Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 09-16-2008, 09:01 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default JDM Engines Just Arrived EJ207 STi Spec.C/EJ20 Twin Turbo/EJ25 FXT/EZ30/EZ36
JDM Engines just arrived from Japan! Dont miss out guys. Complete long block assemblies. These engines always sell out so dont miss out. Also dont forget our special deal on BC Cams with free eibach Springs and Free BC retainers. Best price anywhere on BC Cams. If someone else has them cheaper we will beat them
JDM Engines
Engines have less than 30k miles. All engines leaked down and compression tested.Engines come with start up warranty only. Sorry no complete engine conversios are available. Long Block assemblies only.
EJ207 STI SPEC C (1 In Stock) $3500 Plus Shipping
Long Block Assembly- No Turbo- No ECU- No Intercooler
EJ20TT Legacy Twin Turbo (10 In Stock) $1400 Plus Shipping
Long Block Assembly- Turbos Included- No Intercooler- No ECU
EJ255 FXT Turbo (3 In Stock) $2500 Plus Shipping
EZ30 (6 In Stock) $1999 Plus Shipping
Long Block Assembly- No Exhaust Manifolds- No ECU
EZ36 (5 In Stock) $1999 Plus Shipping
Engine Rebuild Kits
EJ20 Engine Combo/ EJ25 Engine Combo
-CP (std) or (+020) Pistons
-CP Piston Rings
-Helix Forged Rods
-Coated Race Bearings
$799 Shipped
EJ25 Budget STi Engine Rebuild Kit
Brand new components. Taken out of a brand new USDM EJ257 STi Shortblock. Brand new with zero miles.
-USDM STi Pistons
-USDM STi Piston Rings
-USDM STi Rods
-USDM STi Bearings
$599 Shipped
2008 STi IHI VF48 Turbo
320+ whp
The IHI VF48 comes stock on the 2008 STi. With Supporting Mods gains of 320 +whp can be easily acheived. With a larger compressor compared to the VF34 and more potential The VF48 is the new kid on the block.
***Will Not Fit on 2008+ WRX Models***
VF48 Turbo (fits 02-07 WRX/ 04-08 STi)
$925 Shipped
VF48 Turbo/ Helix 820 Injectors/ Walbro Fuel Pump (fits 02-07 WRX/ 07-08 STi)
$1475 Shipped
VF48 Turbo/ Helix 860 Injectors/ Walbro Fuel Pump (fits 04-06 STi)
$1475 Shipped
2007 Legacy Spec.B IHI VF46 Turbo
'08 WRX Turbo Upgrade
The VF46 is the world's first 5-arc scroll turbo. This new design has been adopted for the turbocharger compressor. By adjusting the flow of compressor air and improving compression efficiency, low and midrange torque has been increased/improved. Perfect upgrade for the 08+ WRX and Legacy GT
***Will Not Fit on 2002-2007 WRX/ STi Models***
VF46 Turbo (fits 08+ WRX/ 04-08 Legacy)
$925 Shipped
$1475 Shipped
ATP GT3076 Turbo
Stock Location 500+whp
The Garrett GT Ball Bearing GT3076R, the benchmark 500+ HP capable dual ball bearing turbo, is now available in a drop-in package for the Subaru WRX/STI! The easy to implement turbo assembly that takes no more than 1-2 hours to install in place of the stock journal bearing VFXX unit is made possible by a high flowing GT inspired ATP exhaust housing and a series of custom engineered components built to suit the installation.
Each GT drop-in turbo package consists of a Garrett factory assembled and high speed balanced dual ball bearing CHRA which is then assembled into a set of CNC machine ported housings that have been optimized in every aspect for maximum flow and efficiency.
All accompanying oil and coolant supply components included in each kit have been designed to properly and seamlessly bridge the Garrett GT turbo to the EJ engine so that the fit is as OE as possible.
Just bolt the turbo on, add fueling and a good tune and prepare for a blast of acceleration. Garrett GT turbos offer more then just "peak HP" numbers. These GT turbos off more torque area under the curve and more "accessible" power then any other turbos series out there.
We do recommend that you compliment your GT bolt-on turbo with a nice high flowing bellmouth downpipe and a high flowing inlet pipe to effortless channel air in and out of the turbo. Although every bolt-on GT turbo ships with a 3" inlet, we do provide a "stepdown" sleeve just in case you're forced to use the stock 2.25" inlet hose. However, as a rule of thumb, turbos, especially higher flowing units love as much inlet flow as possible. This promotes both quicker spoolup and better ultimate HP, with less boost pressure at the manifold. The 3" downpipe and bigger inlet is critical for reaching peak efficiency on the GT turbo. Please also be aware that some downpipes such as the stock catted downpipe, has a "no-flow" door at the wastegate flapper area. This type of downpipe may not allow the wider swinging wastegate valve to open all the way, thus causing the possibility of a "boost-creep" condition or uncontrollable rise in boost.
The GT3076R is a great match for the 2.5L that still has great spoolup, especially if you're looking for boost threshold that is just a little later than stock but still want enough airflow for 500+HP. The GT3076R makes boost about 300 to 400 rpms later than the GT3071R but keeps pumping where the GT3071R starts to run out after 450HP. A lot of the boost is available even at part to medium throttle. Dual ball bearings means boost recovery between gearshifts is awesome with full boost ready even before upshift is complete as the STI lurches forward with shear enthusiasm at the onse of each gear. The 2.0L driver should not rule out the use of the GT3076R if his HP target is in the same range. This competition grade turbo is still a big favorite for the HP range because it hits like a hammer while other 500HP turbos are still "spooling up".
GT3076 Turbo (fits 02-07 WRX/ 04-08 STi)
$1799 Shipped
GT3076 Turbo/ Helix 820 Injectors/ Walbro Fuel Pump (fits 02-07 WRX/ 07-08 STi)
$2350 Shipped
GT3076 Turbo/ Helix 860 Injectors/ Walbro Fuel Pump (fits 04-06 STi)
$2350 Shipped
Helix Downpipes
In Stock Ready To Ship
Non-Catted DP
$225 Shipped
Catted DP
$349 Shipped
***Coming Soon Helix Downpipes for 2008 WRX/ STi***
Helix Turbo Back Exhaust
Performance Exhaust
Helix Non-Catted DP/HKS Hi-Power
$725 Shipped
Helix Catted DP/HKS Hi-Power
$825 Shipped
Helix Non-Catted DP/HKS HKS Carbon-Ti
$775 Shipped
Helix Catted DP/Greddy Ti-C
$949 Shipped
Helix Non- Catted DP/GReddy TI-C
$725 Shipped
Helix Non-Catted DP/Blitz NUR Spec
$725 Shipped
Helix Catted DP/Blitz NUR Spec
$849 Shipped
Quiet Exhaust Under (93db)
Helix Non-Catted DP/A'Pexi World Sport
$675 Shipped
Helix Catted DP/A'Pexi World Sport
$799 Shipped
Helix Non-Catted DP/Apexi WS NOIR
$699 Shipped
Helix Catted DP/Apexi WS NOIR
$825 Shipped
Helix Non-Catted DP/GReddy SP2
$975 Shipped
Helix Catted DP/GReddy SP2
$849 Shipped
Helix Non-Catted Dp/Tanabe Medalion Touring
$725 Shipped
Helix Catted Dp/Tanabe Medalion Touring
$849 Shipped
Gruppe-S Exhaust Manifold
Dyno Proven HP
Equal Length
$549 Shipped
BC Cams
Free Eibach Valve Springs/ BC Retainers
After months of testing the BC camshafts are finally available.
Stage 2 (272)-Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK.
Stage 3 (280)- Race Specification
Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit.
WRX 272 $799 Shipped
WRX 280 $799 Shipped
STi 272 $825 Shipped
STi 280 $825 Shipped
***Free Eibach Valve Springs/ BC Retainers***
__________________
Thanks,
Gruppe-S
[COLOR=black][B]Please Note:[/B]
[I]- All Competitors Prices Beat
- All Items Are Shipped Via FEDEX
- All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit
- Any Order Cancellation Will Result In A 25% Processing Fee
- Local Pick-Ups Available[/I][/COLOR][I]
- [B][COLOR=Red]No Cancellation on JDM Or Special Orders. No Exceptions![/COLOR][/B][/I]
Gruppe-S is offline
Old 09-17-2008, 04:05 AM   #2
onefasazn
Member Sales Rating: (53)
Member#: 45574
2002 WRB GGA...again
98 986 Boxster HT
Thanks for putting the rebuild kits back up...I was about to ask.
with the BC cams and Eibach springs, do you guys have the open and seat pressures for the springs?
onefasazn is offline
Old 09-17-2008, 02:01 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
No that is not required for the Eibach springs.
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-18-2008, 03:13 AM   #4
lulala_sti
Member#: 127148
1994 Supra TT
please quote me seperately (including shipping charge to Taipei, Taiwan, postal code: 10500) for the following:
1. Helix Non-Catted DP/HKS HKS Carbon-Ti
2. HKS Carbon-Ti
Thanks!
lulala_sti is offline
Old 09-18-2008, 02:50 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
2. HKS Carbon-Ti
Thanks!
$775
Shipping will be around $450
2. HKS Carbon-Ti
$699
Shipping is $350
Please note that tehse are us spec items and will not work with Japan spec downpipe due to different lengths.
For International sales please note that we only accept bank wire tarnsfer.
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-18-2008, 11:50 PM   #6
raheezy69
Member Sales Rating: (10)
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
the long block comes with how many miles?
raheezy69 is offline
Old 09-18-2008, 11:58 PM   #7
Mechie3
Member Sales Rating: (51)
Member#: 120152
That engine looks brand spanking new!
Mechie3 is offline
Old 09-19-2008, 12:45 AM   #8
SL,UT_STI
Member Sales Rating: (8)
Member#: 161458
1999 BLK 2.5RS
Swap in progress
would the ej205tt work with my stock 02 wrx ecu and wiring harness?
pm me please very interested
SL,UT_STI is offline
Old 09-19-2008, 02:20 AM   #9
lulala_sti
Member#: 127148
1994 Supra TT
$775
2. HKS Carbon-Ti
$699
Shipping is $350
Thanks
Ben
Gruppe-S
Ben, thanks for the reply!
1. Regarding fitment issue, I'd better get an exhaust/dp combo for proper installation. Is that correct?
2. Are these items in stock and ready to ship?
by the way, please email me your bank info to [email protected]
Thanks!
Old 09-19-2008, 05:58 AM   #10
e_mailaccnt
Member#: 145431
05 wrx
wrb wingless. so nice
any greddy ti-c in stock? shipped to 7708. thanks.
e_mailaccnt is offline
Old 09-19-2008, 02:54 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Engine miles vary. The usually have around 10-30K
Sorry but that would be a custom instal in the GD. The steering rack and firewall interfere. Custom wiring and ECU will be required. I suggest you reserach the forum for install info. I know I have seen a few guys with them
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-19-2008, 02:57 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The Japan market and US market have different DP lengths. If use a exhaust designed for the Japan Market then you need a Japanese spec DP or Vice Versa.
Yes items in stock
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-19-2008, 02:57 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yes they are in stock. Please call 949-457-1234 for a price quote
Thanks
Ben
Gruppe-S
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-22-2008, 12:04 AM   #14
lulala_sti
Member#: 127148
1994 Supra TT
Old 09-22-2008, 02:46 PM   #15
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Old 09-22-2008, 08:20 PM   #16
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Closing Thread Guys
Click Here For Updated Specials
http://forums.nasioc.com/forums/show...7#post23797307
__________________
Thanks,
Gruppe-S
Gruppe-S is offline
Closed Thread
need to find turbo for ej20 twin turbo engine roostema4328 Private 'Wanted' Classifieds 1 09-19-2009 04:54 AM
JDM Engines In Stock EJ257 STi $3500-EJ255 FXT $2500-EJ205 $2000- VF48 In Stock Gruppe-S Engine/Power/Exhaust 37 11-11-2008 08:36 PM
EJ25 swap for EJ20 twin turbo..Will it work? bushey83 Built Motor Discussion 6 01-31-2008 06:28 PM
EJ20 Twin Turbo B4 JDM Engine fiid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-06-2004 09:24 PM
Twin turbo EJ25? 8Complex Technical Forum Archive 51 09-19-2000 01:16 AM
