Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 09-17-2008, 03:39 PM   #1
GDAryder
Member#: 184753
2005 WRX
Default TD05 18G 7cm2 turbo: who has one and how do they work out for you?
i just picked one up. brand new off a fellow member from here. just give me the basics on these. i plan on putting this on the car by january/february, right now im just setting money aside and getting other stuff in the mean time, as well as new software to run everything. after i get bigger injectors and a base map its all good to go. i just want as much helpful info about the turbo from experienced guys that i can soak up.
any helpful info would be greatly appreciated. thanks!
GDAryder is online now   Reply With Quote
Old 09-17-2008, 03:51 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
It's a turbo, flows aboot 600 CFM, full boost between 3500-4000, and it's freakin awesome. What exactly do you need to know? I would think research should be done BEFORE the purchase, but that's just me....
Audiosavvy is offline   Reply With Quote
Old 09-17-2008, 03:51 PM   #3
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
Works Great, I Love Mine. Power Is Very Linear And Will Pull All The Way To Redline, Expect Full Boost At 3600-4000 Depending On Tune And Supporting Mods. You Will Especially Love It Having 93 Octane Instead Of 91 In Your State.
mongoosaroo is offline   Reply With Quote
Old 09-17-2008, 04:01 PM   #4
GDAryder
Member#: 184753
2005 WRX
any and everything. the more info the better. i just wanna grab as much knowledge about this as i can. i have done research, i wanted to this turbo so i'd be able to hit 300whp and above, given i had the mods to support it (and the gearset eventually).
Old 09-17-2008, 04:16 PM   #5
GDAryder
Member#: 184753
2005 WRX
hey mongoosaroo what boost are you running? mods?
Old 09-17-2008, 04:20 PM   #6
B16A2NR
Member#: 88676
I love mine as well. Ran 18psi on 91 pump and now tuned with meth/water injection at 22psi.
B16A2NR is offline   Reply With Quote
Old 09-17-2008, 04:27 PM   #7
jason miller
Member#: 158313
2003 WRX
Forced Performance says that their 18g holds maximum efficiency all the way to 23 pounds of boost. There have been some people running 25+ pounds for race tunes... The main advantage, imo, of the 18g over a big 16g is that it's supposed to be more efficient at higher boost levels. Granted, your 18g will still pull great at 20 psi, but if I had an 18g I'd want to push it a little.
I could be totally off base, though. I'm not all that educated on turbo dynamics...
You'll need a Walbro 255lph fuel pump, at least STI pink injectors, uppipe, downpipe, catback, and a good tune. Those are the bare bones basics. If you wanted to push that 18g, I'd get a header of some sort, an inlet and intake, and a bigger intercooler.
You should really be shopping for a tuner, and ask them what they recommend. A good tune is the most important aspect of an aftermarket turbo.
jason miller is offline   Reply With Quote
Old 09-17-2008, 04:57 PM   #8
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
I RUN 750 CC RC INJECTORS, 255 LPH FUEL PUMP, TGV DEL, APS TURBO INLET, AEM INTAKE, PRODRIVE BCS (GM WORKS JUST AS WELL), INVIDIA TURBO BACK, HKS UP PIPE, 1 STEP COLDER PLUGS, CUSCO HEADER, STI TOP MOUNT. I'LL POST MORE AS I REMEMBER.
IT MAKES 20 PSI TAPPERS TO 18, FULL BOOST IS AT 3600 RPM. IT MADE 289 WHP ON CALI PISS WATER ON A DYNOMITE (SIMILIAR TO A MUSTANG) AND 272 TQ.
IF YOU RUN 93 300WHP IS A VERY REASONABLE GOAL IMHO. AS FAR AS INJECTORS AND A BCS TALK TO YOUR TUNER, THEY ALL HAVE PREFRENCES.
Old 09-17-2008, 07:25 PM   #9
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Ive got 360wtq off of my 18g Td05 7cm Deadbolt. Ive also been feeding the 2.5l ethanol and blew up my 1st gear... Needless to say the 18g is pretty fun...21 psi tapering to 15.5psi
TDagen is offline   Reply With Quote
Old 09-17-2008, 07:32 PM   #10
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
You should see somewhere close to 300whp.
I have an Blouch 18g TD05h 8^cm
I have 306whp and 280 ft-lb with catted uppipe and only supporting mods and catless tbe
fearmywrx is offline   Reply With Quote
Old 09-17-2008, 08:25 PM   #11
big16gwrx
Member#: 129459
my tdo5 18g 7cm hits full boost at 3200rpm also an ewg will fix the tapering problem
big16gwrx is offline   Reply With Quote
Old 09-17-2008, 08:37 PM   #12
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
ive been debating either evoiii big16g or an 18g...i want quicker spool so i was leaning toward the 16g but is really that much different compared to the 18g??
jcbluescooby is offline   Reply With Quote
Old 09-17-2008, 10:15 PM   #13
WRBWRXVII
Member#: 66801
GDB 03 dirt FTW
NO Hardpark HERE!!!
^^^ 18g do it right the first time and don't look back... That is what I hear from ppl all the time. If you want a quicker spool try porting it and find a good tuner/ tell the tuner what you are looking for
WRBWRXVII is offline   Reply With Quote
Old 09-17-2008, 10:20 PM   #14
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Great turbo, pulls all the way to redline.
Have a very conservative tune, as it maxed out the maf with a K&N typhoon.
This is on a Dyno Dynamics. It reads significantly lower than most.
007WRX is offline   Reply With Quote
Old 09-18-2008, 03:33 AM   #15
GDAryder
Member#: 184753
2005 WRX
i see......
You'll need a Walbro 255lph fuel pump, > check
, uppipe > check
, downpipe > check
, catback > check
, and a good tune.
check and check
i am, i was just curious as to what some other folks had going on with their setups
Old 09-18-2008, 03:36 AM   #16
GDAryder
Member#: 184753
2005 WRX
not bad....i got most of that stuff minus the tgv deletes, sti top mount (turbo xs fmic ftw), the bcs, the plugs, and the larger injectors.
Old 09-18-2008, 04:46 AM   #17
GDAryder
Member#: 184753
2005 WRX
***note i have a turbo inlet it is not on car as of yet tho****
Old 09-18-2008, 04:47 AM   #18
GDAryder
Member#: 184753
2005 WRX
Default ok so out of the few, who is running an EWG??
Old 09-18-2008, 06:39 AM   #19
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You shouldn't be curious what other people run as other set-ups have no bearing on you. Call your tuner and ask him for help. And yes, I am serious.
Old 09-18-2008, 11:16 AM   #20
GDAryder
Member#: 184753
2005 WRX
this thread was just for general ideas, and i am looking at tuners, at the moment.
Old 09-18-2008, 01:45 PM   #21
big16gwrx
Member#: 129459
I'm running the UR 38mm EWG kit...
heres a list of my mods....
http://forums.nasioc.com/forums/show....php?t=1598178
Old 09-18-2008, 02:59 PM   #22
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
I am getting ready to get my 18G 7cm
i have stock 2.0L block
844cc injectors
FMIC
Totally catless
Spt intake
UTEC engine management
44mm Tial Wastegate
Grimmspeed Uppipe
255 Walbro FP
Future plans are to get Meth
emsmap is offline   Reply With Quote
Old 09-18-2008, 03:24 PM   #23
GDAryder
Member#: 184753
2005 WRX
844cc injectors
FMIC
Totally catless
Spt intake
44mm Tial Wastegate
Grimmspeed Uppipe
255 Walbro FP
who you going to for tuning?
Old 09-18-2008, 03:25 PM   #24
GDAryder
Member#: 184753
2005 WRX
daaaaaaaammmmmn homie that thing is nice
Old 09-18-2008, 04:18 PM   #25
BlaxTrax
Member#: 139989
C6 05 Vette 11 WRX
00 Impreza, 03 WRX
FP TD05-18G 7cm^2
Oil feed line
V1 TurboXS top mount
NGK 1 step plugs
DW 750cc injectors
Perrin DP
Borla Hush catback
P&L EWG up-pipe
tial 44mm EWG
Coolingmist Veri-cool Meth injection
Perrin MBC
APS hard turbo inlet
Perrin LW crank pully
SPT intake
Walbro 255 fuel pump
I think thats it... Its all still sittin in my room right now. Just gotta find time to get her appart and togeather. Install meets FTMFW
BlaxTrax is offline   Reply With Quote
BC Coilovers: any good?? Who has them and what do you think of them?? SLO_02WRX Brakes, Steering & Suspension 3 06-30-2008 09:18 AM
Jon-E Hand Warmer... anyone have one of these, do they work well? SjYankee006 Off-Topic 4 10-24-2006 04:27 PM
P&P VF22: Who has it and how do you like it? PattyB69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-11-2006 01:13 AM
Koni Inserts...how do they work? HiVoltg12 Newbies & FAQs 3 02-11-2004 03:56 PM
Adjustable sway bars - how do they work? tomrichardson Brakes, Steering & Suspension 5 05-03-2001 12:56 AM
