Old 09-15-2008, 05:07 PM   #1
speed_ga
Member#: 188906
1999 Legacy SUS lmt.
Black Cherry
Angry I have a sunroof that only opens...and doesn't close...
ok I have a 1999 subaru legacy SUS lmited edition. Today on the way home I decided to let some of the hot air out by opening my sunroof....but then when I went to close it...it wouldn't close. The motor runs like it's closeing it...but it's not actually close it. I can run the motor to close it until it stops....Then I can pull the sunroof shut...but it won't put the back end up to do a complete seal.
Anyways are there any cheap fixes for this. I really don't care too much for the sunroof...so if there is a aftermarket part that I could use that isn't electric...that would be completely fine with me. Or i'm open to any suggestions.
speed_ga is offline   Reply With Quote
Old 09-15-2008, 05:46 PM   #2
Pohenegamook
Member#: 134262
cyka blyat
I have an 01 so it might not be the same but when I bought it there was an allen wrench in the tool kit and I was like .
After reading the manual I learned you can pull something off (map light cover? I don't recall), insert the allen wrench and close your sunroof. Check you manual (download from my.subaru.com if you don't have one)
Edit: I may be mistaken, found the manual online and it's the moonroof:
http://hp.auto.ru/Subaru%20Legacy/20...1_leg_sec9.pdf
Pohenegamook is offline   Reply With Quote
Old 09-15-2008, 08:09 PM   #3
speed_ga
Member#: 188906
Black Cherry
ok I followed that and it just doesn't do the job. See my motor is running fine...but whatever grabs the sunroof to pull it back...is off or something. I may do a complete teardown of the roof lining to get to the sunroof assembly this weekend if I don't find the answer to my problems on here. Hopefully if it works...then I can make a DIY guide.
Old 09-15-2008, 08:10 PM   #4
speed_ga
Member#: 188906
Black Cherry
However...as a temp fix...I just wedged some stuff to get the window as close to a complete seal as possible.
Old 09-15-2008, 08:12 PM   #5
chicakms
Member#: 183449
2010 Impreza 2.5i
Camellia Red Pearl
Aww, sorry to hear about your troubs...I am annoyed because I don't think my sunroof opens enough went I put it up. Anyone know if there is a way to make it go more?
chicakms is offline   Reply With Quote
Old 09-16-2008, 02:03 AM   #6
WhiteH2O
Member#: 452
'06 Lexus GX470
'07 Triumph Daytona 675
Subscribed for pictures and a DIY fix.
WhiteH2O is offline   Reply With Quote
Old 09-16-2008, 08:49 AM   #7
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
If you can't figure out a fix, you could yank the whole assembley out and replace it with a peice of lexan.
You'd have a sunroof that only closes and doesn't open, but I suppose that'd be more convenient then the situation now.
SomeoneWhoIsntMe is offline   Reply With Quote
Old 09-16-2008, 10:46 AM   #8
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Dude, check to see if there is anything blocking the "arms" from moving back down. Mine did the same thing and I was pissed. Got out and did a 10 min lookover and found out a little piece of mulch or something got stuck in between the moving arms. That was all it took and it wedged itself in there and wouldnt allow it to close. Motor was running just like yours but wouldnt close. Check the "gutters" for any debris
NickWRX is offline   Reply With Quote
Old 09-16-2008, 10:48 AM   #9
speed_ga
Member#: 188906
Black Cherry
thanks for the info...i'm gonna look that over tomorrow.
Old 09-19-2008, 11:41 AM   #10
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
Sure. Any word yet?
My idea for a one touch sunroof open and close Kraziken Legacy Forum 20 06-26-2007 03:57 PM
i have a gauge that only works when it rains drain bramage Electrical & Lighting 6 04-26-2006 01:55 PM
why is it that i am the only one on i-club that DOESNT have a girl that wants to use dorifto88 Off-Topic 28 12-04-2002 03:35 AM
What's the dif. between open and closed deck? HYDCSX400 Normally Aspirated Powertrain 11 02-21-2001 10:18 AM
Sunroof won't open, but will close ecfitzgerald Interior & Exterior Modification 3 10-23-2000 05:40 PM
