Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 09-14-2008, 10:21 AM   #1
Member#: 160383
2011 WRX
Lighting Red
Question Help w/ Boost Gauge Install using clock wiring
I am installing an autometer boost gauge and I am using the triple gauge pod that replaces the clock on my 03 wrx. I was going to tap into the wiring for the clock for the light on the boost gauge. There are 4 wires, one of them being the ground. I was going to solder the ground to that one.
My question is which of the other three would/should I use for the power. I have a wiring schematic for the clock power cord and it shows all three of the others going to power supply routing. One of them has a (B), one has (ACC) and the other doesn't have anything other than the fuse number. Any idea's which I should use. I was going to use the ACC one, but wanted to make sure before I did anything.
Thanks in advance for any and all help,
astrange22 is offline   Reply With Quote
Old 09-14-2008, 12:38 PM   #2
Member#: 53443
2001 LL Bean Outback
The ACC is for accessory power so it only turns on when the key is turned to ACC. You don't want the lights to turn on in the ACC mode. The clock also needs continious power for the memory and I think the line marked B is for that one. So this leaves the line with a fuse number marked on it to tie to. To prove it, check the voltage on that lead with the key OFF. If you get voltage there after the key is turned to ON or RUN then that is the correct lead to tie to.
need wiring help for boost gauge install switchn2aWRX Electrical & Lighting 0 08-31-2007 12:34 PM
ok, i must be retarded, help with boost gauge install.. simple question MaK10 Mid West Subaru Owners Club Forum -- MWSOC 2 05-03-2003 05:04 PM
Electrically challanged needs help w/ boost gauge install BIGSKYWRX Electrical & Lighting 6 10-06-2002 02:21 PM
Help!! TT/Boost Gauge install dubRX2002 Newbies & FAQs 7 08-07-2002 02:02 PM
Help with boost gauge install please HonduhEater Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-18-2002 10:31 PM
