Old 09-03-2008, 07:11 PM   #1
mookies
Member#: 168294
2007 WRX
Default How did you Cut/Mod your stock turbo heat shield?
Hey everyone,
So I installed my cobb tbe =] and now I need to either buy a new heat shield or mod my stock one. I'd rather save the $$, and I also heard the stock heat shield is better than aftermarket ones...so I want to see how people did theres. Which tools do you guys recommend (hopefully something simple)?
Thanks!
PS: i tried searching but if there are threads around already then sorry! and please post the link so I could just look on over.
mookies is offline   Reply With Quote
Old 09-03-2008, 07:56 PM   #2
obsti2
Member#: 174278
2004 WRX
JavaBlackPearl
All you really need is a good set of tin snips,basically just trim about the bottom 1/3 of the heatshield's edge that should get most of it out of the way.At that point just trim a little then test fit over and over untill it fits to your liking.Also you can run a cusco or cobb shield over the stock one for even better heat resistance.Ive had both and the cusco is alot easier to work with,takes about 30 to install the cusco and about 3-5 minutes for the cobb.
obsti2 is offline   Reply With Quote
Old 09-03-2008, 11:05 PM   #3
07HaWkEyE
Member#: 139080
2006 Trailblazer SS
Summit White 6.0L V8
read the directions on cobbs site , i also threw a few coats of engine enamel spray pain on there
07HaWkEyE is offline   Reply With Quote
Old 09-03-2008, 11:26 PM   #4
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
Tin snips, dremel, file, whatever. Look around in your garage.
MB38 is offline   Reply With Quote
Old 09-03-2008, 11:46 PM   #5
Sleepr56
Member#: 67326
2015 WRX Limited
World Rally Blue Pearl
Is keeping the turbo heat sheild (stock/hacked or aftermarket) essential after installed a bigger dp? -- noob question....
Sleepr56 is offline   Reply With Quote
Old 09-03-2008, 11:50 PM   #6
arrowscooby
Member#: 176615
??? sleeper
rex
use tin snips
arrowscooby is offline   Reply With Quote
Old 09-03-2008, 11:55 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It's not essential in the way that a driver's seat is not technically essential to drive your car.
Old 09-04-2008, 12:40 AM   #8
Sleepr56
Member#: 67326
2015 WRX Limited
fair enough.
Old 09-04-2008, 12:45 AM   #9
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I used a dremel and a cut-off wheel. Than de-burred it.
rexman2002 is offline   Reply With Quote
Old 09-04-2008, 01:30 AM   #10
Shamoo
Member#: 188107
2007 STi. [email protected]
Green Wheelz
I used a jigsaw with a fine-toothed metal blade.. than a file to de-bur it. Never thought about spraying it with some high-temp enamel, sounds like a great idea though.
-shamy.
Shamoo is offline   Reply With Quote
Old 09-04-2008, 01:33 AM   #11
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
I used voodoo and seven kinds of rubbing salts.
Old 09-05-2008, 08:32 AM   #12
jheeno
Member#: 177805
2007 WRX
I happened to be doing this task whilst fitting my blouch td05h-18g 7cm housing
I used a saw and for bigger chunks I drilled holes progressively until i could bend it off cleanly and file the sharp drilled edges
pictures below outline the culprits to why it wont fit
1. down pipe bellmouth is bigger
2. turbo clip
3. boost actuator to wastegate flap connection
Front Towards Turbo Inlet
Rear facing Down Pipe
^^^Note stock downpipe is half of what it should be to what I had to cut below
Final Product
Diverting from the topic
Life is harder for Right Hand Drive cars
as the steering knuckle + brake booster gets in the way of any twist mount/external waste gate products from the lovely US of A
jheeno is offline   Reply With Quote
Old 09-05-2008, 04:47 PM   #13
wrxSIN
Member#: 157818
did you do your
kegels today?
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 2_0_2 like Mac OS X; en-us) AppleWebKit/525.18.1 (KHTML, like Gecko) Version/3.1.1 Mobile/5C1 Safari/525.20)
to tell you the truth, I don't think that for a stock turbo, you even need a heat shield. There are of course many websites like scooby mods, Perrin and I belive even turboxs that has directions. Also, some shop would do it for you at a small cost
wrxSIN is offline   Reply With Quote
Old 09-05-2008, 05:42 PM   #14
Wangspeed
Member#: 127985
2005 LGT w/ STi swap
Dominator 3
I disagree. Stock turbos that are being run outside their optimal efficiency range should certainly be shielded off.
Warren
Wangspeed is offline   Reply With Quote
Old 09-05-2008, 10:59 PM   #15
mookies
Member#: 168294
2007 WRX
thanks for all the great input. I'm sure having my heat shield in won't have any negative effects so i'm just going to do it. I don't really have any tools necessary to cut that metal....but a lot of you guys are saying tin snips would be the cheapest/most efficient way of doing the job? I think i'll head over to a store sometime and buy some. hmmm
Old 09-05-2008, 11:02 PM   #16
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
Just go to your local hardware store and ask the guy in the tools department. I'm sure he will have EXACTLY what you need
Spootypuff is offline   Reply With Quote
Old 09-05-2008, 11:07 PM   #17
mookies
Member#: 168294
2007 WRX
sounds like a plan thanks
Old 09-07-2008, 06:06 PM   #18
mookies
Member#: 168294
2007 WRX
do tin snips really work? i just went to ace hardware and asked for something to cut it and the guy said tin snips won't do the job...
and how did you guys file it down?
thanks again
Old 09-07-2008, 06:17 PM   #19
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
I'm stage 2 (tdo4). I have a cut stock heatshield, and Cusco over the stocker. If the car came with an oem heatshield (which imo is better than any aftermarket one) from factory, don't you think it's there for a reason. Aftermarket ones are more of a bling factor imo. Run a cut stock one and either (cobb, cusco, or Spt one over the oem one).
Warren
agreed.
Old 09-07-2008, 06:18 PM   #20
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
thanks again
invest in a dremel. It will come in handy in the future, trust me. Great tool. You can polish, cut, drill, etc, ect..(file, debur).
Old 09-08-2008, 04:31 AM   #21
jheeno
Member#: 177805
2007 WRX
Things I used (it was 9pm at night so didnt get tin snips):
-A drill
-dremel
-big metal file
-pliers
I used the drill and laboriously drilled holes instead of cutting sections. It snapped off easily with pliers.
Metal file to sharpened the drilled section
after the metal file - Dremel to finely file edges
Old 09-08-2008, 09:53 AM   #22
Good2Go
Member#: 100634
04 STi
I used a sheet metal nibbler and a dremel to smooth it out. Went very fast. Tin snip really aren't up to the task.
Good2Go is offline   Reply With Quote
Old 09-08-2008, 08:36 PM   #23
WRKX
Member#: 28402
2005 STI
CGM
Tin snips worked fine for me.
WRKX is offline   Reply With Quote
Old 09-08-2008, 08:46 PM   #24
toutanje
Member#: 153465
2004 Suzuki GSXR 600
WRX now FS!
die-grinder with metal cut off wheel ftw!
Done in under a minute.
toutanje is offline   Reply With Quote
Old 09-08-2008, 10:51 PM   #25
cpelton
Member#: 168543
2011 STI hatch
Satin White Pearl
Pneumatic nibbler and a file to deburr took 5minutes
cpelton is offline   Reply With Quote
how much is a *new* stock turbo heat shield jobber Private 'Wanted' Classifieds 8 08-01-2008 11:37 PM
WTB: Cut Stock Turbo Heat Shield DUB03REX Private 'Wanted' Classifieds 9 07-22-2008 01:08 AM
Perrin Inlet, Modded injectors, Cusco turbo heat shield subalou1 Private 'For Sale' Classifieds 2 04-15-2006 01:41 AM
How do you know if your stock Turbo is gone? superstud General Community 23 12-07-2004 05:07 PM
Stock turbo heat shield fits IHI turbos? skycruise Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2004 12:29 PM
