Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 09-07-2008, 09:52 PM   #1
mtrdrms
Member#: 186888
2000 Outback
Default 2.5 interchangeablility
Hey guys. I've been asking around here and have gotten some mixed messages but I am hoping someone can tell me if a 2007 2.5 from a legacy will bolt into my 2000 Outback? My engine is smoked and I found a great deal on a 2007 2.5 with 22k. What will I have to do make this swap possible?
Edit: Sorry I should have clarified, I know the engine will bolt up as per moderators sticky but I am wondering if the wiring harness will work with the 07 sensors or will I have to swap manifolds, heads, accessories, etc.
Thanks
Andy
mtrdrms is offline   Reply With Quote
Old 09-08-2008, 12:17 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
they are both Phase II blocks. you should be able to just use the long block from the 07 and keep the intake and all from your 00.
i beleave your intake will bolt up to the heads.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 09-09-2008, 12:45 AM   #3
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
from my knowledge with the harness situation from the facts i've found you shouldn't have but dont quote me i think you should just need a little Engine management maybe a reflash but like i said don't quote me
bugeye-brawler is offline   Reply With Quote
Old 09-09-2008, 11:12 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm not sure I could quote you even if I tried! I'm not even sure if that was English.
Andy, I think you would probably have to swap your intake and heads onto the '07 shortblock. The reason I say that is due to the fact the '06+ engines have iAVLS on the intake cams, so the heads and cams are different.
It may be that your '00 intake would bolt onto the '07 heads - I'm not familiar enough with the bolt patterns to say for sure. But that still leaves a couple issues:
(1) What are the crank and cam position sensor trigger patterns for the '07 vs. '00? In particular, the cam position is almost certainly different due to the iAVLS.
(2) Would the car be a dog with iAVLS cams that are (I think) always going to be on the low lift lobes? (Theoretically you could fix that with an RPM trigger switch that would trigger the iAVLS solenoids. Could be a cool thing to play with, if you're into tuning and experimenting a bit.)
I'd bet you could get some good money for low mileage '07 heads and cams. So I'm thinkin' you should go ahead and buy the engine, swap the heads and intake, and then sell the '07 parts to recoup your costs.
Pat Olsen
Old 09-10-2008, 08:21 PM   #5
mtrdrms
Member#: 186888
2000 Outback
[quote=Patrick Olsen;23633449]I'm not sure I could quote you even if I tried! I'm not even sure if that was English.
Funny.
Thanks for the great reply Pat. I will keep you informed on what I do and compatability of intake on the new heads.
Andy
2.5 interchangeablility mtrdrms Newbies & FAQs 5 09-07-2008 09:48 PM
Why can't use 2.2 or 2.5 PH1 trans with 2.5 PH 2? rallynutdon Transmission (AT/MT) & Driveline 6 04-02-2003 06:01 PM
('93-'01) Mileage: '02 2.5 worse than previous 2.5? Em Impreza Forum 4 06-14-2001 01:39 PM
ROAD TEST: 2001 2.5 RS VS 2002 2.5 RS WantaSubaru Normally Aspirated Powertrain 4 06-11-2001 09:05 AM
Gasket for 2.5 Mid-Pipe to 2.5 Down Pipe? yebokmj Normally Aspirated Powertrain 4 03-02-2001 06:53 PM
