Old 03-14-2002, 03:30 PM   #1
DannyGT
Member#: 6281
2002 Impreza WRX
Graphite Pearl - SOLD :(
Default Question on the KYB-AGX strut...
I know how to adjust the rears, but how can i tell which level the front are in ? which direction are the numbers supposed to face in order to be that setting, and how do i adjust the front ?
DannyGT is offline   Reply With Quote
Old 03-14-2002, 04:53 PM   #2
DannyGT
Member#: 6281
2002 Impreza WRX
BUMP -- C'mon lets wrap this up, some 1 give me the answer...I know some 1 knows this....
Old 03-14-2002, 05:01 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
The fronts are easier to adjust than the rears.....
Fronts are adjustable from 1 to 4 where 1 is the softest setting and 4 the hardest.....
Convenient external dial or slot at top of rod (depending on model) allows for simple hand adjustment of the damping forces for strip, street, cruising, or high speed driving. Eliminating the need to remove parts or lift the vehicle.
Robin
Robin2 is offline   Reply With Quote
Old 03-14-2002, 05:59 PM   #4
Hozay
Member#: 1248
04 Impreza WRX STi
Java Black Pearl
Smile
a little screwdriver slot at the top of the strut piston.
white dot aimed at the current setting.
insert screwdriver, push down (important) and rotate to the desired setting.
i don't think its a good idea to go across the 1 to 4 setting. better to go 1,2,3,4 or vice versa.
Hozay is offline   Reply With Quote
KYB AGX strut question? woods Brakes, Steering & Suspension 3 07-11-2008 05:16 PM
anyone know about the KYB agx struts? peddlerex Brakes, Steering & Suspension 2 03-03-2005 01:01 PM
question about kyb agx struts MtlPete Brakes, Steering & Suspension 10 01-26-2005 08:30 PM
Question on KYB AGX struts? Polar Bear Brakes, Steering & Suspension 5 07-09-2001 05:37 PM
Questions on the KYB struts kappa652 Legacy Forum 8 11-01-2000 06:49 PM
