Old 09-08-2008, 04:27 PM   #1
#522
Member#: 2185
01 RS
swirly blue
Default Map Sensor Voltage Clamp Question
I have seen various voltages specified for this when running forced induction. It has no effect on timing in the 4v-4.7v range, but does effect fueling.
My question is: Am I supposed to clamp it at the voltage it registers at 0 PSI, or just clamp it around the 4.7 mark to prevent the CEL? My Sensor is at 3.85 at 0 psi/atmosphere. I was never to clear on this.
Thanks,
Ron
#522 is offline   Reply With Quote
Old 09-08-2008, 07:18 PM   #2
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
I wouldnt use a voltage clamp at all. Its not very safe or effective.
Chocoholic005 is offline   Reply With Quote
Old 09-08-2008, 07:50 PM   #3
#522
Member#: 2185
01 RS
swirly blue
True, I am using an E-Manage Ultimate to do this, so not just the regular voltage clamps. I am just wondering if it is the goal to stop the voltage right before the ca sensor max's out, or to clamp voltage just as the car sees 0 psi.
Old 09-08-2008, 09:29 PM   #4
bubba2533
Member#: 175483
97 N/A w/ MS3
Aegean Blue
Well really it is up to you.
You could clamp it when you see boost, then tune with the greddy map sensor.
Or you could clamp it right before it maxes out then tune with the greddy map sensor.
Either way you are just doing it just so the stock ecu doesn't freak out.
Are you maxing out the stock maf right now?
I'm assuming you are using the stock maf also...
Do you have the Greddy map sensor?
bubba2533 is offline   Reply With Quote
Old 09-08-2008, 09:45 PM   #5
Brydon
Member#: 107569
1998 Forester S
SRP
Since he has an 01 RS. I guessing he isn't worried about a MAF. Since it's a MAP car.
Brydon is offline   Reply With Quote
Old 09-08-2008, 10:51 PM   #6
#522
Member#: 2185
01 RS
swirly blue
Sorry, I should have included more details, but yes, 01 RS, MAP sensor stock with Emanage Ult with greddy map sensor to tune boost. I have more info in the Emanage Ultimate on MAP based RS's thread as well.
I was just wondering if there was any advantage to either method. Didn't know if it was better to take the factory ecu and MAP sensor out of the equation once into positive manifold pressure and take over from there with the EMU, or let it do it's thing until it reaches max voltage and then take over.
Thanks.
Old 09-08-2008, 11:58 PM   #7
bubba2533
Member#: 175483
97 N/A w/ MS3
Aegean Blue
oh ok, yeah i forgot about the whole map car thing.
I wouldn't really think that it would make any difference either way you did it. But I have never done it so I'm not positive.
The greddy sensor might be less accurate then the stock one because it covers such a large range of pressures...so it might be beneficial to use the stock map until it almost reaches max voltage
Old 09-09-2008, 01:56 AM   #8
morrocco88
Member#: 104098
1997 LGT 2.1 stroker
Rotated S200SX-56 6speed
How are you maps set up? Map voltage vs. RPM, or Boost vs. RPM?
I would think you would want Boost vs. RPM and then cap the MAP voltage at 0 psi. This way your ECU thinks your humming along at that steady state and just run timing and fueling off the greddy map sensor in boost.
I don't know for sure though because I have a MAF car, but this is how I would try it and see how it works.
morrocco88 is offline   Reply With Quote
Old 09-09-2008, 12:27 PM   #9
#522
Member#: 2185
01 RS
swirly blue
Thanks. I saw that you did that on your MAF car (morrocco88) and had good results.
Old 09-10-2008, 10:34 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The most important thing here is to clamp it before you hit 5psi. The reason for this is that is the point at which the voltage you will pop the MAP. Once you do that, the car will run like crap because the ECU throws it into limp mode. Optimumly you want to clamp it low enough that it won't pop the CEL.
Matt Monson is online now   Reply With Quote
Old 09-10-2008, 11:28 PM   #11
Brydon
Member#: 107569
1998 Forester S
SRP
4.7 volts on a 2000/2001 RS
Old 09-10-2008, 11:52 PM   #12
#522
Member#: 2185
01 RS
swirly blue
ok, so it is let it do it's thing until 4.7 and then clamp it, what I figured but just wanted to be sure. I guess I was overthinking it. Good to know it will actually damage it if the voltage exceeds 4.7.
MAP sensor voltage @ idle? Pi7467mp Normally Aspirated with bolt-on Forced Induction Powertrain 17 12-15-2004 03:35 AM
Help me!! stock MAP sensor voltage w/ Key on? Pi7467mp Rocky Mountains Impreza Club Forum -- RMIC 0 09-16-2004 09:40 PM
map sensor voltage Nick M Factory 2.0L Turbo Powertrain 8 06-21-2004 11:18 AM
turbo and voltage clamp questions lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 6 07-24-2003 09:23 PM
Reading Boost from MAP sensor voltage? midlifecrisis Factory 2.0L Turbo Powertrain 14 11-12-2001 07:31 PM
Message Board Statistics All times are GMT -4. The time now is 03:39 PM.
