Old 09-14-2008, 01:14 AM   #1
199subaru
Member#: 186582
Default crank/cam sensor HELP PLEASE
i have a 2004 wrx and one day it just stoped running. well it startes and runs for a min then as u give it gas it dies out some one told me that it may be the crank/cam sensor cant seem to find it on the left side if your looking at the motor can find the right one just above the timinning cover maybe if some one has a digram that would help to thanks rick
199subaru is offline   Reply With Quote
Old 09-14-2008, 06:35 AM   #2
REDI-wgn
Member#: 38068
03 WRX Wagon
cam sensorS or crank sensor usually will throw a code, you should check. Check you MAF
REDI-wgn is offline   Reply With Quote
Old 09-14-2008, 09:15 AM   #3
199subaru
Member#: 186582
yeah the weirds thing their was no code throw for this
Old 09-14-2008, 10:13 AM   #4
Rodwrx23
Member#: 170948
I'm also sure we (WRX's w/o AVCS) only have one on the driver side.
Rodwrx23 is offline   Reply With Quote
Old 09-14-2008, 01:08 PM   #5
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
If the cam sensor went bad while driving the car would still run until it was turned off. If either of those sensors don't work the car will NOT start. This is another one of my check and clean your maf posts.
2gnt2wrx is offline   Reply With Quote
Old 09-14-2008, 09:51 PM   #6
199subaru
Member#: 186582
ok thanks will check and clean the maf tomorrow and see what happens
Old 09-14-2008, 10:09 PM   #7
Rodwrx23
Member#: 170948
When my cam sensor went bad, I would just have trouble starting now and then but I could start and run my car. I always threw a code for it though regardless of how many times I cleared it.
Old 09-15-2008, 04:59 AM   #8
REDI-wgn
Member#: 38068
03 WRX Wagon
I believe you're right. Anyhow I dont think thats the problem he is having.
ATX: Crank/Cam sensors and Q-tech EvilCerealBoX TXIC Private Classifieds 0 04-06-2010 02:45 AM
EA82T code 11 crank angle sensor help please!!! iluvdrt Pre-2002 Factory Turbo Powertrain 4 11-02-2005 05:25 PM
Crank / Cam sensor Compatibility Hitokiri Normally Aspirated with bolt-on Forced Induction Powertrain 1 01-21-2005 11:51 AM
are my crank/cam sensors broke? GimpWRX Engine Management & Tuning 6 03-02-2003 01:23 PM
Help w/DTC's P0335 and P0340 Crank/Cam sensor malfunction Austin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2002 08:41 AM
