Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 03-15-2002, 09:20 PM   #1
Shinji N
Member#: 3987
1999 Miata
Smile Group N transmission mount
Wow, this is how the car is supposed to feel when you shift. I can understand why they don't include it stock though. While there is noticeable vibration and a little more noise in the cabin, this is a very worthwhile modification.
I only had two difficult steps in the installation. The 14mm bolts holding on the rear portion of the forward-back crossmember was terrifying to unscrew. Air tools or a 3 foot breaker would definately make it easier. The other thing is that I found it hard to install the sti mount without completely removing the whole crossmember assembly, i-club modification instructions be damned.
The shifting action has become a lot smoother. Downshifting from fourth to third no longer has an unwary wandering feeling; it just slips right in. Third to second downshifting has also firmed up a bit although I still need to double clutch in order for it to go in smoothly. Second to first is still a no-go though.
Shinji N is offline   Reply With Quote
Old 03-16-2002, 10:50 AM   #2
adamsrs
Member#: 3768
I installed mine yesterday too! TOO BAD MY MOTOR IS BLOWN! LOL!
adamsrs
adamsrs is offline   Reply With Quote
Old 03-16-2002, 10:57 AM   #3
Peaty
Techno Sapien
Member Sales Rating: (1)
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
http://www.scoobymods.com/forums/sho...=&threadid=234
There are my instructions on install. I agree a worth while mod.
Peaty
Peaty is offline   Reply With Quote
Old 04-01-2002, 06:06 PM   #4
lgstucki
Member#: 14980
2002 impreza wrx
I also installed my STi tranny mount on saturday. I think that I is a very worth while mod!!! I helps your shifting a lot more than any bushings will (if you ask me). As for the extra cabin noise I thought that it sounded really cool it was more rumbly then anything. I does virate more at idle but I don't mind very much vs. how much it helps other things perform.
I agree with Shinji N the 14mm bolts that you are supposed to loosen on the forward-back crossmember were very hard to loosen because of the 3rd cat. I actually ended up loosening the four 14mm bolts from the horizontal crossmember that the forward-back crossmember is connected to. I also had to use a breaker to get some of the bolts loose.
lgstucki
lgstucki is offline   Reply With Quote
Old 04-03-2002, 03:19 AM   #5
Kostamojen
Member Sales Rating: (7)
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Anyone find where the cheapest place to get them is yet?
Old 04-03-2002, 02:16 PM   #6
20mm
Member#: 11607
2004 Impreza WRX STi
Platinum Silver Metallic
Cobb Tuning
They are the only ones I could find with them in stock, pretty cheap too, ordered mine yesterday
-Chad.
20mm is offline   Reply With Quote
Old 04-03-2002, 07:22 PM   #7
bemani
Member#: 5673
02 bug eye, 05 LGT
adamsrs
The 2 incidents are not related are they?
bemani is online now   Reply With Quote
Old 04-04-2002, 03:26 AM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Originally posted by 20mm
Cobb Tuning
-Chad.
Ya, cobb's price is ok... seen it cheaper in the group buys though, and someone said AVSport was selling it for like $59, but its not on their site...
Old 11-14-2004, 11:40 PM   #9
scoobystas
Member Sales Rating: (22)
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
rallispec.com
scoobystas is offline   Reply With Quote
Old 12-14-2004, 04:32 PM   #10
GeorgeRex
Member Sales Rating: (12)
Member#: 51695
2004 STi
Installed my Group N mount yesterday. NVH did increase as expected and as noted by others the engine sounds have more "texture". Shifting action is greatly improved and even clutch takeup feels better. A good tradeoff.
GeorgeRex is offline   Reply With Quote
Old 08-29-2009, 12:44 AM   #11
hklatte
Member Sales Rating: (3)
Member#: 131234
2007 WRX Wagon
Anyone else got a group n mount on a 06/07 wrx? Honestly I don't really feel much different driving on the street/hwy....
hklatte is offline   Reply With Quote
Old 08-29-2009, 12:50 AM   #12
eb_rat_7
Member Sales Rating: (40)
Member#: 106910
2012 WRX SWP HATCH
C6 ZO6 track toy
it made a large difference on my 06, though not as much as the group n motor mounts.
eb_rat_7 is offline   Reply With Quote
Old 08-29-2009, 12:55 AM   #13
hklatte
Member#: 131234
2007 WRX Wagon
Maybe my wagon is already loud and noisy because of the dp and catback, a little more NVH from the mount doesn't make much different...
shifting though, I really can't tell the difference...
Old 03-08-2010, 01:17 AM   #14
txl146
Member Sales Rating: (145)
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
OP noted mount made shifting a lot smoother; anyone else notices the same thing?
I recently upgrade strut top to group-N and it did make noticeable difference.
Old 03-10-2010, 05:51 AM   #15
relliMmoT
Member#: 206931
2004 WRX Wagon
6MT JBP 318WHP//300WTQ
Hells yeah it makes shifting smoother, THINK ABOUT IT!
The transmission is slopping back and forth every time you are on and off the gas, between shifts, whatever. Heck itll slop around if you shake the car.
When you plant that thing still your actually shifting the motion of your arm into gear, not correcting with the transmission movement AND into gear.
And some of the higher up posts keep saying STi mount.. STi mounts are the same as the WRX mount with harder rubber while the Group N mount is filled in completely, big solid brick of 80A rubber.
relliMmoT is offline   Reply With Quote
Old 03-10-2010, 11:47 AM   #16
fastwrx25
Member Sales Rating: (37)
Member#: 126441
03 bugeye
smoother shifting for sure, and i feel better handling also.
fastwrx25 is offline   Reply With Quote
Old 03-10-2010, 11:52 AM   #17
Longshot55
Member Sales Rating: (2)
Member#: 164121
2005 WRX EvoIII 16G
EFI Logics Tuned
I installed one this past Saturday. The biggest difference I noticed is mostly between upshifts from 1st to 2nd. This is definitely worth it, just comparing these two mounts holding them in your hands you can immediately tell it makes a big difference. The stock mount is such a joke, too much sacrifice on NVH.
Longshot55 is offline   Reply With Quote
Old 03-11-2010, 01:19 AM   #18
relliMmoT
Member#: 206931
2004 WRX Wagon
sry thats funny
Old 03-12-2010, 11:50 PM   #19
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I installed GN transmission mount a couple days ago along with Kartboy crossmember bushings. First thing I've noticed is noticeable amount of starter noise similar to pitch mount.
Unfortunately, I really cannot feel any difference in shifting other than increased engine noise and vibration.
Old 03-13-2010, 05:43 PM   #20
nfm
Member Sales Rating: (10)
Member#: 171697
05 WRX
0whp
Just about same here, except that I only noticed very cool noise in 1st and 2nd gear, sound more like straight cut gears, it awesome . I currently have:
- Rear Diff Mount and Outrigger Bushings
- Kartboy Shifter Bushing
This mount did reduce the slop that I have in my drivetrain however I still have a lot left of lash if I release clutch a bit early or give gas bit late @ low RPMs, maybe I need a pitch stopper and engine mounts. Overall thumbs up to Group N .
nfm is offline   Reply With Quote
Old 03-13-2010, 08:20 PM   #21
idipskoalmint
Member#: 169716
2005 WRX STi
WTF Tuned
All transmission mount installs should include crossmember bushings (TiC, Kartboy, or Whiteline) as a "while you're there"
idipskoalmint is offline   Reply With Quote
Old 03-13-2010, 10:37 PM   #22
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
yes, I also noticed whining sound in 1st and 2nd gear - sounds a lot like PPG gear.
Old 05-09-2010, 06:34 PM   #23
Blue_Rex
Member#: 236954
2010 WRX Base
I just installed my group N transmission mount and STi hardened crossmember bushings on my 2010 WRX, so I thought I would add some comments. First thing, with the radio off, there is definitely transmission whine. Any gear. More than I expected, but bearable. One thing that surprised me was that the car felt heavier going over bumps, kind of like the more direct connection with the rest of the car made everything mode in unison. There is definitely a bit more NVH, but not too much. Nothing in comparison to the whine. Throttle response is WAY snappier, and there is more of that nice snap into gears, similar two the improvement from the shifter bushings.
The stock bushing are total crap. I thought that the youtube video was exagerated, but I was wrong. The stock mount and bushings are made of the same rubber, and it is mushy as heck. My 7 year old was able to move the stock mount arond with no problem, but I could barely budge the group N. Good mod, I'll probably add some more comments after I break them in and see if the whine subsides. I also want to see how it affects the slack and driveline rocking at slow speed and stop and go traffic.
________
How mflb works
Blue_Rex is offline   Reply With Quote
Old 05-10-2010, 06:49 PM   #24
Blue_Rex
Member#: 236954
2010 WRX Base
Slack and rocking in traffic is improved, but not perfect. I might have to go with the engine mounts next. I just dread the thought of putting them in myself.
________
MAXIMCAM
Old 08-27-2010, 01:47 AM   #25
kenliu84
Member Sales Rating: (42)
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
the GroupN Transmission Mount is definitely a worthwhile mod. I highly recommend it.
You should definitely remove the front, rear and center transmission crossmembers. It'll make it a lot easier.
- build-quality is pretty good. not only is the material much more hardened than stock, it also fills up the center gap that exists on the stock mount.
- combined with the crossmember bushings, it will improve the shifting dramatically. ever heard or read of "snick-snick" gearboxes in car magazines? yeah, now I know what they mean by that
- the drivetrain slop or bogging when shifting is pretty much gone. when you dump the clutch during 1-2 or 2-3 upshifts, the car will bog a little but it is a "controlled" bog. it's hard to explain, kind of like slow-motion bogging. and this should be expected when you purposely dump the clutch or you horribly miss rev-match
- there is definitely increased noise but it isn't bad at all (obviously subjective). you can tell the difference but it's overshadowed by the benefits and I'll stop noticing it in a few days.
as a side note, if you plan on installing upgraded crossmember bushings (Whiteline, TiC, Kartboy), you might as well upgrade the tranny mount. you are working in the same area and the stock tranny mount will start to wear out significantly faster, especially if you have other upgraded mounts/bushings along the drivetrain.
I'll upgrade the engine mount and possibly some driveshaft bushings in the future.
my drivetrain mods:
Pitching Stopper, Torque Solution
Tranny Crossmember Bushings, Whiteline RACE version
Rear Diff Mount Bushings, TiC Comfort version
Rear Diff Front Mount (outrigger) Bushings, Kartboy Comfort version
Rear Subframe Lock Bolts, Kartboy
probably insignificant but I'll list anyway:
Front and Rear Shifter Stay Bushings, Kartboy
Shift Linkage Bushings, TiC
Shift Lever Pivot Bushings, TiC
this review is from a night's worth of city and highway driving after installation, installing shift linkage bushings, and also greasing up the front and rear shifter stay bushings as I don't think I did that when I installed the Kartboy short shifter kit last year. I'll post up another review when I get a chance to test out NVH on long highway drives.
Here are some pictures:
kenliu84 is online now   Reply With Quote
Sti Group N Transmission mount BNIB and oem mounts mystilexzero Engine/Power/Exhaust 10 03-17-2009 05:52 PM
Cheapest Group N transmission mounts? Steven Romero Transmission (AT/MT) & Driveline 2 08-09-2006 01:22 PM
WTB: Group-N Transmission Mount Cavadini Private 'Wanted' Classifieds 1 01-20-2006 10:24 AM
A Question about the STi Group-N transmission mount Rippa Transmission (AT/MT) & Driveline 7 07-15-2005 02:01 PM
WTB: Group N transmission mount vee Private 'Wanted' Classifieds 0 04-30-2004 07:54 PM
