Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 09-10-2008, 04:25 PM   #1
Skin Irritant
Member#: 157208
2006 Wrx TR Wingless
Default High flow down pipe catted on 06?
Does the 06 wrx have catted up and down pipes? How can I get the high flow while still meeting emissions??
Would an access port regulate the car to pass the emissions test?
Skin Irritant is offline   Reply With Quote
Old 09-10-2008, 04:27 PM   #2
jack klompus
Member#: 152885
2014 Malibu LTZ
Technically, altering the factory cats is illegal in the first place. High flow cat or not.
Yes, the CEL can be deleted and if you dont have a sniffer test, you will pass.
jack klompus is offline   Reply With Quote
Old 09-10-2008, 04:41 PM   #3
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
2008 Blue Kawi ZX-10R
Your up pipe is not catted and your downpipe is catted. Yes the AP does have a feature to turn off any CEL so if your emissions is ODBII only, then you should pass with flying colors.
ammo0000 is online now   Reply With Quote
Old 09-10-2008, 05:31 PM   #4
Skin Irritant
Member#: 157208
"ODBII only" Not sure what that means
Old 09-10-2008, 05:36 PM   #5
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
There is an OBDII port right under your steering wheel. It's shaped like a rectangle that's short on one side. Anyways, some states only use a machine that plugs into this port and connects to the car's computer to check for any CELs the car may have. If you don't have a cat, then your car will produce a CEL that the inspectors machine can read. It will see that you're O2 sensor isn't working(even though that's not the case) and they will fail you on your inspection. However, the AP turns off the CELs so that the OBDII reader can't see them, thus giving you a pass.
Old 09-10-2008, 05:55 PM   #6
Skin Irritant
Member#: 157208
Out here in utah, they do a visual inspection as well as the sniffer test, so I think i have to have something on there to make sure i pass.
Old 09-10-2008, 06:15 PM   #7
bulletproof4130
Member#: 173704
07 No Show and No
Go 2.5 N/A
How often do you have to go through inspections?
bulletproof4130 is offline   Reply With Quote
Old 09-10-2008, 06:47 PM   #8
ammo0000
Member#: 175401
2007 VF39'd OBP WRX
I'm in UT as well . I've only been here 3 months though, so I didn't even know that lol. Also, to answer your original question about getting high flow cats, I'm pretty sure that the cat is all one piece with the downpipe. I can't remember for sure as it's been a while since I've looked at my stock pipe, but just grab an aftermarket downpipe with a highflow cat and you shouldn't have any problems with emissions plus you can run stage 2. It's true what everyone says about stage 2 being night and day from stock. I'm running the TXS catted stealthback and I don't smell any odor from the exhaust.
Old 09-10-2008, 06:50 PM   #9
drkramm
Member#: 159156
2007 wrx
wrb
you can get a non catted downpipe and weld in a high flow should stil pass a sniffer unless they are really strict
drkramm is offline   Reply With Quote
Old 09-11-2008, 10:08 AM   #10
Skin Irritant
Member#: 157208
emissions every year. Safety every two years.
Old 09-11-2008, 10:34 AM   #11
jack klompus
Member#: 152885
2014 Malibu LTZ
My aps is a 3 piece DP where the center pipe can be replaced with a APS, or any other high flow cat.
Old 09-11-2008, 03:21 PM   #12
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
If you want to go catless, do it. Then once a year swap the stock DP back on. It only takes an hour to do once you have done it once already really.
Defiant Autospeed is offline   Reply With Quote
f/s ca 04 sti down pipe, cat pipe, mid pipe 949 Private 'For Sale' Classifieds 0 04-16-2005 01:09 PM
sti down pipe, cat pipe , mid pipe 949 Private 'For Sale' Classifieds 2 02-01-2005 04:34 PM
TurboXS Down Pipe, Cat Pipe, and Mid Pipe rideboarderferg Private 'Wanted' Classifieds 0 11-06-2003 09:15 PM
wanted: sources for pre-made subaru-specific high flow catalytic pipes ciper Normally Aspirated Powertrain 18 12-25-2002 09:20 PM
Down pipe, cat or no cat? YJGUY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-19-2002 08:43 PM
