Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > 1993 - 2001 Impreza Specific Parts
Old 09-05-2008, 05:24 AM   #1
awd4ever
Member Sales Rating: (8)
Member#: 31573
I found the
meaning of life!
Impreza GC8 WA: Massive Garage Cleanup
Proceeding with "project clean up"
Last update: Feb 09 - Many pices updates.
note: please dont email or ask for items not listed.
Will consider all reasonable offers or trades.
Pictures: http://s110.photobucket.com/albums/n...ale/?start=all
  • ENGINE STUFF:
    Starter - Auto '95 1.8 - 75k miles (possibly 10k miles but I have no proof) -- $40
    Fuel pump - 1998 - 2.5 RS, 60k miles -- $ 45
    1999+ RS etc.. Panel Filter K&N almost brand new (1k miles) - $35 (52+ in store)
  • Spark plug wires:
    1995 - 1.8l - Bosch Ultra premium 7mm -- $30
    2000 - 20k miles - Packard (probably stock) -- $30
    2000 - Magnacore KV-85 (3k miles old) -- $50 (paid $85)
  • Clutch:
    Master clutch cylinder - 1998 2.5 rs- under 15k -- $40
    clutch line - 1998 2.5 rs -- $ 5
    Slave clutch cylinder - 1998 - under 15k -- $40
  • Accesories:
    Pressure Plate 2001 - 25k miles -- $50
    Power steering lines 98 -- $25
  • shifter knob - 2000 Impreza RS shifter. 25k miles -- $20
  • ELECTRICAL:
    2000 Complete wiring harness Completely uncut, headlight to tails. Comes with ECU (5sp), fusebox, JC torque chip spliced in ( 12 HP). -- $ 350
    --2000 ECU 5-speed. Only if separated from harness -- $100
    --JC Torque chip v.2 - adds 12 hp. (i believe this is identical to PRO ECU - made by same people) -- $100
    --harness with out ecu / chip : -- $280
    -- average shipping for the whole thing is $55
  • Drivetrain (front):
    Axles:
    2 x Awd front axles from AWD 2000 / 25k miles -- $55 (each)
    Cross member (aka: T-bone) 2000 - 25k. -- $30
    Front control arms - 2000 - 25k - $70 each
    Front control arm bushings 2000 -15k. L & R. (Perfect upgrade for pre 1999.) -- $ 30
    Rear trailing links 2000 RS - 25k -- $45 each.
  • Steering:
    Rack & Pinion 2000 - 40k - one bent tie rod (aka: steering rack) -- $55
    Front ABS sensors - 2000 rs - 25k miles - $ 25 each
    Rotors:
    Rear rotors x 2 2000, under 15k -- $20 each (about $30 shipping.)
  • INTERIOR:
    Front dash 2000 - under 30k, gauge cluster included, all wires, airbag, vents, top pocket..) $350
    --can separate:
    -- dash alone - $120
    -- gauge cluster $110
    -- wiring harness $60 (including airbag harness)
    -- top center pocket - $50
    -- vents - $20 each
    -- whatever's on the dash.
  • Driver side mirror 2000 - Auto / electrical, Silver -- $60
    Doorhandles (outside) 2000 - L & R - Silver. No scratches . -- $ 30 both
    E-brake handle 2000 rs, black (with ebake cable splitter) -- $25
    Lower driver side dash cover (part that holds foglight & cruise switches) -- $ 30
    --switches -- $ 15 each. ($25 together)
  • Steering wheel 2001 RS - 25k miles - red stitching, airbag. -- $100
    -separated:
    -- Steering wheel: -- $60
    -- Airbag -- $ 60
    Complete steering hub 2001 - everything from behind the wheel to steering column including all electrics -- $ 100
    -- shipping will be around $90
Stereo:
  • Rear: Pioneer 4-way 200w 4 Ohm (TS-A6976)-- $ 30 both
    Front: Pioneer 2-way 100w 4 Ohm (TS-A1385) -- $ 30 both
    Pioneer 6-disk CD changer -- $ 70
    Tweeter (2k) -- $ 12
    Door Wiring harness with wiring for tweeters and power mirrors. -- $ 15
  • UNCATEGORIZED
  • Fuel evap canister - (aka: charcoal canister - 2k, 25k miles ) with everything, including all hoses, mounting, sensors. -- $ 60
    Wiper motor - 2k rs - 25k miles-- $ 30
    Wiper motor - '95 - 70k miles -- $30
    98 fog light -- $50 both
    unknown year fog light -- $ 40 both
awd4ever is offline   Reply With Quote
Old 09-05-2008, 12:56 PM   #2
Aaron'z 2.5RS
Member Sales Rating: (21)
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I apologize, again, wasn't trying to dump.. or get you to change prices.. just layin down what I know..
Last edited by Aaron'z 2.5RS; 09-06-2008 at 02:53 AM. Reason: Being a tool, I guess..
Old 09-05-2008, 03:01 PM   #3
awd4ever
Member#: 31573
I found the
meaning of life!
Thanks Aaron. I lowered a price a little.
Napa sells A1 brand for 95.79, while the dealer sells OEM for 369.96.
Between the two, I think low mile OEM axles are an excellent middle ground.
Old 09-06-2008, 01:13 AM   #4
awd4ever
Member#: 31573
I found the
meaning of life!
bumppy (updates)
Old 09-06-2008, 01:20 PM   #5
aznguy0087
Member Sales Rating: (1)
Member#: 166010
2000 Legacy
would you know if th ac pump would fit 95 lx?, if so how much shiped to 21043??? thank
aznguy0087 is offline   Reply With Quote
Old 09-06-2008, 07:11 PM   #6
awd4ever
Member#: 31573
I found the
meaning of life!
You got PM.
and pump
Old 09-24-2008, 01:24 PM   #7
dan4bossox
Member Sales Rating: (13)
Member#: 114672
2001 Impreza 2.5 RS
Blue Ridge Pearl
What size is the RS RSB?
dan4bossox is offline   Reply With Quote
Old 09-24-2008, 10:28 PM   #8
rsverv
Member#: 126532
MY01 GC8
interested in ps (power steering) pump. pix to pvang@hotmail.com and how much shipped to 55130?
rsverv is offline   Reply With Quote
Old 09-25-2008, 05:03 PM   #9
wishicoulddrift
Member#: 161015
You have a PM.
wishicoulddrift is offline   Reply With Quote
Old 09-26-2008, 11:24 PM   #10
rsverv
Member#: 126532
MY01 GC8
pm'd...
Old 09-28-2008, 03:09 AM   #11
wishicoulddrift
Member#: 161015
This add still running, i have heard nothing back...
-Stephen
Old 09-28-2008, 11:44 AM   #12
rsverv
Member#: 126532
MY01 GC8
+1... pm's haven't been replied
Old 09-29-2008, 06:28 AM   #13
minhha2006
Member Sales Rating: (4)
Member#: 154914
2005 WRX
UGM
same here.... all i want is the set of fogs
minhha2006 is offline   Reply With Quote
Old 09-30-2008, 06:12 PM   #14
wishicoulddrift
Member#: 161015
knock knock! who's there? NO ONE! ^_^
I needs me an RS steering column!
Old 02-02-2009, 01:57 AM   #15
azn0boi04
Member Sales Rating: (45)
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
pmd about shift linkage
azn0boi04 is offline   Reply With Quote
Old 02-02-2009, 04:02 AM   #16
wishicoulddrift
Member#: 161015
pm'ed again
Old 02-17-2009, 10:22 PM   #17
ylfotevoli
Member Sales Rating: (3)
Member#: 162601
01 RSTi
PM sent
ylfotevoli is offline   Reply With Quote
Old 02-18-2009, 11:03 AM   #18
handyRS
Member Sales Rating: (56)
Member#: 51712
pm sent!
handyRS is offline   Reply With Quote
Old 02-19-2009, 01:18 AM   #19
can'tread503
Member#: 187181
93 maroon impreza
maroon
i would like to buy the gauge cluster if u still have it???
can'tread503 is offline   Reply With Quote
Garage Cleanup, Make An Offer former3g 1993 - 2001 Impreza Specific Parts 11 06-13-2009 09:43 AM
Garage cleanup... Lots of OEM parts.. go1d1e MWSOC Private Classifieds 13 12-16-2008 10:56 PM
MD. Partout. Garage Cleanup. 2006 WRX. AST. Greddy. SSR. COBB. DEFI. GregsblueRex Engine/Power/Exhaust 33 09-19-2007 08:49 AM
Garage Cleanup - mostly stock 2000 RS parts awd4ever NWIC Private Classifieds 6 09-19-2006 03:36 PM
Post project garage cleanup - Here today, friday ebay. awd4ever Private 'For Sale' Classifieds 4 10-06-2005 01:27 AM
Message Board Statistics All times are GMT -4. The time now is 09:47 PM.
