I do not have a shop to work in at my discretion, other then my buddies Chevy dealer that I would have to do after hours, and as I'm in school right now, its too far away. I was wondering whether or not swapping the bottom end will be an easier solution then a full motor swap.
Old 09-04-2008, 03:36 PM   #13
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Subaru Stars
Talk to Frank at Millennium Auto, they have a bunch of STi kits and WRX kits for sale. They run from $3800 for just a WRX motor package, up to $12,000 for a full STi drivetrain swap. Hope that helps you.
Old 09-04-2008, 04:46 PM   #14
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
The price of the car, turbo, engine and finance charges (the residual cannot be great on a Subaru not to mention who knows what money factor the dealership used)...this does not make financial sense. I would just turn it in at the end of the lease and source a used STI or whatever you want and start fresh.
Steve.804 is offline   Reply With Quote
Old 09-05-2008, 08:32 AM   #15
VIsubi
Member#: 187834
06 2.5i impreza
Red
Thanks Boosted I'm gona do a search on google for this company since no web address. I also think its best just to buy the whole engine and ECU..friend of mine bought an SR20 silvia black top motor with tranny and ecu for 5000..not a bad price seeing as the wrx motor is just a run harness and bolt up to tranny. From what I've heard the gas tank bowl is different and theres three fuel lines compared to the two on the 2.5i..friend of mine bought a wrx from an insurance company after they rolled it for 600 bucks..but wouldn't a upgraded fuel pump just work..from what he said he had to swap in the gas tank aswell..I don't really see the need to do all that. if anyones got feedback on this it would be greatly appreciated. Or I'll just ask the guys at millenum auto. Thanks Boosted
Best headgasket to use for ej20r heads/07 ej257 bottom end? trxdam Pre-2002 Factory Turbo Powertrain 9 11-12-2009 03:19 PM
WRX 2.0 heads on STi bottom end... Compression? jblackwell Subaru Conversions 2 10-23-2008 08:33 PM
WRX 2.0 heads on STi bottom end... Compression? jblackwell Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 10-07-2008 11:53 AM
wrx head with EJ207 bottom end Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-19-2006 06:49 PM
EJ257 bottom end swap into '03 WRX? MajinVejitaXV Newbies & FAQs 2 01-12-2005 03:45 PM
