Old 07-25-2009, 12:14 PM   #26
myWRXtacy
Member#: 133711
02 WRX~(sold)
79 Datsun 510 & 00 Fozzy
Ima do it today!!
myWRXtacy is offline   Reply With Quote
Old 07-25-2009, 08:24 PM   #27
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Originally Posted by myWRXtacy View Post
Ima do it today!!
NICE!!
You'll Love it, glad I could help.
JoeSUBARU is offline   Reply With Quote
Old 07-25-2009, 11:19 PM   #28
myWRXtacy
Member#: 133711
02 WRX~(sold)
Originally Posted by JoeSUBARU View Post
NICE!!
Thanx dude piece of cake...10 min done!!
Old 07-28-2009, 11:13 PM   #29
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Tried this a few weeks ago. Nothing. Can anyone verify foglight relay location on 05 Wagon? Is it still third relay from the bottom? I thought 05-07 were the same so i don't know what i did wrong. Will try again soon.
trueno16v is offline   Reply With Quote
Old 08-04-2009, 02:32 PM   #30
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
^ should be the same bro, did you bend the proper contact?
Old 10-01-2009, 03:06 PM   #31
x7742539329x
Member#: 205832
2005 saab 9-2x AERO
black
hey i noticed there was two fuses and was just wondering what size that other fuse is? I can make out the red 10 Fuse but the other one?
x7742539329x is offline   Reply With Quote
Old 10-01-2009, 04:26 PM   #32
littlewhitewagon
Member#: 103068
11 STI sedan
I would have to say that if your fuse box has cables tapped into the fuse holder like in the pictures above, you shouldn't be giving out electrical advice.
I see a T tap and lots of speghetti.
littlewhitewagon is offline   Reply With Quote
Old 10-01-2009, 04:27 PM   #33
littlewhitewagon
Member#: 103068
11 STI sedan
You want to find the relay? Use your finger and put it on the relay you think it is, turn the fog light switch on and off with the headlights on until you find it. Once you think you've found it, pull out the relay and the fog lights will stop working.
Old 10-02-2009, 01:34 AM   #34
myWRXtacy
Member#: 133711
02 WRX~(sold)
Picture says==Originally Posted by JoeSUBARU
Im sure that's the pic from the first page!! I helped my friend and he had more noodles than a Chinese meal box!! it was fun
Originally Posted by JoeSUBARU You are now ready to plug in the Add-A-Circuit. I chose to tap into my rear wiper fuse (seeing that it is a 12v constant) Ideally you would use the Illumination fuse, But I chose the Rear Wiper since it will supply constant power to the Fog switch.
That's a 5! just go by the color.... and as he says to the rear wiper.
Old 10-02-2009, 05:00 AM   #35
MrMakesitRain
Member#: 168333
2006 STi
CGM
question...so i did the scoobymods way. i've run across a problem. when i press the foglight switch while my lowbeams are on the fogs turn on but the beams switch to high beam. they work fine during high beam and during just driving lights.
02 wrx
MrMakesitRain is offline   Reply With Quote
Old 10-05-2009, 10:41 AM   #36
bjaff001
Member#: 192181
2011 WRX Sedan
02 wrx
I have this problem in my 02 as well, but I haven't done the mod yet so obviously they don't work with high beams. I was hoping that by doing this it would get rid of the whole high beam/low beam issue.
bjaff001 is offline   Reply With Quote
Old 10-05-2009, 03:49 PM   #37
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OK......is it just ME or is it a REAL bad idea to have the fogs and hi beams on at the same time
Old 10-05-2009, 05:47 PM   #38
MrMakesitRain
Member#: 168333
2006 STi
CGM
it is which is why my situation sucks. i want the fogs on with lowbeams but they only work with high and driving lights. any ideas?
Old 10-05-2009, 05:49 PM   #39
littlewhitewagon
Member#: 103068
11 STI sedan
It's a good idea if you want to blind people or go driving in dark areas WITHOUT fog. In most states, you can only have 4 main lamps illuminated while driving on a public road. High beams and fog are a definate no-no.
Old 10-05-2009, 06:25 PM   #40
Uncle Scotty
Member#: 16200
OK buy Nates beans
unkiddyify the wiring under the dash
Old 10-06-2009, 02:28 AM   #41
MrMakesitRain
Member#: 168333
2006 STi
CGM
unkiddyify?
Old 10-06-2009, 04:42 PM   #42
littlewhitewagon
Member#: 103068
11 STI sedan
I think you mean un-speghetti mickey mouse ify
Old 10-06-2009, 09:14 PM   #43
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 10-06-2009, 10:55 PM   #44
Stanley072.5i
Member#: 204266
2011 WRX
Ive heard that all you gotta do is pop open your relay and solder a wire across from one prong to another (not exactly sure which ones) and then it will do the same thing and allow your fogs to run independently from your light.
Stanley072.5i is offline   Reply With Quote
Old 10-07-2009, 12:35 AM   #45
MrMakesitRain
Member#: 168333
2006 STi
CGM
uhm my wiring isnt all spaghettiedmickeymousekiddified.
Old 10-07-2009, 12:43 AM   #46
myWRXtacy
Member#: 133711
02 WRX~(sold)
well if you guys followed the instructions as described, then you should NOT have any problems, I did it on 3 subies the exact same way as JoeSUBARU did it, and fogs work all times with low and high beams on... or just the fogs. The only thing is the little fog light indicator goes on and off once in a while... the instructions really indicated that could happen!
Old 11-02-2009, 07:47 AM   #47
rjw5164
Member#: 220239
2002 ej257 WRX
I don't know if anyone has had inspection trouble but I took my jeep in once and failed PA safety inspection because it's illegal for fogs to be on while the high beams are here. Just a heads up for any potential modders. (I did it any way, but inserted a switch as well as the fuse so i can flip it back to legal status when the rex goes in )
rjw5164 is offline   Reply With Quote
Old 11-03-2009, 10:07 PM   #48
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Thanks for backing me up Bud!!
Good thing to keep in mind, Im sure being catless and a lot of other things will help fail inspection also....unless you have a hookup
Old 01-13-2010, 12:43 AM   #49
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
Talking
Wanted to give kudos for DIY!!! +1!
Love it works great looks good, highly reccomended!
Flyin_Hayn is offline   Reply With Quote
Old 01-13-2010, 03:34 PM   #50
shibby2821
Member#: 229778
04 WRX
WR blue
do we need the extra purple fuse or will it run without it?
shibby2821 is offline   Reply With Quote
DIY MY02 fog light cover bracket that work with fog lights installed Darren_2.5RS Mid West Subaru Owners Club Forum -- MWSOC 1 04-23-2014 01:09 AM
diy fog light mod help! blakkboxer Electrical & Lighting 5 04-02-2009 07:46 PM
DIY fog light bulb replacement 04 wrx steakraw Interior & Exterior Modification 0 08-24-2008 09:42 PM
DIY fog light covers for 04-05 WRXs? ismegamanthere Interior & Exterior Modification 5 09-25-2007 10:37 AM
DIY fog lights and security? mr_yellow Newbies & FAQs 2 08-18-2003 05:51 PM
