Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-21-2008, 11:39 AM   #51
parkes
Member#: 166898
1994 T leg SS
ABM
So if i buy this cam gear sensor from Subaru and get a new walbro pump, im assuming the cam gear sensor wont just plug in to my harness if not can i splice it into my ECU stock cam plug in and call it a day?
parkes is offline   Reply With Quote
Old 09-21-2008, 12:31 PM   #52
roostema4328
Member#: 174901
1989 RX coupe
black
Check to see if you put the right pulley on the cam sensor side. If the pulley that goes in front of the cam sensor doesnt have the cogs on the back for the sensor to read it will not run. the rest of the pulleys dont have them. Also check the crank gear to see if all of the tabs are still on. I have seen a few that have been dropped and broke a tooth off then it will not run. because the crank sensor will not know where the crank is anymore.
roostema4328 is offline   Reply With Quote
Old 09-21-2008, 06:14 PM   #53
parkes
Member#: 166898
1994 T leg SS
ABM
Thanks for the info, I bought this moter from a Guy who knew what he was doing unless he decided to huck the moter around before i bought it, The guy knew what he was doing and i went to go see the moter running in person, The only sensor i changed (other than swapping my harness over) Was the Cam gear sensor, So if the Cam gear sensor im getting from subaru is not a direct swap( plugins) would it be okay to swap it over as in just splice my plugin onto it? Because its just wire right? And it sends the code through the magnet doohickey in the cam gear sensor and The ECU just recieves and interpretes it right?
Thanks for the good info though, very appreciated.
Old 09-22-2008, 12:56 PM   #54
parkes
Member#: 166898
1994 T leg SS
ABM
looks like the cam gear sensor from subaru dosent come with wire, apparently you plug your old one in which isnt to bad, no splicing required.
Also the walbro fuel pump 255lph is going to run me 160$ CAN for one
Old 09-25-2008, 11:05 PM   #55
parkes
Member#: 166898
1994 T leg SS
ABM
WEll i got the cam gear sensor and a new walbro fuel pump, installed fuel pump.
Now what about the cam gear sensor on my EJ22 harness it uses a 2 wire connection near the Throttle body, the EJ25 uses the plug in style( i have an EJ25 harness)
When i cut the EJ22 Cam gear sensor at the end there was only two wires, i followed the original harness to see if the harness split the thrid wire as a ground couldnt find anything, So Two of the colors of wire line up. Then the other wires were Black(EJ25 Cam gear sensor) and white off of the harness EJ22 Harness, I spliced them over thinking nothing of the third wire. It cranks but nothing else, im not even getting Spark anymore, other than the spark, Does anyone have a proper guide of Splicing an EJ25 Cam gear sensor into an EJ22 harness?
Thanks!
Old 09-26-2008, 12:47 PM   #56
parkes
Member#: 166898
1994 T leg SS
ABM
Bump,
Im trying to splice in an EJ25 cam gear sensor into a 94 EJ22T harness! Any one with some good info?
Old 09-26-2008, 01:07 PM   #57
parkes
Member#: 166898
1994 T leg SS
ABM
What is the Shield wire?
Old 09-26-2008, 02:31 PM   #58
parkes
Member#: 166898
1994 T leg SS
ABM
Alright i took the 3 wire connector from my EJ22 harness out to look at it.
I took the protection rubber off of it to follow the wire.
it looks like this:
Red, White and black, All the wires are normal except for black that just twinds around it unprotected.
Here is another loook
The black wire clearly goes unprotected and ends up like that.
This is the Plug from the EJ25 harness for the cam gear sensor.
It only has a White and black connector (Signal + and -?)
Here they are shown side by side
What should i do? I hope the pictures help!
It looks like black and white come from the same location, But what about red?
Old 09-26-2008, 02:55 PM   #59
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
These sensors use shielded wire for a reason. Do you have the full diagram for the engine that you are attempting to run? In your case since you are doing something that is this much of a mix of parts you really need a complete diagram not just a pinout.
Zephyr is offline   Reply With Quote
Old 09-26-2008, 03:02 PM   #60
parkes
Member#: 166898
1994 T leg SS
ABM
I was going to put some Shrink wrap over it when i was done followed by some electrical tape, i understand the importance of their integrity.
I am working with a 1994 Subaru legacy Turbo, To which i have the wiring diagram(maybe i should of looked at that) Using the EJ22T block with
EJ25 SOHC heads, To which i do not have a wiring diagram.
I guess ill take a look at that haynes (forgot i had it)
Old 09-26-2008, 03:14 PM   #61
parkes
Member#: 166898
1994 T leg SS
ABM
Here is a picture from the haynes manual, i have no idea what they are showing a yellow ire for, This is a pinout for an EJ22
If i did have this yellow wire, what is the diagram showing is this what a "Shield" wire is?
Old 09-27-2008, 12:42 AM   #62
parkes
Member#: 166898
1994 T leg SS
ABM
Suggestions anyone?
Old 09-27-2008, 12:58 AM   #63
parkes
Member#: 166898
1994 T leg SS
ABM
I guess ill splice, Black to black, white to white, and leave red hanging since i have no idea what to do with it and in my Diagram it shows it as a yellow wire creating a "Shield" around them, i know i just posted but ive been doing nothing but reserching this and cant find anything!
Old 09-27-2008, 01:30 AM   #64
parkes
Member#: 166898
1994 T leg SS
ABM
I just saw you viewing this thread Silentt(im a stalker) i know we dont have the best past but you know this moter the best and have a wealth of knowledge, what do you think?
Old 09-27-2008, 01:59 AM   #65
silentt
Member#: 119995
2004 Outback XT
Peachy
I think you burned your bridges long ago. It's too bad, your wiring diagram is wrong and good luck getting ahold of the right one.
silentt is offline   Reply With Quote
Old 09-27-2008, 02:05 AM   #66
parkes
Member#: 166898
1994 T leg SS
ABM
Thanks, it says this is the right wiring diagram, for the right car. Im going to try out what i just did and see what happens, cant say you didnt try right?
Old 09-27-2008, 02:15 AM   #67
silentt
Member#: 119995
2004 Outback XT
Peachy
The NA and turbo have different wiring. That's the last of the help you're getting.
Old 09-27-2008, 02:25 AM   #68
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
unplug the MAF sensor wire off the intake and see if it starts. sometime bad MAF sensor cause non start.
qualityracer is offline   Reply With Quote
Old 09-27-2008, 11:37 AM   #69
parkes
Member#: 166898
1994 T leg SS
ABM
Thanks but the Sensor was good before i started all this ill check that very last/
Old 09-28-2008, 07:48 PM   #70
rocky2
Member#: 157684
Default mhcg,
hey parkes,this story is going the wrong way....
if i read corectly,you drive a 94 legacy and you are trying to run that engine with your stock ecu.(ej22t block with 99 impreza sohc heads,94 legacy ecu.what you need to do is take the cam pouley and the crank pouley from the legacy engine,put it on that engine and used the legacy cam and crank sensor.
rocky2 is offline   Reply With Quote
Old 09-28-2008, 08:04 PM   #71
tripleAAA/RRR
Member#: 190423
2002 wrx
blue
sounds like your fuel lines are swaped should go from filter to hard line and the return is off the regulator try swaping lines
tripleAAA/RRR is offline   Reply With Quote
my stupid car wont start! blackwagony Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 10-10-2003 05:40 PM
help my car wont start DDImpreza New England Impreza Club Forum -- NESIC 2 05-27-2003 11:58 PM
help my car wont start DDImpreza Normally Aspirated Powertrain 2 05-27-2003 11:57 PM
my car wont start phestik Newbies & FAQs 8 07-22-2002 06:22 PM
my car wont start - need help phestik Southern California Impreza Club Forum -- SCIC 9 07-22-2002 11:41 AM
