Closed Thread
Old 09-10-2008, 06:07 PM   #1
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
Default 3.90 r160 users chime in
I can't seem to locate a 3.90 ring and pinion . Where did you get yours and how much did it cost + installation
smileyou is offline
Old 09-11-2008, 10:09 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
the 91-94 turbo legacies AT & MT, 92-94 non-turbo legacy AT had a 3.9 final drive ratio and would have the a 3.9 rear diff. There's a few imprezas too that have a 3.9 final drive ratio as well.
Legacy777 is offline
Old 09-12-2008, 02:57 PM   #3
MrPhiscal
Member#: 47843
www.subaruparts.com
part # 38104AA010 526 plus shipping . Or try local with the part number
MrPhiscal is offline
Old 09-12-2008, 03:14 PM   #4
swiftwrx06
Member#: 130897
2006 6 speed WRX 18G
330awhp 355ft/lbs
If your interested i have a 3.9 r160 lsd that was rebuilt after coming off an older legacy. I had it on my car for less than 10k miles before i swapped in the r180/brembos.
swiftwrx06 is offline
Old 09-12-2008, 07:53 PM   #5
smileyou
Member#: 152045
2003 PIA wrx
Now that's what I wanted to her =) sent pm. Let me know what you guys got
smileyou is offline
Old 09-13-2008, 09:27 PM   #6
swiftwrx06
Member#: 130897
330awhp 355ft/lbs
pm replied to
Old 09-14-2008, 11:47 AM   #7
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
i bought my 3.90 from ds1 motorsports. installed myself with some cryofitting
Dubstar112 is offline
Old 09-14-2008, 02:49 PM   #8
smileyou
Member#: 152045
2003 PIA wrx
What did you buy. The ring and pinion on the whole 3.9 diff???
smileyou is offline
Old 09-14-2008, 05:31 PM   #9
Spiider
Member#: 13680
I'd assume when he mentions cryo fitting, he is talking about installing the 3.90 ring onto his diff.
You can "home cryo fit" by putting the ring on a hot plate and the diff in the freezer. The thermal expansion coefficient of steel is ~11-12ppm/Degree C.
So if the ring was say 150 degrees and the diff was 0, you could get a substantial enough size difference to be able to slip fit it instead of pressing it on.
Just don't fool around too long getting the orientation correct or it will be stuck.
Spiider is offline
Closed Thread
WTB: R160 3.90 rear differential or 3.90 R160 ring and pinion aboothman Private 'Wanted' Classifieds 3 04-18-2010 01:59 AM
Setting a 3.90 ring and pinion in a r160? D Money Transmission (AT/MT) & Driveline 35 07-07-2006 07:23 PM
WTB: Automatic driveshaft, 6MT shift linkage, and 3.90 R160 D Money Private 'Wanted' Classifieds 9 06-05-2006 06:08 PM
3.90 R160 diff blackbart Private 'For Sale' Classifieds 1 01-30-2006 03:41 PM
What models have a 3.90 R160 diff? fragment Transmission (AT/MT) & Driveline 3 03-17-2004 06:32 PM
