Old 09-05-2008, 03:31 PM   #1
MrMakesitRain
Member#: 168333
2006 STi
CGM
Default Searched: How to change an accessory belt for 02 wrx..
Hey guys i already searched but couldn't find any threads showing how to change the accessory belt. i just got it in from mach v and would like to install it soon. any helpful links/tips/tricks? thanks in advance.
MrMakesitRain is offline   Reply With Quote
Old 09-05-2008, 05:17 PM   #2
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
It's the one that the alternator is attached to it, right? Just unbolt the timing cover then take off the horizontal bolt holding the alt in place. If the belt is now loose enough, unbolt the alt and take it out. You should def be able to take the belt off if you do that. When you put everything back on. get the slack out of the belt by tightening the long vertical bolt on the alt. Tighten everything up and you should be good.
wrxskier18 is offline   Reply With Quote
Old 09-05-2008, 06:47 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
www.scoobymods.com
Learn it, live it, love it. It's a butt simple install.
And check the Maintenance FAQ in the Service Forum as I might have a direct install linked inside of there.
Old 09-05-2008, 07:35 PM   #4
notsosimple
Member#: 179937
Just one edit to your post, it is the belt cover, not the timing cover. Other than that you have it right.
notsosimple is offline   Reply With Quote
Old 09-05-2008, 08:05 PM   #5
MrMakesitRain
Member#: 168333
2006 STi
CGM
i checked scoobymods already. there was one thread where a dude asked for help with it and said he had a diagram but didnt post it up. and had a problem but fixed it on his own.
Old 09-05-2008, 09:48 PM   #6
MrMakesitRain
Member#: 168333
2006 STi
CGM
i unscrewed the long belt and the other locking bolt but i cant push the alternator anywhere to get slack like in this video...http://videos.hspn.com/?videoid=65&catid=1
any ideas? i actually broke the long belt.
Old 09-05-2008, 09:55 PM   #7
tabrad
Member#: 157229
02 WRX
Just look around and see if there are any other bolts to undo that seem logical, I was able to do this without any instructions when I changed my power steering, didn't seem hard
tabrad is offline   Reply With Quote
Old 09-05-2008, 09:57 PM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Old 09-06-2008, 03:07 AM   #9
MrMakesitRain
Member#: 168333
2006 STi
CGM
haha so i broke a bolt, turns out the belt i really needed to replace was the power steering/alternator belt and i had ordered the a/c belt.
i drove to napa and got the ps belt, went to orchard to get a replacement bolt but couldnt find any correct length thread size and thickness. got one pretty damn close i thought id try so i bought that and 2 nuts to ghetto rig it together.
it didnt work. so i went back to osh and got a smaller bolt, some washers and nuts to ghetto-er rig it.
got everything on and by this time it was pitch black outside and i started the car and it sounded like tweety was in my engine bay, hella chirping. turns out my ac belt was rubbing on my alternator. fixed that and now its cool.
so tomorrow im going to take everything back apart and replace the ps and ac belt and i think ill take pictures along the way to help make a tutorial so someone doesnt run into the same problem as me. thanks for all the help though!
How do I change the accessory belts in 03 wrx? Lordhowe Service & Maintenance 12 06-04-2009 03:43 PM
Help on how to change an slternator belt. h.a.r.t. ej20wrx General Community 2 05-22-2007 08:04 PM
Like to buy an TMIC local for 02 wrx, WPB FL, anyone selling? DLBWRXR South East Region Forum 0 01-20-2006 03:29 AM
How to change an fuel filter on an '02 wrx wagon d4ygl0 Service & Maintenance 19 12-28-2005 02:31 PM
How to make an intercooler sprayer for the WRX for under 40 bucks! Blugin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-01-2001 02:17 AM
