Old 01-13-2010, 03:41 PM   #51
shibby2821
Member#: 229778
04 WRX
WR blue
also since im doing this, if i disconnect the plug under the glove box that controls the DRLs, will i still be able to turn the fogs even though the drls are disabled?
shibby2821 is offline   Reply With Quote
Old 01-15-2010, 01:14 PM   #52
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Originally Posted by Flyin_Hayn View Post
Wanted to give kudos for DIY!!! +1!
Love it works great looks good, highly reccomended!
Thanks Dude!
Originally Posted by shibby2821 View Post
do we need the extra purple fuse or will it run without it?
As far as I know you need the extra fuse to colse the circuit, so yes
My DRLs are disabled and it works fine, but I disabled mine under the hood
JoeSUBARU is offline   Reply With Quote
Old 01-15-2010, 10:37 PM   #53
Mr. AWDriver
Member#: 176505
07 SWP STI
I did the scooby mod one 2 years ago, took 15mins and works.
Mr. AWDriver is offline   Reply With Quote
Old 01-20-2010, 09:01 PM   #54
shibby2821
Member#: 229778
04 WRX
WR blue
just did it tonight and wow it worked with my horrible soldering. and on the 04s u gotta cut plastic off wen u plug it back in. blade and some pliers and ther u go. thanks for the mod. took a look at the scoobymods one, didnt look very easy
Old 01-20-2010, 09:17 PM   #55
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Glad it worked out for ya bro!! Dont feel bad my soldering sux too
Old 01-20-2010, 10:00 PM   #56
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Has anyone done this on an 08+?
redobs is offline   Reply With Quote
Old 02-22-2010, 12:44 AM   #57
T WRX H
Member#: 169948
2002 WRX/STi
Very cool. Will be definitely doing this mod this coming weekend.
T WRX H is offline   Reply With Quote
Old 02-22-2010, 02:28 PM   #58
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Nice!! Good Luck with it!
Old 03-03-2010, 07:22 PM   #59
subielover29
Member#: 237533
2002 MSPT tuned WRX
a few questions....
where is that second white fuse from?
whats the best way to take out the relay? I do not have any baby screw drivers
the op said he ran the fuse off the rear wiper. does that mean that same fuse on the sedan is no good to do this mod or is this mod just for wagons?
subielover29 is offline   Reply With Quote
Old 04-23-2010, 06:40 PM   #60
hoffmanEstates
Member#: 122043
04 wagonier
psm
i haVE done this just a different way. i just tapped into the ign switch wireing and done
hoffmanEstates is offline   Reply With Quote
Old 04-26-2010, 09:02 AM   #61
bjaff001
Member#: 192181
2011 WRX Sedan
Did this mod about two weeks ago, not sure what I screwed up by my fogs won't turn on at all now
bjaff001 is offline   Reply With Quote
Old 04-29-2010, 09:45 AM   #62
tacomaprime
Member#: 70572
2005 Tacoma
I was going to do this mod this weekend, can anyone verify if you have to dremel out part of the fuse box on the 05's?
tacomaprime is offline   Reply With Quote
Old 04-29-2010, 10:12 AM   #63
huminajumina
Member#: 214200
2005 wrx Sti
black
Yea I am not sure thats why I didn't do this on my '05 either, I don't wanna permanently mod my fuse box
huminajumina is offline   Reply With Quote
Old 10-15-2010, 07:34 PM   #64
jproy12
Member#: 116315
2012 Forester 2.5X
One question I had; with this mod, are the fogs always on, no matter if you press the button? Or are they completely independent, you can run with or without fogs?
Thanks
jproy12 is offline   Reply With Quote
Old 10-15-2010, 07:57 PM   #65
littlewhitewagon
Member#: 103068
11 STI sedan
You can make the fogs turn on with parking light, ignition, when the door is open, but the switch will still control it. It's just the relay trigger you are changing
littlewhitewagon is offline   Reply With Quote
Old 10-15-2010, 10:40 PM   #66
efaroh
Member#: 166947
2006 WRX Sedan
Crystal Gray Metallic
just did this on my 06 sedan. tapped into the rear wiper fuse. only thing that sux is the coin tray doesnt stay closed because the "add-a-fuse" housing is in the way of it closing. tried messing with the coin tray tabs on the side... didn't work. I'm sure i'll think of a way to rig something up.
efaroh is offline   Reply With Quote
Old 10-16-2010, 11:58 PM   #67
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Mine closed fine.... A bit more snug but no major interference once it popped into place
Old 10-19-2010, 11:50 PM   #68
gandhimtb
Member#: 253718
2004 WRX wagon
I did this today, tapped into the lumi fuse since it was closest and the wire that came on the add a circuit didnt fit from the rear wiper. the indicator light is off when headlights are off or on parking but is on when headlights are on and is a bit faded when the high beams are on. The coin tray didnt fit back as good as before and has trouble getting in place but once it is in place it seems to stay put. overall worth it but considering the soldering and the pain to get the relay back in I probably should have gone with the splicing method
gandhimtb is offline   Reply With Quote
Old 10-20-2010, 08:20 AM   #69
LilJeb
Member#: 242249
2003 Outback Sport
Silver/Champagne
did this last night. very easy and well done write up. couldn't have done it without. *claps*
here ya go. with some halogen bulbs (awesome in the fog lenses)
^^^Just fogs.
LilJeb is offline   Reply With Quote
Old 10-21-2010, 08:26 AM   #70
ETacv
Member#: 134010
2007 WRX bren-t00ned
UGM
That's a clean OBS!
ETacv is offline   Reply With Quote
Old 10-22-2010, 11:26 AM   #71
prezzy
Member#: 238445
Cool Mod!!
prezzy is offline   Reply With Quote
Old 10-22-2010, 12:07 PM   #72
LilJeb
Member#: 242249
2003 Outback Sport
Silver/Champagne
Originally Posted by ETacv View Post
That's a clean OBS!
Thanks bud. She's my babe for sure. lol
Originally Posted by prezzy View Post
Cool Mod!!
thats what im sayin!
Old 11-27-2010, 08:42 PM   #73
04wrxroc
Member#: 121818
2009 Forester XT
CRP
*** i did the spliceing mod on my 04 wrx just want to know if it wouls work on my 09 forester or if the fuse mod would work on the forester
04wrxroc is offline   Reply With Quote
Old 11-30-2010, 01:52 AM   #74
cheapfreerider
Member#: 152985
2006 wrx wagon
wrb
Hey all, Just an idea but haven't tried this on the wrx yet.
On a lot of cars this can be done very easily. All you're doing is bypassing the relay by jumpering the two power prongs. There are typically 4 prongs on a relay - two "control" terminals that when 12v is applied on one (which is when the headlights turn on) then it connects the two power terminals (one is always hot, the other goes to the switch/light/etc). The easiest way is to take a 2" length of wire and put a spade terminal on each end and simply plug them into the 2 power female connectors where the relay would sit, which permanently gives power to the switch/device/etc. I've done this on a handful of vehicles and it takes two seconds and requires no splicing, etc. I would think it would be just as easy on the wrx...
cheapfreerider is offline   Reply With Quote
Old 01-10-2011, 07:19 PM   #75
CRUZTAKER
Member#: 269757
2011 WRX 5-door
I need to do this on my 2011 WRX.
I'll read up on this "splicing method" once I find it, and read up on the "ScoobyMod" version, and then make my decision and share my results.
We need another warm day around here first. It's been in the teens and 20's for awhile now and I would rather go skating.
CRUZTAKER is offline   Reply With Quote
diy fog light mod help! blakkboxer Electrical & Lighting 5 04-02-2009 07:46 PM
DIY fog light bulb replacement 04 wrx steakraw Interior & Exterior Modification 0 08-24-2008 09:42 PM
DIY fog light covers for 04-05 WRXs? ismegamanthere Interior & Exterior Modification 5 09-25-2007 10:37 AM
DIY fog lights and security? mr_yellow Newbies & FAQs 2 08-18-2003 05:51 PM
DIY MY02 fog light cover bracket that work with fog lights installed Darren_2.5RS Mid West Subaru Owners Club Forum -- MWSOC 0 03-05-2002 03:28 PM
Message Board Statistics All times are GMT -4. The time now is 01:04 AM.
