Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 09-17-2008, 03:03 PM   #1
nhluhr
John Wayne Toilet Paper
Member Sales Rating: (22)
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default Moving Sale! Tons of stock parts and bike, skis, etc, some free!
First of all, NO SHIPPING. This stuff is local pickup only.
Also, ALL PRICES ARE NEGOTIABLE
2005 STi stock motor mounts $20
http://wrx.grapon.com/forsale/moving/2005mounts.jpg
2006 STI stock motor mounts $15
http://wrx.grapon.com/forsale/moving/2006mounts.jpg
2006 STI Rear floormats Perfect Condition $10
http://wrx.grapon.com/forsale/moving/floormat1.jpg
2006/2007 Hood Prop Rod (with clip) $10
EJ257 Fuel Pump $25
2006 STI Mirror & Clip, and trim buttons $10
a single super-HD front or rear adjustable pillowball endlink $5
2006 STI stock shifter and tranny bushings
http://wrx.grapon.com/forsale/moving/assorted1.jpg
assorted tubes, hoses, and clamps FREE
http://wrx.grapon.com/forsale/moving/assorted2.jpg
1 - Lateral Link Outer Bolts (both sides)
2 - Lateral Link Inner Bolts (one side only) and both plastic gastank protect-covers for inner bolts
3 - starter cable support
4 - assorted turbo and downpipe heatshields
5 - (4) rear tophat dust/water covers
6 - LH 2006/2007 STI front axle seal (where it goes into front diff). New/unused.
7 - 2002 DRL ballast
8 - I think this goes around the Boost Control solenoid
9 - SOLD
10 - turbo support brace?
(everything in this photo, $10)
http://wrx.grapon.com/forsale/moving/assorted4.jpg
assorted trim clips (LOTS brand new)
some OE flange bolts like the ones that hold the undertray on
fender liner clips
OE button blanks
intake resonator blockoff plate
2004-2007 STI seat base plate covers
(everything in this photo, $10) Hokie-wrx-wagon
http://wrx.grapon.com/forsale/moving/assorted3.jpg
bag of lugnuts. M12X1.25 standard subaru lugnuts. Probably like 18 or 20 of them. $5 big c
http://wrx.grapon.com/forsale/moving/bag-o-lugnuts.jpg
nhluhr is offline   Reply With Quote
Old 09-17-2008, 03:10 PM   #2
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
2006 STI OE brembo brakepads. about 3/4 pad thickness left. $20
http://wrx.grapon.com/forsale/moving/brakepads.jpg
several used but functional brakelines even a couple steel ones. I don't think any of these have any troubles except the goodridge lines which are faulty. FREE
http://wrx.grapon.com/forsale/moving/brakeparts1.jpg
OE brake bleeders and some brakeline bolts/hardware FREE wrxskier18
http://wrx.grapon.com/forsale/moving/brakeparts2.jpg
2006 STI bumper beam Steel Gray perfect condition. $50
http://wrx.grapon.com/forsale/moving/bumperbeam2006.jpg
2006 STI rear diff support brace. Can use this to press in aftermarket bushings at your leisure.
http://wrx.grapon.com/forsale/moving/diff-support.jpg
2006 STI fender braces FREE
http://wrx.grapon.com/forsale/moving/fenderbraces.jpg
2006 STI Fog Covers Steel Gray $20
http://wrx.grapon.com/forsale/moving/fogcovers2006.jpg
Old 09-17-2008, 03:10 PM   #3
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
(2) 2006 STI Rear springs (Stock) and (2) 2006 STI Pink front springs (STI Sport) $50 (note: STI Sport springs are available individually so you can purchase two rear springs to make this a complete Pink kit)
http://wrx.grapon.com/forsale/moving/springs.jpg
set of metal rear subframe bushings - these came with the 2002 Sti Sport suspension kit. Meant to replace the rubber subframe bushings with metal and make the rear end super tractable. Requires professional installation. FREE
http://wrx.grapon.com/forsale/moving...e-bushings.jpg
Steel Gray touch-up paint for 2006 Steel Gray FREE
http://wrx.grapon.com/forsale/moving/touchup.jpg
2005 STi Trailing Links $20, dirty but in perfect condition, no rust.
http://wrx.grapon.com/forsale/moving/trailinglinks.jpg
2005 STi Front Transverse Link Rear Bushings (i.e. where an ALK would go) FREE big c
http://wrx.grapon.com/forsale/moving...nkrearbush.jpg
Factory Swaybars! each $20 with bushings, $15 without bushings
1 - 2004 STi 19mm front
2 - 2005 STi 20mm front w/ bushings
3 - SOLD
4 - SOLD
5 - SOLD
http://wrx.grapon.com/forsale/moving/sways.jpg
some old skis and bindings. Defintely in usable shape. $20
http://wrx.grapon.com/forsale/moving/oldskis.jpg
Kickass Hardtail Mountain Bike
Cannondale CAAD2 frame, full XT components, 70mm Air adjustable front shock with on-the-fly damper adjust, Spinergy SPOX wheels, carbon bits, minor cosmetic issues, raced in college but meticulously maintained by a pro bikeshop mechanic (me), size XL (21"). Asking $400 obo
http://wrx.grapon.com/forsale/moving/cannondale/
Old 09-17-2008, 03:11 PM   #4
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
(5) Subaru Oil Pan Drain Plug Gaskets $1 NEW IAD wrx ?
(2) TGV Gaskets $10 NEW
(2) Intake Manifold Gaskets $10 NEW
(1) 2006 STI PCV Hose Assembly $10 NEW
http://wrx.grapon.com/forsale/moving/gaskets.jpg
2006 STI Inlet Pipe $10
http://wrx.grapon.com/forsale/moving/inletpipe.jpg
2005 STI Exhaust Manifold (began porting but got distracted) LH side is tapped for 1/8NPT EGT sender or plug. $20 wrxskier18
http://wrx.grapon.com/forsale/moving/manifold-LH.jpg
http://wrx.grapon.com/forsale/moving/manifold-RH.jpg
http://wrx.grapon.com/forsale/moving...old-center.jpg
Infinity Perfect 12 subwoofer in small sealed box $50 IAD wrx ?
http://wrx.grapon.com/forsale/moving/perfect12.jpg
Impreza speaker adapter (adapts aftermarket speaker to factory wiring) $5
http://wrx.grapon.com/forsale/moving/speakeradapter.jpg
Front speakers (incl tweeters) from 2006 STI $10
http://wrx.grapon.com/forsale/moving/speakers_sti06.jpg
2006 STI Factory 6-disc changer head unit $50
http://wrx.grapon.com/forsale/moving/stereo1.jpg
http://wrx.grapon.com/forsale/moving/stereo2.jpg
Old 09-17-2008, 03:15 PM   #5
Hokie-wrx wagon
Member Sales Rating: (36)
Member#: 87194
I'm interested in the $10-everything in this photo stuff. I need a few clips as well as the seat base covers.
Are you ever near Tysons Corner?
Hokie-wrx wagon is offline   Reply With Quote
Old 09-17-2008, 03:15 PM   #6
spazegun2213
Member Sales Rating: (11)
Member#: 91208
the '13 Ktm Duke
damn dude! where are you moving to? staying local?
spazegun2213 is offline   Reply With Quote
Old 09-17-2008, 03:17 PM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
just moving out near Marshall and would prefer to not have to carry this crap! I don't even own a Subaru anymore! and this is what's left AFTER I set aside all of Jason's stock parts!
Hokie-wrx-wagon, I am not near Tysons. I am near Gainesville/Manassas, but I can bring that stuff to work with me tomorrow. I will be working in Chantilly at 4050 Lafayette Center Dr from 5:30pm until 5:30am if you want to pick it up.
Old 09-17-2008, 03:51 PM   #8
Matt_H
Member Sales Rating: (29)
Member#: 107000
2015 BMW X1
PM sent.
Matt_H is offline   Reply With Quote
Old 09-17-2008, 04:01 PM   #9
nhat
Member Sales Rating: (42)
Member#: 140163
03 STi
hellaflunctional
i'll take the metal rear subframe bushings, ramps, and a couple fender liner clips.
price on the oem head unit? any info on drop & spring rates of those sti sport springs?
Old 09-17-2008, 04:04 PM   #10
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Matt_H has the ramps unless he backs out.
wrx-hokie-wagon has the clips
nhat - you got the bushings.
The springs are typical JDM Pinks. 257lb/in, about 3/4" lower than stock.
Price added for headunit
Old 09-17-2008, 04:29 PM   #11
mla163
Member Sales Rating: (9)
Member#: 104922
2016 WRX
PM sent
mla163 is offline   Reply With Quote
Old 09-17-2008, 04:35 PM   #12
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
mla163 has the cabin air filter and the tires.
Old 09-17-2008, 04:52 PM   #13
Jard
In the silly seat
Member Sales Rating: (26)
Member#: 34935
SPB- 2013 Dadcore
EJ205 Timing Belt Tensioner
EJ205 PCV Valve
Tow Hook
20mm front STI sway w/bushings
20mm rear STI sway w/bushings
Please!
Jard is offline   Reply With Quote
Old 09-17-2008, 05:02 PM   #14
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
does Matt_H live near you? I'm taking him the ramps on my way to the climbing gym... if he agrees, i can give your stuff to him as well, Jard.
Old 09-17-2008, 05:08 PM   #15
TurbojonLS
Member Sales Rating: (54)
Member#: 38772
2 Cars, No Bling
I'll take the all weather mats.
TurbojonLS is offline   Reply With Quote
Old 09-17-2008, 05:12 PM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
You got 'em.
You still live near Random Hills/Monument? I can drop them off this evening.
Old 09-17-2008, 05:21 PM   #17
TurbojonLS
Member#: 38772
2 Cars, No Bling
Originally Posted by nhluhr View Post
You got 'em.
Sure do. Sending my address.
Old 09-17-2008, 05:26 PM   #18
Butt Dyno
Street's closed, pizza boy
Member Sales Rating: (27)
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
I guess you didn't get my PM about the tires
It's cool, I'm lazy.
Old 09-17-2008, 05:33 PM   #19
STi.CC.
Member Sales Rating: (4)
Member#: 128749
2010 STi SE
PM me Ill take the floor mats.
STi.CC. is offline   Reply With Quote
Old 09-17-2008, 05:35 PM   #20
nhat
Member#: 140163
03 STi
hellaflunctional
nick, could you drop off the metal subframe bushings off at jon's? i'll be seeing him shortly about some tires and it'd be more convenient for the both of us. how much do you want for them?
Old 09-17-2008, 05:39 PM   #21
abui01
Member Sales Rating: (15)
Member#: 86899
2000 Impreza 2.5 RS
STM
Lemmie get a set of STI Sway Bars! 20mm! (also work in Chantilly, maybe we can meet up tomorrow!) =D
abui01 is offline   Reply With Quote
Old 09-17-2008, 09:18 PM   #22
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
ahh crap didn't see this in time. sorry. the metal subframe bushings are free. you could pick them up from me at work tomorrow if you like, anytime after 5:30pm in Chantilly.
Old 09-18-2008, 08:00 PM   #23
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
bump for stuff still available
things marked with a red name are dibb'd. If I missed your dib, please let me know - have had a flood of PMs and it's hard to keep track.
Old 09-18-2008, 08:59 PM   #24
mla163
Member#: 104922
2016 WRX
Thanks Nick. Good deal
Old 09-18-2008, 09:38 PM   #25
MilesToEmpty
Member Sales Rating: (18)
Member#: 129031
1998 Impreza RSTi
JBP
Id like the sub if it doesnt sell
MilesToEmpty is offline   Reply With Quote
FS : Tons of Stock parts, many aftermarket parts also. DefyF8 SWIC Private Classifieds 7 08-08-2008 04:22 PM
tons of stock parts for sale 25rsti NESIC Private Classifieds 34 07-19-2008 10:26 AM
Chicago FS: WRX Part-out. Enkei Rims, JDM bumper beam, tons of stock parts. Low $. WRXCJS MWSOC Private Classifieds 9 09-24-2007 02:39 PM
Shop Moving Sale Tons of Used WRX and Forester parts John Holmes Private 'For Sale' Classifieds 91 07-18-2005 01:12 PM
FS: LOCAL- Mike's Garage Sale-Tons of suby parts, custom stereo, EBC, MBC, SAFC, ETC. mcu81 Tri-State Area Forum 11 07-11-2003 03:35 PM
