Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 12-15-2009, 03:36 PM   #76
Trierry09
Member#: 225644
Trie http://tierussi
Trierry09
Default FineLine 2006STI APS TSR 70 Reverse Intake Manifold
How was the car running on the magnus intake mani? Ive heard some good/bad things about their manifold. Will the new build retain the same manifold or are you guys going with something different?
Any chance you guys could post a mod list of what we shoudl expect with this build or will that be posted step by step as the build goes on?
Thanks,
-Greg
Trierry09 is offline   Reply With Quote
Old 01-12-2010, 08:04 PM   #77
boardinshorty81
Member#: 174965
07 WRX VF43
Any updates on this car? More mods, or a dyno run?
boardinshorty81 is offline   Reply With Quote
Old 02-12-2010, 08:46 PM   #78
Fine Line Imports
Member#: 81166
2008 Forester
ask and you shall receive.
Event: dyno pull
Ambient Temp: 65
Elevation: feet above sea level
Weather: overcast
Tires: 225/45/17 Bridgestone
Car: year, model
Tuner: Miles Hechtman from Fine Line Imports
Dyno Info: Mustang MD500 AWD
Peak HP at RPM:503whp
Peak Torque at RPM: 468
Baseline: Stock STI 245whp 240 torque
Target Boost: 30 psi tapering to 28psi
Fuel: E85
Engine/Power Modifications: COBB pro series short block, cobb pro series stage 2 heads, cosworth 278 cams, APS TSR 70 rotated turbo kit, APS FMIC, APS BOV, APS 3.5in TBE, APS fuel rails, APS TGV deletes, APS aux fuel rails, APS main fuel rails, PE 850 CC inj x4, Bosch 600cc inj x4, Aeromotive A1000 fuel pump, wallbro fuel pump, FLI surge tank, Aeromotive FPR, FLI reverse intake manifold pipeing, Aeroquip fuel lines, Link G4 stand alone ECU, Aquamist HFS 6 kit and a spec C ic spray tank.
Driveline: ACT 6 puck clutch with light weight fly wheel.
Suspension Modifications: KW varient 3 coilovers, COBB front and rear swaybars, Whiteline ALK
After a long build up of this 2006 STI it is finally complete. Overall this is one of our favorite engine builds of recent memory. With a great power band and excellent topend this car is truly a blast to drive.
For more info on this car check out our blog at http://fliblog.wordpress.com/categor...owered-06-sti/
Ryan
Fine Line Imports
www.finelineimports.net
Fine Line Imports is offline   Reply With Quote
Old 02-13-2010, 06:55 AM   #79
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
why is it only reving to 7k????
bmxhotsauce is offline   Reply With Quote
Old 02-14-2010, 12:15 AM   #80
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
^^^ +1
wrblueballs is offline   Reply With Quote
Old 02-14-2010, 03:25 PM   #81
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
i have a fully built motor too and my car is reving to 7500 and my power never dies off
Old 02-15-2010, 04:14 PM   #82
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
Nice build.. she seems to be holding power pretty well too! I bet it's a blast to drive! I want updated/completed pix.
AlxSti is offline   Reply With Quote
Old 09-25-2010, 12:47 AM   #83
boostcut
Member#: 258879
09 sti
why are you still using a afm when using the link g4?
you dont need them...
boostcut is offline   Reply With Quote
Old 09-25-2010, 10:41 AM   #84
fourmicah
Member#: 128760
2015 STI
300 WTQ at 3400 RPM's and 400 WTQ at 3850, very impressive! What do you attribute the spool to? I don't think I've seen a turbo that big, spool that quick in a while.
fourmicah is offline   Reply With Quote
Old 09-26-2010, 12:55 AM   #85
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
videos please.
maxpowr is offline   Reply With Quote
Old 02-17-2011, 02:16 PM   #86
tasroadster
Member#: 238288
Awesome............
tasroadster is offline   Reply With Quote
Finally Finished: TSR-70 Kit, Cosworth Manifold, Build Motor + MORE Mac323 Member's Car Gallery 35 03-12-2010 10:23 PM
For Sale: APS TSR 70 twin scroll turbo kit with intake and full race" reversed piping syoung0298 Engine/Power/Exhaust 25 09-23-2008 04:10 PM
2004 STi with APS TSR-70 -- 11.33et @ 127.92mph Dasani Proven Power Bragging 72 06-08-2008 12:34 AM
Aps TSR-70 ?'s Que Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-16-2008 06:21 PM
Turbine inquiry about APS TSR 70 Twin Scroll Turbo Kit... nomorem3 Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-11-2006 03:59 PM
