Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 09-13-2008, 06:52 PM   #1
capamerica
Member#: 105056
2005 WRX
WR BLUE
Default Spring Pins
I am following this DIY on changing the clutch, but I dont know where I can buy the spring pins. Please chime in with some direction! THANKS!!
I also posted in the clutch replacement thread. sorry for the double post, I just need help fast.
Thank for any info.
capamerica is offline   Reply With Quote
Old 09-13-2008, 10:37 PM   #2
r3xor
Member#: 188129
02 WRX Cobb Stg 2
I know my local dealer has them in stock (about $3 a piece)... not sure if any other local parts store would have them.
r3xor is offline   Reply With Quote
Old 09-14-2008, 09:54 PM   #3
capamerica
Member#: 105056
2005 WRX
WR BLUE
thanks
Old 09-14-2008, 09:59 PM   #4
hangman
Member#: 173493
1999 Legacy GT
Quick Silver
This is what you would call a dealer parts only.
hangman is offline   Reply With Quote
Old 09-15-2008, 01:24 PM   #5
Manbike26
Member#: 72122
2015 SUPER AWESOME
TEST VEHICLE
In case it helps someone one day: I ran into a problem when changing the clutch on my 02 where the pins wouldn't go back in...be sure to note the pins only go in one way.
The hole on both the half-shafts and the outputs is slightly tapered on one end...trying to get it in the wrong way is a major pain.
-Mike
Manbike26 is offline   Reply With Quote
throwout bearing retainer clips and halfshaft spring pins NITRO163 Transmission (AT/MT) & Driveline 4 08-14-2006 06:18 PM
2000 RS Spring Pins young_matthew Transmission (AT/MT) & Driveline 0 03-19-2005 10:47 AM
Spring pins on the halfshaft? RootUsr Mid Atlantic Impreza Club -- MAIC 4 10-12-2003 01:20 AM
Need help - half shaft inner part spring pin - can't get it to go in - anyone?? alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-30-2001 10:25 AM
Need mechanical help!! w/ spring pins that hold half shaft inner side on alfriedesq Tri-State Area Forum 1 11-30-2001 01:32 AM
